There are around 28 million homes in the UK. Has anyone come across many with IR heating? Not as if Physics has changed any, even if you allow for the difference between Newtonian and Quantum modelling methods.
What is there to stop someone falling down to the lower, more sloped, level from the upper, less slopped, level? Road crossings use a textured surface to help the blind.
Heat Pump vs Gas Boiler: Relative Climate Impact
SteamyTea replied to Green Power's topic in Air Source Heat Pumps (ASHP)
I did see something the other day about not having children as we 'inherit' half our children's resource costs. Not something I subscribe to, except I dislike children, and don't have them. So inadvertantly saving the planet for further generation of idiots to make mistakes. -
Why wait till Christmas. Guy Fawkes night tonight, so will need good plumbing to put a Catholic out.
I think you have actually hit the nail on the head. Except that population is used as a catchall as the problem, not the solution. I was talking to a St. Agnes resident yesterday about the latest sewage spill. The problem, according to them, is the increase in housing, and associated people. I pointed out that, as we were outside of a holiday period, the population was as low as it goes, so that can't be the problem. I then pointed out that over August Bank holiday, the same thing happened (actually told a well known actor to take his family to another beach). I also pointed out that the existing sewage system is no 'listed' and could be improved. So population, time of year is NOT the problem, it is inadequate infrastructure. Infrastructure is a political issue (may be local or national, but it is a human decision). Infrastructure costs often seem out of proportion to the local benefits. Ask each resident of St. Agnes to pay £1000 each to improve the sewage system and you will get a flat 'No Way'. They think it is the SW Water's job to do it. They think that SW Water should 'just get on with it'. So a £10m pound project, that would improve the environment, needs to have the load spread across many people paying, which requires people, lots of people, each paying a little. If you go back to historical times, villages, small towns and cities were highly polluted and horrible places to live (people moved out in the summer), but by spreading the load nationally, these places became nicer. So reducing population will only lead to lack of facilities, not better ones. It is all to do with distribution, there are no lack of resources. -
The principles apply, but the surface area to volume does not scale in a linear fashion. Except it is wrong. -
Yes, humidity can be a problem, but a much more manageable one. You can leave a notch around the trickle vents, it is only plastic and wood than needs shaping.
You are right, except you are totally wrong. Thomas Robert Malthus (1766–1834) Club of Rome (1968) Paul Ralph Ehrlich (born May 29, 1932) They are just the well known ones, and they have all been proved wrong. Now distribution of resources is a totally different matter, and this is what you are probably on about, without realising it. Just done a quick calculation, which may be wrong somewhere. But if we say that a m2 of land can produce constant 3W of power, and each person on Earth has access to a mean of 3 kW (currently about 2 kW), then we need an area of 1000 km2 to produce that for a population of 9bn people. So an area the size of France and Spain combined will do it. But it would, of course, need to be distributed around the globe. But it is not a huge amount of land and it does not have to be used exclusively for energy production, unlike nuclear and thermal combustion, and to a certain extent hydro. -
I think the term you’re looking for here is greenwashing as those statements are neither linked nor relevant. Not sure you are right as the title is; Heat Pump vs Gas Boiler: Relative Climate Impact The link is climate impact. -
So would I.
The main roof does not look that large, roof area is your friend with solar. Shading, of any sort, is your enemy.
Yes, and the same as 2,862 kWh of natural gas, gasoline, timber or coal. A kWh (not kwh) is derived from SI units for distance, mass and time. The real unit of energy is the joule [J] and is very small, the force needed to move a kilogram 1 metre. If you move that mass and distance in 1 second, then it is known as a watt [J/s] If you carry on doing that work for 1 hour, then that is a Wh. It is often easier to think of energy as gasoline or diesel in your fuel tank, and the engines power is the rate that you use up that fuel.
Write, not send.
COP 27 is not going to be of any interest to you then.
That may be true, and quite good for time of year. Not what your screenshot is showing. kW is power, kWh is energy, they are not, on their own, interchangable.
I think it is a west country thing, took solicitors 5 months to sort it out for me. An acquaintance has recently had a similar wait.
Small, achievable steps. It will soon start snowballing.
Thermal or moisture expansion and contraction maybe?
So halve the loads and hope for the best. What we usually did. I am not sure how elastic PU foams are, when I say elastic, I actually mean work evenly within the theoretical elastic limits. I think by the time you get to the nasty end of Young's Modulus, the point of no return has been reach and the material will fail rapidly. You only got to bend, or shock a sheet to see how easily it can snap. I don't know much about expanded and extruded polystyrenes, had to make some tooling for some once, but never even say the production process. They feel more compressible than expanded PU, but fingertips can easily be tricked by a softer feeling material.
So altitude as well.
So the humidity in the air had fused, then solidified. Which bit she in? This time a few years back the OAT went from 24⁰C to -7°C overnight, in Halifax.
I think you are right. Water can be 'enter' into brickwork and render just through wind driven rain, leaky downpipes and guttering, standing water etc. To my mind it does not make much difference to drying out what the render is made from when it comes to drying out. So treat internal humidity and external dampness as separate problems. Then, anything that is between the two will sort itself out in time. @darkrabbit Good luck getting an old house airtight enough to take advantage of MVHR
As usual, there is misunderstandings around heat pumps. Sized correctly, and run as intended, they are compatible to gas heating on cost. With any system that uses UFH, plenty of insulation has to be fitted under the pipework. You would not put your radiators outside on the wall, so why would you, in effect, do the same with UFH.
