Nickfromwales Posted February 15, 2018 Posted February 15, 2018 14 minutes ago, Onoff said: Yay! In the cold, sober light of day I'm bang on perpendicular to the rear wall! TF for optical disillusion! Moral, drink more! I now need to cut an accurate 180mm dia hole in the ceiling but DON'T want to spend £30 odd on a tool with a cowl so off to T'station for their <£10 version. Errrrr.....compass and a padsaw THEN get pissed
daiking Posted February 15, 2018 Posted February 15, 2018 1 hour ago, Onoff said: Yay! In the cold, sober light of day I'm bang on perpendicular to the rear wall! TF for optical delusions! Moral, drink more! I now need to cut an accurate 180mm dia hole in the ceiling but DON'T want to spend £30 odd on a tool with a dust cowl so off to T'station for their <£10 version. If that’s the silver line adjustable hole cutter... Good luck with that!
Onoff Posted February 15, 2018 Author Posted February 15, 2018 Just now, daiking said: If that’s the silver line adjustable hole cutter... Good luck with that! The very same. Looks lethal!
daiking Posted February 15, 2018 Posted February 15, 2018 Just now, Onoff said: The very same. Looks lethal! Lethal in the same way a shotgun is and probably less accurate
Onoff Posted February 15, 2018 Author Posted February 15, 2018 (edited) 6 minutes ago, daiking said: Lethal in the same way a shotgun is and probably less accurate I'm looking at it realising why people duck when they get out of helicopters! @daiking, sounds like you've experience of this. Other than it smelling like a cheap Chinese air rifle what's the score with it? I'm thinking it might be worth sticking a temporary timber batten up between the joists to keep the pilot drill on centre. Edited February 15, 2018 by Onoff
Onoff Posted February 15, 2018 Author Posted February 15, 2018 1 hour ago, Nickfromwales said: Errrrr.....compass and a padsaw THEN get pissed Yeah I might hold off on the sauce 'till a bit later! 1
daiking Posted February 15, 2018 Posted February 15, 2018 58 minutes ago, Onoff said: I'm looking at it realising why people duck when they get out of helicopters! @daiking, sounds like you've experience of this. Other than it smelling like a cheap Chinese air rifle what's the score with it? I'm thinking it might be worth sticking a temporary timber batten up between the joists to keep the pilot drill on centre. I found it impossible to get balanced and my cordless drill probably wasn’t up to the task anyway.
Onoff Posted February 15, 2018 Author Posted February 15, 2018 Right then, the Silverline hole cutter IS perfectly usable IF you use something solid to keep the 8mm pilot true. In plasterboard, without it, imo you're on a hiding to nothing. I tried it without then screwed on a bit of scrap 9mm ply. The pilot wobbled so much in the pb to start with it was just ripping and tearing rather than cutting: So with the ply scrap: Happy with that. Wine o'clock! 1
Russell griffiths Posted February 15, 2018 Posted February 15, 2018 (edited) If you drill the centre hole you could probably insert that and turn it by hand if it’s just plasterboard you have to go through. You beat me to it. Well done ? Edited February 15, 2018 by Russell griffiths
Onoff Posted February 15, 2018 Author Posted February 15, 2018 4 minutes ago, Russell griffiths said: If you drill the centre hole you could probably insert that and turn it by hand if it’s just plasterboard you have to go through. You beat me to it. Well done ? This isn't just any old plasterboard, this is...
Construction Channel Posted February 15, 2018 Posted February 15, 2018 3 questions, - where is the hole in the VCL from the pilot hole? -is that a 3 speed makita drill? if so, you lucky bastard, someone stole mine and they are virtually impossible to replace. - how can you sleep at night with so few screws in your ceiling? 1
Onoff Posted February 15, 2018 Author Posted February 15, 2018 40 minutes ago, Construction Channel said: 3 questions, - where is the hole in the VCL from the pilot hole? -is that a 3 speed makita drill? if so, you lucky bastard, someone stole mine and they are virtually impossible to replace. - how can you sleep at night with so few screws in your ceiling? Very stubby drill on this Silverline thing, it pushed up and only just pierced the vcl. Yep, BHP451...I wish I'd bought a couple more tbh. The body dryer comes with some weird "material" straps. Not fitted yet so I added a few more screws. NO I didn't measure them! That was a horrible moment cutting the vcl, OMG the draught! In she goes temporarily: The timber box will be lined with Asbestolux or similar. The rest of the vcl under the dryer will go: A few more screws. A couple of 20mm holes for the control cable and the DRAIN! To fit, the cover. 4 screws but the positions aren't on the card template. I'll figure it tomorrow! 1
Onoff Posted February 15, 2018 Author Posted February 15, 2018 The cover fits to the ceiling with 4 curly wurlys! It doesn't actually screw through the pb and then to the black "fan" deck. So the fan deck just sits there atop the pb under it's own weight so to speak...which is weird. Must read instructions...
Onoff Posted February 17, 2018 Author Posted February 17, 2018 And there was me thinking it would look ugly and obtrusive...
Onoff Posted February 17, 2018 Author Posted February 17, 2018 I screwed up a bit here I SHOULD have cut the vcl BEFORE I drilled / cut the big holes! What I want to do is bring the vcl up the sides of the timber joists and over the top. I'm going to have or course to add some vcl and seal the joins. A fire resistant plasterboard "lid" will then be screwed down maybe on an intumescent bead. It's a nod to putting the integrity of the vcl back. Save me having to buy airtight tape, would Gorilla Tape be OK? It says you can fix paddling pools with it.
Onoff Posted February 17, 2018 Author Posted February 17, 2018 (edited) So let's get rid of the Polypipe tray! Parkside mutitool: Near miss : It's destryoying the foil which'll need some repairs with tape pre whatever new membrane I put on: Time to sit down with a Cobra and take stock... Edited February 17, 2018 by Onoff
Pete Posted February 17, 2018 Posted February 17, 2018 45 minutes ago, Onoff said: So let's get rid of the Polypipe tray! Parkside mutitool: Near miss : It's destryoying the foil which'll need some repairs with tape pre whatever new membrane I put on: Time to sit down with a Cobra and take stock... Please please do not start dismantling it before you have finished it
Jeremy Harris Posted February 17, 2018 Posted February 17, 2018 2 hours ago, Onoff said: Save me having to buy airtight tape, would Gorilla Tape be OK? It says you can fix paddling pools with it. How much airtightness tape do you need? I have part of a roll left over, the expensive Siga stuff, that you could have for free if it might help. 1
Gone West Posted February 17, 2018 Posted February 17, 2018 (edited) 2 hours ago, Onoff said: And there was me thinking it would look ugly and obtrusive... It looks good but how effective will it be? Hot head and wet feet? Mounting it in the floor Marilyn Monroe style might work better, now there's a thought in more ways than one. Edited February 17, 2018 by PeterStarck 1
Onoff Posted February 17, 2018 Author Posted February 17, 2018 32 minutes ago, JSHarris said: How much airtightness tape do you need? I have part of a roll left over, the expensive Siga stuff, that you could have for free if it might help. Thanks. Might take you up on that. I reckon though if I cut and bring the vcl that's there up and over the joist I could add more & set my Asbestolux boards on intumescent mastic. Where the boards meet the plasterboard and the 4 internal corners of the lining.
Jeremy Harris Posted February 17, 2018 Posted February 17, 2018 15 minutes ago, Onoff said: Thanks. Might take you up on that. I reckon though if I cut and bring the vcl that's there up and over the joist I could add more & set my Asbestolux boards on intumescent mastic. Where the boards meet the plasterboard and the 4 internal corners of the lining. Just PM me your address and how long a length you need and I can easily pop it in the post on Monday.
Onoff Posted February 17, 2018 Author Posted February 17, 2018 Bugger! I remember when I laid the PIR that I took so long and walked on it so much that the foil started peeling off. Then the foam itself started laminating / disintegrating. I "saved" it by going mad with the foil tape. Removing the Polypipe panel now and I've made multiple slices into the repaired foil and the foam is literally falling apart even as I vacuum it! I reckon the best way to salvage this is to slip in some squares of heavy duty baking foil and again foil tape. Will the liquid DPM affect the Pex-Al-Pex pipe I wonder?
Jeremy Harris Posted February 17, 2018 Posted February 17, 2018 1 minute ago, Onoff said: Will the liquid DPM affect the Pex-Al-Pex pipe I wonder? It shouldn't do, as it's safe to use in contact with polyethylene DPM, but if you want to be sure then you could test a sample.
Onoff Posted February 17, 2018 Author Posted February 17, 2018 59 minutes ago, PeterStarck said: It looks good but how effective will it be? Hot head and wet feet? Mounting it in the floor Marilyn Monroe style might work better, now there's a thought in more ways than one. I'm banking on this review: Rather than this: If nothing else it'll warm the room up pronto!
Jeremy Harris Posted February 17, 2018 Posted February 17, 2018 Is it really 9 kW? If so then it would really warm the bathroom up quickly, along with the rest of the house!
