Everything posted by Dreadnaught
https://www.bbc.co.uk/news/uk-england-devon-45450278 Television wildlife presenter Johnny Kingdom has been killed in an accident on his land. The film-maker, photographer and author, who specialised in his local area of Exmoor and north Devon, died on Thursday night. Police confirmed emergency services were called to a field near Wadham Cross in Knowstone, Devon, to reports that a digger had rolled over.
Welcome, @Rob99. There are lots of people here who will be able to answer your questions!
Welcome aboard, @IainH. Sounds good. Where abouts are you located?
Me too.
Welcome @Sean003point5. Love that curved roof line shown in the plans!
Welcome @Tyke2! With your knowledge, I look forward to learning from your questions and answers.
Very interesting discussion. @jack, with the benefit of hindsight, would you have changed anything about your TV room to correct for that propensity for summer overheating? Asking as its relevant for the design of my future house.
Drainage design — right approach?
Dreadnaught replied to Dreadnaught's topic in General Construction Issues
Good point @Russell griffiths. The only problem is that I don't have any windows at all from either of the bedrooms and also none from other rooms on those sides of the house. Instead I have lots of large roof lights.- 60 replies
- foul drains
- surface water drains
- (and 3 more)
So could I just lay a drain at 1:8 over 20 m to achieve my 2.5 m drop, no chambers needed? Presumably not. (Or 1:13 for the foul drain?)- 60 replies
- foul drains
- (and 3 more)
Delivery weights during a typical build.
Dreadnaught replied to epsilonGreedy's topic in General Self Build & DIY Discussion
Delivery/collection of site hut, welfare facilities (site toilet), storage container? I think you're having a garage for some or all of those. -
For those like me who did not know, the ring is for safety to stop a child falling down the hole. The stipulation is in Building Regulations Part H.- 60 replies
- foul drains
- (and 3 more)
The foul sewer is ⌀ 100 mm. The surface water drain is ⌀ 300 mm.- 60 replies
- foul drains
- (and 3 more)
Ah, interesting. Makes sense. Main sewer run in the access road. There is a storm-drain manhole and an "unable-to-lift" foul sewer manhole, both within 10 m of my boundary in the road.- 60 replies
- foul drains
- (and 3 more)
Thanks @Temp. Fascinating link. I note it says "anything deeper than 1000mm requires a brick-built or concrete section manhole". I assume that applies to both my connections, foul and surface. I see on my drain survey that for each drain there is a manhole only a few metres away. I guess that it is easier to run to the existing manhole(s) rather than intercept the drains at a point closer and make new ones.- 60 replies
- foul drains
- (and 3 more)
The level difference between the ground level of my site and the drains looks to me quite large. In the case of the foul drain, it looks to be 1½ m. In the case of the surface water drain, 2½ m. Is that a concern? A 1:40 slope would not do it, of course, the run is only about 20 m. I assume a drop needs to be achieved. How are these usually done, some form of chamber? I am also slightly concerned about working with such deep excavations.- 60 replies
- foul drains
- (and 3 more)
I just added above the FFL recommended by the EA. They recommend a FFL of 6.13 m ODN for a 1:100 risk level of 5.83 m ODN, a difference in our case of just 300mm, rather less than your 1.5m. In our case I spoke to people who had lived locally for 20 years or more. They said that flood water has never even reached the access road (which is at about 5.9m ODN), let alone my building which will be at 6.42 or above with my no-dig and passive-raft foundation. However, with global warming, perhaps the future will not be like the past. The annoyance for me is that I may need to put an evacuation door in the rear of my property (I have no garden). The EA considers the access road to be flood prone and so assumes I may need to high-tail-it across my neighbours' back gardens in the event of a flood. Rather ridiculous I think. Perhaps they are envisioning a Krakatoa-style flood with mere moments to respond. I would have thought a sedate egress in wellies would be more than sufficient!- 60 replies
- 2
- foul drains
- (and 3 more)
I found my proscribed FFL from the Environment Agency for 1:100 flood risk. The original planning permission for the old house design (not a passive house) had an internal FFL of 6.42 m ODN The plot is on average 6.29 m ODN The EA FFL is a minimum of 6.13 m ODN The EA 1:100 flood risk is 5.83 m ODN The storm drain in the road adjacent to my plot: cover level 5.9 m ODN invert level 3.8 m ODN The storm drain discharges into the river at invert level 3.41 m ODN It occurs to me that fall from the plot to the drain is some 2½ metres. That strikes me as quite a lot.- 60 replies
- foul drains
- (and 3 more)
Yes. It was done for the original planning permission in 2015. You are right, I must dig out the FFLs from that.- 60 replies
- foul drains
- (and 3 more)
Not quite, Russell. Not directly, but almost so. There is both a small access road and the boat houses between my plot and the river. However, in the access road directly in front of my plot there is a storm drain that discharges straight into the river just 40m away. It is to this that I plan to connect. So effectively I am discharging straight into the river.- 60 replies
- foul drains
- (and 3 more)
Making OSB air tight
Dreadnaught replied to MikeSharp01's topic in Environmental Materials & Construction Methods
Oh, that's concerning. Very concerning. It makes me wonder if: (i) there is best practice when blowing-in cellulose insulation to minimise voids; and (ii) there can be any post-installation checks to spot them. -
Grand Designs Live Birmingham
Dreadnaught replied to ultramods's topic in General Self Build & DIY Discussion
I fully sympathise. I barely trust my own taste to pick out a single item sensibly let alone a number that form a harmonious whole (whatever that means). I can look at something and think it looks nice but I have no conception as to why. -
@ultramods it is unlikely that this is relevant for you but for interior design I am planning to attend an interior-design course. Its £150 for 6x short classes with a private interior-design company close to my plot. In a similar vein, I know of one other person on BH who is going on a (different) course. I have no knowledge of, skill in, or aptitude for interior design whatsoever. The idea is to hopefully pick-up some basic principles but perhaps even better to spend time in the company of others from whom I can beg-borrow-and-steal ideas and without spending too much money doing so. -
I am I suspect an unworthy interloper into boffins' corner. I have been following many of these discussions with a keen interest. Currently, each of your posts requires me to look up many things online. My history of programming started as a youngster but was curtailed quite early by a career change. I am keen to learn more, to monitor things and to automate things. I am learning by watching. Anything here that help someone like me is welcome. I use the Apple ecosystem so Apple Homekit is of particular interest although I don't think I have seen it mentioned here. I am also interested in the new Bluetooth mesh protocol for lighting control. I wonder if it will disrupt the lighting-design industry.
I visited Grand Designs Live in London this year, my second ever visit. In my case one day was plenty, even a long half day was enough. Of course, it depends slightly on what you're after but generally I found it to be focused on window companies, under-floor heating companies, and then the usual range of water-softener salesmen, novelty picture and candle sellers, and kitchen gadgets. Overall I found it rather disappointing. For me at my stage of my build, it paled besides a visit to the NSBRC in Swindon on one of their periodic exhibition days. Just my tuppence worth. -
I have an old one but need a new updated topo survey. That's next on my to do list. Have a quote for one. I have asked the surveyor to include some other things, such as the access road (which is narrow). The thinking was that I could provide the dimensions to suppliers to help them plan their access but I am now thinking that pushes up the price of the survey for no good reason and besides when I mentioned the restricted access to one of the timber frame companies they simply popped by when they were in the area (and pronounced the problem to be manageable). The survey quote I have is for £1,350 plus VAT, and includes: 1. survey of any buildings - their external footprint, plus any external steps and ramps 2. survey of external building services such as down-pipes, gullies, etc. 3. survey of all walls, fences and hedges to show type and height 4. survey of all changes of surface material - tarmac, concrete, paving, grass, etc. 5. survey of all manholes and service covers, plus pipe sizes and invert levels where possible 6. survey of all other features and furniture, plus any overhead poles and cables 7. survey of major trees to show position, girth, spread and height only 8. survey of levels across the area at a maximum spacing of 10 metres, plus all changes of height and slope 9. the survey will include the access road and details of the public highway kerbs, etc. 10. we will include height details of neighbouring buildings if possible. Is this OK? By the way, does finished floor height include the floor make up & floor coverings? I am still working on the foundations system. And have not decided on floor coverings yet. On the foundation system, I had feared I would need a suspended floor with a sacrificial void for clay heave but I have just spoken to a local SE (the same SE as above) and, with a little urging from me, they have suggested it will be possible to design a insulated reinforced concrete raft/slab, MBC-style. The raft would be connected to piles. I have since gone back to MBC to ask them to ask their friendly SE to confirm this and am expecting a reply shortly. Back to drains. Having skip read the building regs for draining, drainage does not look terribly complicated.- 60 replies
- foul drains
- (and 3 more)
