Dreadnaught
    5
Everything posted by Dreadnaught
  1. Welcome Tamara! Where about's is your build?
  2. With a 5A circuit, do the sockets use round pins? Does one need to replace the plugs on side lamps accordingly?
  3. @Nickfromwales forgot his mince pie! Unlike him I would imagine.
  4. The 44dB is quite surprising too. Does the new model have any pumps within?
  5. Sorry to change the subject slightly, but I wonder why anyone has not considered using blown cellulose in interior walls. I visited a lovely Touchwood build in Suffolk recently that will do exactly that. Is it a matter of cost I wonder? Or perhaps the concern of the circular holes required? Any thoughts?
  6. Its fascinating how there really is no one-size-that-fits all. It depends so much on the individual circumstances. Its surprisingly subtle. Its why pros like @Nickfromwales take such care to look at all the parameters before recommending a complete solution.
  7. Yes I found that too. E10 (and to a lesser extent even E7) is not supported by even most electricity suppliers it seems. Some do, so if it interest you then you can find a company that will if you persevere. Having an E10 electricity meter installed can also take a bit of research too.
  8. Just to note for others that there is an option with UniFi for it to update firmware itself without intervention. But if I recall correctly that's not turned on by default (might be wrong).
  9. Sounds like BT have limited the options, probably to simplify their online support calls. The option you were looking for was to disable the WiFI network. The only disadvantage of having your BT modem transmitting an alternative WiFi network is that those that attache to it wont "roam" to the other APs. Some Wifi routers allow you to make the SSID "invisible", so people won't see it as an option. Look for that setting. Or alternatively name the Wifi network transmitted by your BT modem as "Do Not Use" or similar. Or simply just don't give them a password for it. So long as this other BT Wifi Network is set to to automatically choose its frequency it should not interfere with your Unifi WiFi network.
  10. In your case you're Mac is the "controller". An iPhone will do just as well. Either is only needed for setup to configuration changes. Nothing else. You don't need a CloudKey for setup. Its for remotely monitoring your network (optional).
  11. On E10: https://economy10.com/overview/. I think its a bit out-of-date now but might still be useful.
  12. A colleague recently set one up using the Unifi iPhone app and a YouTube video. I suggest looking on YouTube. (CloudKey is optional and most basic users won't need it.)
  13. Perhaps go for simplicity. A PCM58 SunAmp charged by E10 electricity. Much less capital cost. Probably only slightly higher running costs. Fewer things to go wrong. Simpler all around. Less hassle. Small and compact too. You could ask @Nickfromwales to specify the system. He knows a lot.
  14. A SunAmp with PCM58 outputs water at 58ºC, ideal for showers, baths and space heating. But it needs an input water temperature of about 65º or so to charge it. ASHPs struggle to generate water at 65ºC*. If they do so they become much less efficient and have to work hard, which causes them wear out, and to freeze-and-defrost cycle when its cold, especially when the outside temperature is around the freezing point for reasons to do with humidity. Not good. Not recommended. There is a SunAmp being developed with PCM34 (one person on here already has one). This outputs water at 34ºC and needs an input of perhaps 45ºC, which is easily generated by an ASHP. Water at 34ºC is OK for space heating but not warm enough for a shower but it can be used as a pre-heat for input to a boiler or heated tank (or indeed a SunAmp with PCM58). Does that help? PCM = phase-change material ASHP = air-source heat pump * there are special multi-stage ASHPs that can generate higher temperatures, but they are mechanically more complex and more expensive.
  15. @joe90, very helpful. Thank you. I didn't realise how the buffer tank for the UFH worked, with the coil within. Your diagram was instructive.
  16. This article (posted earlier by @daiking) might be a useful contribution to the debate: https://www.independent.co.uk/news/business/comment/brexit-scare-stories-ashoka-mody-imf-bank-of-england-mervyn-king-economics-trade-a8670416.html
  17. On the subject of cylinder temperature, while the ASHP could only heat to 55 or 55ºC in practice, I assume there is no reason why the immersion heater powered by PV could not, if plentiful sunshine allowed, heat the water to a higher temperature. A TMV would blend the temperature down as required for output. That would also do for any sneaky legionella bacteria too if the chlorine in the mains water hadn't done so already. I wonder, is there any upper limit for the temperature of the cylinder water heated by PV? Would the immersion heater have a cut off?
  18. I know that this has been covered before, but is there a legionella risk? I think the consensus from last time this was discussed was that the risk was overblown. I thought it worth mentioning for new people who may not have read the old threads.
  19. Haha, it sounds like an old Windows PC .
  20. Welcome @Grian. Your build sounds like a marathon. Hope you find some help here: I suspect you will.
  21. Here's a company commercialising paraffin-wax products for thermal buffering. They mention walls. https://www.microteklabs.com/nextek Who wants to be the first on BuildHub to try this out?
  22. There has been some limited research into using particles of paraffin wax embedded in sand (even just plain old beach sand) as a latent heat store. Such particles could even be made to flow. Some referred to this being "nano technology". I find it an intriguing idea. Prompted by @JSHarris above, I skim read a few articles in the subject area. Are there any links to that house which had paraffin-wax panels in the walls?
  23. Can of compressed air? Forgive my ignorance, but wouldn't the dust usually be caught by the filters (which it clearly isn't otherwise you wouldn't have posted)? Or is it fine dust that passes through the filter?
  24. If an ablate sphere is one that bulges in the middle like the Earth, what describes a rectilinear volume that does the same?
  25. Yes, and the SunAmp unit is a lot smaller in volume so if space is at a premium then that's another reason why the extra cost might be worth it.
