Seems a good thing to try out first. Someone, and I think it may have been @joe90, fitted some pipes with a venturi on the top of them to draw out damp. That seemed to be a good idea.
Some of you may remember Ben, over at the other place. His project went totally pear shaped and he was looking to pull out. http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=8401 In hindsight, there was probably a lot that 'the community' could have done to help, even if just meeting him for a cuppa. He did have the balls to put up his problems, which was a good thing I think. I still wonder what happened to him.
Basic economics. It is the manufacturers job to maximise profit, the consumers job to minimise it. These are really basic bits of kit, a food blender is more complicated. It is easy to get sucked in to a few 'special' features. Mine has a power setting (hardly ever use it), a temperature setting (use it all the time) and a timer (very useful).
To reduce condensation by ventilation quickly and, initially, cheaply, could you not stick a fan in the underfloor void?
A reluctant oven can contact JustEat to get you a pizza. Can't do that on a gas on.
remote location with need for internet access
SteamyTea replied to joe90's topic in Electrics - Other
Try this app and see what it shows. https://opensignal.com/ Several years ago I read in my weekly comic about some rural Indians that cobbled together a couple of old satellite dishes and wifi transceivers. They used them for line of sight communication. Seem to remember that they could cover a distance of 30 km. Anyone tried this? -
I pulled my old one apart (was a £20 one from Maplins). There really is not much to them. A bit of copper wire in a coil, and temperature sensor, some magic circuitry on a tiny board and, on the one I had, two push buttons and a variable resistor.
This is not an easy post to write.....
SteamyTea replied to ToughButterCup's topic in General Self Build & DIY Discussion
Have you looked at crowdsourcing, not the same, but some guy was trying to raise money for this: https://www.gofundme.com/9wvxt9-replacement-window- 62 replies
- planning
- project management
Nest home security?
SteamyTea replied to Jeremy Harris's topic in Networks, AV, Security & Automation
I think the latest about CCleaner shows just how insecure our systems are. -
Loft Insulation Upgrade
SteamyTea replied to MikeGrahamT21's topic in Lofts, Dormers & Loft Conversions
I made large 'sausage rolls' of insulation from weed control barrier stuffed with mineral wool. Stapled these to the roof rafters leaving a ventilation gap. Works well. Has the advantage that you get a bit of gentle warning before you crack your head on a timber. -
Nest home security?
I think part of the security problem is 'cloud storage'. I have a Kindle, I like it, can read books and watch movies on it. And it only cost 40 quid. I had an encrypted file which I wanted to read, so popped it onto the kindle, unencrypted it, read it, closed it down and deleted it. I thought that was the end of it. Imagine my surprise when I was browsing my file system and noticed that the file was still there. I think what happened was that it copied the file to the built in cloud storage from the Kindle, and I only deleted the local copy. Also we may have trouble with OSs. The open source people always claim that anyone is free to look at the source code, but I doubt if there is a person on earth that could actually do that and find anything sneaky hidden in there. Maybe a team of highly skilled software people might be able to. So we rely on trust a great deal. It may be time to start using less software and more hardware, at the expense of less convenience and versatility. -
Ian Have you considered a holiday. Maybe a week in the sun, or God forbid, Canada, may help.- 62 replies
- planning
A few questions about vapour permeability etc
SteamyTea replied to Crofter's topic in General Construction Issues
That is really down to just collecting data. But I think that simply extending the extremes of a model would be good enough. -
I would think that a temporal statistical model would do that. Just run the above model though the different temperature and humidity conditions for an area, then weight those results to local weather data. -
Sell your current place, cash is king in this world.- 62 replies
- planning
Why not DIY SIPs. Basically just a couple of sheets of OSB, a sheet of Celeotex or similar, some posts in the right place and a pot of glue. Knock them up in a garage, tow to site, nail together and then clad in tin. -
Just been brought to my notice over at the other place that there is a Part R of the building regs about communication cabling. https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/517789/BR__PDF_AD__R__2016.pdf
Is the comparison between space probes and mobiles really relevant. They are designed to do different things, in different ways and in different places. I still have a working scientific calculator from 1979.
Insulation, Heating, time constants etc. Am I expecting too much?
SteamyTea replied to ProDave's topic in Boffin's Corner
Do you have a couple of temperature and RH sensors rigged up to a logger. Then you can see what is really happening -
Bogged down in the English planning system
Once the plasterboard is 'up to temp', say 19°C for an internal air temperature of 21°C, it then starts to fully transmit energy. So you can think of it as a change from absorbing energy from the internal air to just allowing the energy in the internal air to escape to the outside (which is your insulation/frame/render and finally the great outdoors) only being hindered by the R-Value (or U-Value). I suspect what other have said about moisture is correct. A kg of water takes 4.2 kJ to heat up 1K. But to evaporate 1 kg of water takes 2,260 kJ, 538 times more energy. This is also affected by the relative humidity, I think the higher the ambient RH, the more energy is needed (why things don't dry well in the tropics) Now I have no idea how many kgs of water is in your plasterboard, but for every kg, you need 0.63 kWh extra. -
Bunsen Air Heat Pump for domestic hot water
SteamyTea replied to readiescards's topic in General Alternative Energy Issues
Seems to me that you are better off with E7. Are new heat pumps going to have to change to R774/CO2 ones in the not too distant future. -
For those that missed it, Costing the Earth is available here. http://www.bbc.co.uk/programmes/b0938p7z And the podcast is here http://open.live.bbc.co.uk/mediaselector/5/redir/version/2.0/mediaset/audio-nondrm-download/proto/http/vpid/p05frp5j.mp3
