An architect will work to minimum building regulations, while charging extra because they are 'the professional'. You really need to do a thermal model. Now as you like woodworking, have you considered a stick build?
10 quid fan heaters, it will not be long until the carbon content of our electricity supply will be 50g?kWh which will beat combustion technologies hands down every day. This is not how you set up a heat pump system. 130 kWh / 24 h is a power of 5.4 kW, which is ASHP terms is about as small as you can get.
The Building Regulations are here: https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/697629/L1B_secure-1.pdf The L1B is for existing buildings. Seems to be 0.22W.m-2.K-1 unless it is an upgrade and then it is 0.25 While you may not have to improve the losses though the floor, you may want to. Part of thermal calculations is temperature difference, and as the ground does not change temperature much, and UFH heats the floor more than an unheated floor, it makes sense to insulate it more.
- 22 replies
- underfloor heating
- insulation
That will be worth following.
can planning authority issue a split decision?
SteamyTea replied to MYL's topic in Planning Permission
Am I (expletive deleted). But when I ride my sister's bike I split my difference. -
That is my understanding, but it is over a decade since I was involved in it.
I got told that by a carpet fitter about 35 years ago. Had forgotten all about it.
Beware of strangers bearing gifts.
I got a £270 speeding fine for overcompensating the times I have been stuck in traffic. It don't work like that.
What Resin To Use For Resin Anchors
SteamyTea replied to Johnny Jekyll's topic in Building Materials
Has anyone mentioned degreasing the studs/bolts? If the resins is a polyurethane based one, moisture be of less of a concern. Often with epoxy resins it is hard to get a new mix to adhere to a fully cured mix. Many a long night I have spent in a workshop waiting for epoxy to cure enough to apply a new substrate. -
Good on you, we like definitive answers on here. There is still some confusion about I stalled capacity and limited capacity AFAIK.
Start by looking up some data. https://flood-warning-information.service.gov.uk/river-and-sea-levels
I am a bit dubious about that. Reflectivity is the important part. Or in Cornish, "is it shiny or no". Colour is more to do with what wavelengths of light are absorbed. Not all wavelengths will give a problem, but that is getting into the Ultra Violet Catastrophe, which quickly leads into the quantum nature of photons.
GSHP planned but not hot water??
SteamyTea replied to Selfbuildsarah's topic in Other Heating Systems
Any reason you want a GSHP over and ASHP. There is a large price difference in the units and the installation costs. Don't get temperature, the ⁰C or K, confused with the power, the kW, of a unit. Power (kW) is also different from energy, the kWh unit is usually used in the domestic setting for energy, through the proper unit is the joule, you need 3,600,000 J to make a kWh. What you need to do first us a decent thermal model of the house. This will set the maximum heat load and the most likely power needed satisfy it. Going from an occupancy of 2 to 10 is a huge difference, you are probably financially better off with a secondary cylinder that just uses immersion heaters run directly off the mains electricity. To heat a cold, 200 litre cylinder to 60⁰ will probably take around 12 kWh of electricity. That will cost, even at 20p/kWh, £2.40 a day. Less that a couple of metres of GSHP pipe. -
Isn't there a problem with galvanic corrosion due to dissimilar metals i.e. zinc (4 shells 2 outer electrons) and aluminium (3 shells, 3 outer electrons). Many module manufacturers will not warrantee their product unless a recognised mounting system is used.
Will it be a 'limited by supply' scheme. Most of the government 'incentive' schemes seem to be. And I am sure it will be shockingly complicated overall. What is does do is put a floor price on new/replacement installations, not sure if that is good or bad for the general public though.
Did you manage to see how they fitted the balustrade in place. Might be useful for a when people ask how to fit one to their stairs.
Mobile Phone Reception issue?
SteamyTea replied to ashthekid's topic in Networks, AV, Security & Automation
Are they. Not my experience of listening to phone interviews and radio phone in shows. -
When I stand out in the cold, my testes get a walnut veneer.
Coat hooks still give me the shivers 43 years on.
Well it is better than none. But for a 3 or 4 car family it may be a problem. Especially in rural areas. Then there is the issue of car to grid. That may have a 4 kW limit to it (like most domestic PV).
Pleblon, it goes nicely with vulgarlour.
What next, will we have to fit locks to doors and windows, plumb in water, and take waste away. I would think fitting a charging point to a new build was dead easy. Trouble is, it will probably only be a 7 kW one.
Planning rejected "Your proposal is proper whack"
SteamyTea replied to Temp's topic in General Self Build & DIY Discussion
I have to work with some, and out of 6 of them, only 1 is pleasant. (expletive deleted)ing shits the lots of them.
