Temp
Everything posted by Temp
,+1 Unless you plan to dig deeper than the neighbors foundations I probably wouldn't bother with the PWA either. If the neighbour that notified you asks tell them you aren't going deeper than their founds so it's not necessary The council Tennant probably won't care unless you make a lot of noise or similar. If you notify the council they are likely to want to go by the book and are likely to want you to pay for up to three surveyors and any other costs they can dream up. There is no penalty for not complying with the act. A neighbor would have to take you to court and prove you caused damage. Then the fact that you didn't get PWA would weigh against you. The judge might be more inclined to issue an injunction stopping work etc. Perhaps ask the neighbors if you can take photos of any existing cracks in the nearest rooms before you start.
To be honest I'm not 100% sure. So just my opinion.. In most cases the brick bond crosses the boundary so I could argue there is some "reliance on support" by each side on the other. To me that suggests that a strip of the outer leaf is probably part of the party wall. I would think that strip would be about as wide as the thickness of the main part of the party wall. Your drawing shows the new wall ties into the strip I believe is part of the party wall but only just. How have you arrived at the distance that it is set back from the boundary? Presumably its set back to avoid gutters overhanging the boundary but it doesn't look like you have allowed much for gutters?
Not much news but.. https://www.gov.uk/government/news/brokenshire-hails-package-to-build-homes-and-opportunities-in-communities
1) Planning Permission Pretty sure you will need planning permission because a footpath is a highway... https://www.gardenlaw.co.uk/phpBB2/viewtopic.php?t=12073 2) Party Wall Act Will your extension be 3m from his boundary or 3m from his house? See section 28 page 19 and the diagram 6 on page 20.. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/523010/Party_Wall_etc__Act_1996_-_Explanatory_Booklet.pdf Its the distance between your foundation trench and their house or outbuildings that matter. The PWA applies if: a) It's less than 3M or b) It's between 3 and 6m AND your trenches will be more than a certain depth (see diagram 7 on page 21
Does your council have the CIL? To qualify for the self build exemption you have to do paper work before starting on site. Not sure how that works if the founds are already in.
We have a rooms-in-the-roof house. Roof stick built using 200mm deep rafters filled with PIR. It's not enough insulation. Too hot in summer as well. Fitting PIR between rafters was a nightmare job that was too easy to do badly. If building again I would either build a conventional two story house with insulation at joist level or, if it has to be room in the roof, a warm roof with the insulation above and between the rafters.
Invoices and Receipts
Temp replied to nubbins's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
From memory I think it actually says they want VAT "Invoices" on the claim form. -
I'm thinking its a combination of not enough fixings and no expansion gaps between the boards.
- 33 replies
- render
- renderboard
- (and 5 more)
When is a conservation area not a conservation area..?
Temp replied to PeterW's topic in Party Wall & Property Legal Issues
Seems odd to define the area using a schedule. How do they deal with land that's not got an address (eg like a paddock or field)? Does the schedule have grid references? -
We have one sliding door and I would only use them where absolutely necessary. You typically need a wider door to achieve the same opening and they are slow to open and shut compared to regular doors.
Extra fee to PPQ for paying a planning fee?
Temp replied to Mr Punter's topic in Planning Permission
If you think £20 is bad check out the new fees for getting probate. -
I was involved with two groups fighting plans for large developments near two conservation areas. I discovered not all conservation areas are created equal. Planners will fight hard to protect some conservation areas and others they won't. Planners sometimes take an interest in the view into or out of a conservation area, in some cases this can affect plans to build some distance outside the conservation area. My council appears to use maps to define conservation areas. -
Can you still apply direct to the council to discharge or do you have to use the portal? -
Here it say it's for the "financial transaction"... https://www.planningportal.co.uk/info/200247/professional_portal/145/financial_transaction_service_and_payment_nomination So how come the Land Registry can charge £3 for a title plan with no fee? If they can do it.... -
understanding co ordinates on planning drawings
Temp replied to redtop's topic in Surveyors & Architects
Easting & Northing are coordinates for a point on the plot. Ideally you use a GPS to accurately find that point on the ground (unless the surveyor picked a landmark like a tree or or marked its position with a stake etc). I also recommend buying a 60m tape and double checking the dimensions of the plot vs the survey plan and title deed. -
Building control approval for self build mortgage
Temp replied to Water's topic in Building Regulations
Make sure you get ALL of the CIL exemption paperwork sorted before you start any work on site or you may loose the exemption. If in doubt ask. -
If you are going doing a Building Control Application you normally send them a full set of plans and other documents with the application. The BCO will look over the plans and write back with a request for any extra info he needs. That might be anything from evidence that soakaways will work (soil percolation test required) to engineering calculations for steel beams (Structural Engineer might be needed to do some sums). Eventually he will agree that what you have submitted is ok and you can start work on site. He will usually want to inspect the bottom of the foundation trenches before you fill them. -
The pooling restriction applies to all areas regardless if they have introduced the CIL or not. However I'm not 100% certain if the pooling restriction applies to ALL planning obligations or just S106 agreements. As I understand it the pooling restriction could apply to any planning obligation if it is a "reason to grant planning permission" but they don't usually say its a reason to grant.
Good question. Which is it?
Just to add to my post above... Googling formwork tiles finds there are quite a few makes.
These tiles might be an option... https://tile.expert/en-gb/tile/Energieker/Formwork I'm on my phone at the moment and it's hard to see the images but they look like tiles intended to produce the shuttered effect.
PS This change was meant to encourage councils to adopt the CIL to which you would be exempt.
Regarding the Section 106 agreement... The government changed the rules in 2015 so that councils can only collect ("pool") 5 different section 106 contributions for the same thing (That's five after April 2010). It seems very likely your council will have asked for more than 5 unilateral undertakings for "open space" since 2010 so how can they still be insisting on more? That said I've read here that some councils are bending/breaking the rules. More on this here.. https://www.ashfords.co.uk/news-and-events/general/pooling-contributions-regulation-123-of-the-community-infrastructure-levy-regulations-2010 I could probably find a link to the legislation if needed.
I think that fireplace works because they apply a texture first then press in relatively sharp/low area grid lines. If you wanted to get a wood grain effect you would have to press in the larger area of a flat board. The force required would be a lot higher. I guess it might be possible to press in a small board? Give it a try.
