SteamyTea
    200
  1. Time for Alice Cooper's Muscle of Love.
  2. You have to delete the original, including the @, and start again.
  3. That is to stop us all from correcting and clarifying what we have typed more than 30 minutes earlier. So @Nickfromwales, typing this instead of Simple answer is switch it on and leave it for 3-4 hours
  4. Reminds me of my youth.
  5. Cannabis. He smuggles them across the boarder most night to corrupt the Cornish youths. Last I heard he got 2 pasties and a cream tea for an eight. Purple Bude is the street name.
  6. Could you not just pop some weak bleach into the header tank, run the hot taps for a few minutes, leave for a few hours. Flush out the system for half an hour, then heat up the water. The presences of legionella bacteria in the water is not, in itself, a problem. It is when that bacteria is dispersed via water vapourisation, as in air conditioning units (where the problem comes from, not your daily shower) that there is a problem.
  7. Do you know what sensor the Shelly uses? I suspect it is a DHT22.
  8. Is the Banksy worth more than the boat. At least Robin Gunningham did not have to go far to paint it.
  9. I do that with the arc wielder, touched a can of WD40 that a dickhead workmate put on the wielding bench when I had the mask down.
  10. Have caught my fingers a couple of times. Does smart a bit.
  11. That looks dangerous. Shall order myself one.
  12. Damp wood maybe. Overused disk. Only using the outer edge of the disk. Pushing too hard. Assuming that the grain makes no difference. I also remove the guard when I have the abrasive disk on. Actually usually remove the guard on the small angle grinders. I have been using angle grinders since I was a kid to sort things out, so hard to say what I actually do, it is just second nature to me.
  13. New blades don't much, blunt ones do. Or the jiggler/shaft on the saw is worn. I use an angle grinder for just about everything I can.
  14. I find that an unbelievable figure. I will have to look into it. Today, at work, I weighed the waste, worked out at about 25% of perfectly good food was thrown away. The really staggering thing is milk. Probably 75% thrown away. In the olden days, we would have just rejugged it. Not allowed to do that now. We also wrap our cutlery in paper napkins. A good 20% get picked up by customers, not used, and we have to unwrap them and wash them, then wrap them again. We are, according to a certificate, 'carbon neutral'.
  15. Labour member Philippa Hulme said: “It fits beautifully with the eclectic mix of the harbour: you’ve got apartment blocks that look like boats, you’ve got boats that look like houses. That’s just part of being Bristol. I think it’s fantastic.” And a shed that floats.
  16. They are (expletive deleted)ing hideous, unlike the meatballs and gravy. Send them back. Did you choose them from the ColourClimax magazines.
  17. Forget about them, they are not for domestic settings.
  18. Has the inverter been set up for a different country? https://www.fronius.com/~/downloads/Solar Energy/Operating Instructions/42%2C0410%2C2148.pdf
  19. I was actually comparing the bills, which includes waste water, and surface run off. it is the waste side that is so expensive. We pay to keep the Atlantic Ocean clean and the beaches sparkling. Then total wankers let their dogs shit on the beaches.
  20. How about picking the right balls and shooting at a number of narrow goals. The ball is either the problem or the solution, and the goal is the target. You may miss, but the overall effect will be closer to where you need to be than just leaving it up to fate and the free market. An example if this sort of policy is the Landfill tax. Companies and individuals don't want to pollute the environment, they want to do the right thing, as long as it is cheaper to do so. The problem with the LFT is that it is now very expensive, and the chances of getting caught, and the associated fines, are relatively small. So the ball is waste, the goal is proper disposal. Make it easy to dispose of it, and it will be disposed of correctly.
  21. @Dave Jones Just spent 2 minutes looking up the price of the above ASHP https://www.cityplumbing.co.uk/Vaillant-Arotherm-Plus-7kW-0010037213/p/477547 Can save almost £2500 before the haggling starts.
  22. 184 lt/day over the last year, and there is just me. I am a clean chef, not one of those grubby, unshaven ones.
  23. I shall try and remember to look up my figures when I finish work. Southwest water is the most expensive in the country. 8 times the price of the City of London.
