SteamyTea
    200
  1. Worth working out your energy usage. Ideally you want to minimise usage, then the problem goes away. Also worth considering car charging. We are heading to a BEV world, so may be better to fit 3P now. You can easily connect up more PV with 3P as well. Don't worry about the system being balanced, that is the electrician's job.
  2. Welcome. Have you considered a night storage heater, some of the more modern ones have fans built in. Saves having a battery if some of the power comes from the PV. There is also air to air heat pumps. These can be quite cheap to run. Usually worth working out the heat losses of any building, even a shed, then you can size a heating system to be in the most efficient window, most if the time. Really comes down to how much you want to spend. Do you know much about LED grow lamps? Often thought about buying some, but don't know enough about plants and getting the best growth out if them.
  3. Jubilee Pool wanted to try something similar, but ended up with, in effect, a small well supplying a heat pump. There was a geothermal hot dry rocks project here. Achieved its goals of getting water back out at 100⁰C. Well when I say achieved, they pumped in 100 litres of liquid and got 1 kg of steam out. Then the project moved to France as it was EU funded. Can't happen down here are the whole of Cornwall has a moratorium on fracking. Worth noting that at Rosenanowes Quarry, Cornwall has the best resources, there is a resource of 120 mW/m². So that is about 1 kWh/m².year. Makes you wonder why they bothered.
  4. And 0.021 kWh of energy. Can see why we use gas and electric.
  5. Because they want to show they are a separate country. Whatever I did, my sister would do the opposite, just to show her independence. @China21 Following with interest as I want to 'expand' my shed, and welcome.
  6. And we can do an autopsy on you, if you like. Just to be clear, I don't think element cycling is a problem, though it used to be with car indictor bulbs, they always lasted less time than headlight bulbs. Down on the seafront at St. Ives, there are dozens of ASHP, usually to cool beer, they are very exposed and none seem to be showing bad corrosion.
  7. They may be on about thermal cycling. If the element is on for 60 seconds, then off for 120 seconds, then on for 60, then off for 120 i.e. mimicking 1/3rd of the output potential, then it may shorten the life. Would be a strange setup then did that though.
  8. Work out the price difference, then look at how much electricity that will buy in. Also, at 15⁰ off horizontal, you are limiting the production quite a bit. Will be good around noon, in the summer.
  9. I was reading about WiFi7 the other day. https://www.howtogeek.com/782023/what-is-wi-fi-7/ (not the most technical of articles, but you get the idea) So why bother with terrestrial broadcasts? Seems the technology is already here to make better use of broad band in the home. There are a number of projects make use of cheap hardware to stream TV. There is also Radio, very cheap and the pictures are better.
  10. ASHP to do both space heating and DHW. Then add PV. Much of it depends on what you think is important. Constant supply of heat Cheapest installation price Most reliable Cheapest running costs Least GHG emissions Simplest to install And many more
  11. Just goes to show how useful proper energy monitoring and basic analysis can be. And it only cost a few quid.
  12. My old (actually younger than me) university supervisor had long email conversations with him. The conclusion was, don't bother, buy a half decent professionally made one. It is a real shame that Proven are no longer about (think they got bought by Kingspan, their 4 kW turbine was rugged and reliable (unlike the 6 kW).
  13. Yes, most of the time a loft, even an uninsulated one, gets quite warm. Also helps the ventilation: a warm roof is, but definition, really just another room.
  14. I can answer that, having been imprisoned in @joe90's attic. No. You may have noticed that his loft is a warm roof, and I think he sucks some of the warmth out of it, as well as the rooms.
  15. https://www.thespruce.com/what-is-bar-keepers-friend-5214383
  16. Not sure either, though I think the last two versions were just tidying up, nothing fundamentally different.
  17. Ask @joe90 I think he had this problem.
  18. Is there a filter you can easily check to see if there are any bits of the pump in it?
  19. It is You get the very narrow ones then.
  20. The shower label is starting to look like a used johnny
  21. Not if the unit containing the propane is indoors. I think there may be a 150g limit. A new record of 9.7g/kW was recently achieved, but current units use around 60g/kW. https://www.coolingpost.com/world-news/propane-heat-pump-hits-new-efficiency-record/
  22. Assuming the place is watertight and it is now just a case drying out, then a tiny bit of basic physics may help. Relative humidity is not the amount of actual H2O in a mass of air, rather it is a ratio of the amount of H2O that is in the air to the total amount it could potentially contain. This is why it varies with temperature. Think of it as a sponge that can hold 100g of water, but is only holding 75g of water, still feels wet. There are three main ways to get rid of liquid H2O, physically remove it i.e. find something to mop it up. Heat it until it evaporates i.e. blow hot air on it. Change the ratio of dry air to wet solids i.e. dispersion/diffusion. Usually we do the latter two in one cycle, so we heat which lowers the RH, then we disperse it into heated air, that is at an even lower RH. Now if you cannot easily run a fan off electricity, some sort of natural ventilation will be needed, careful design can increase this. One way to increase the input of outside air is to have a hole in the wall downstairs, and another hole in the wall upstairs, then add heat near the hole downstairs. This will reduce the RH of the air in the building, which improves the evaporation rate: evaporation takes place at all temperatures, not just above 0°C. By allowing the hot air to rise though the building, while being replaced with air from outside (which will almost certainly have a lower amount of H2O in it), drying will slowly take place. This is why forced ventilation is used, because if you are only taking out a few grams of H2O every hour with natural ventilation, it will take a very long time. If you are on site, or the site is very secure, you could use a portable generator and a gas heater to heat and force the wetter air out. If the structure of the building is very wet, then it will take a long time, and a lot of energy. You may be better off making up some clear windows on the sunny side, and let the sun help (wait till March). Also removing all plaster and getting back to the minimum structure will reduce the amount of trapped H2O that has to be removed. If it is a single skin brick building, make sure the wall 'facing the weather' usually the SW side, has good pointing and maybe a waterproof treatment. Purely as an experiment, it would be interesting to put a sheet of clear acrylic over the outside sunny wall to act as a greenhouse. This could help heat the wall from the outside, while also keeping it dry. Small vent holes at the top would be necessary.
  23. I would have thought that if you know the charging characteristics of the batteries, and the ability for the the inverter to supply, you could find a suitable battery pack. Not that many mainstream makers of batteries once the branded cover is off them.
  24. I thought @pocster was using MAC addresses, but was having trouble.
  25. Is it the LAN/WiFi hardware going to sleep?
