keith65 Posted September 4, 2021 Share Posted September 4, 2021 You can get a D4 PVA glue it is just most people use PU glues now as they foam so fill gaps. Link to comment Share on other sites More sharing options...
Adsibob Posted September 4, 2021 Author Share Posted September 4, 2021 44 minutes ago, keith65 said: You can get a D4 PVA glue it is just most people use PU glues now as they foam so fill gaps. Well that is somewhat reassuring as it's possible he just used D4 made by another manufacturer. I'm a little confused by the notion that there are gaps to be filled, because this is brand new chipboard being laid on brand new posi joists, so in theory there will be no gaps. Link to comment Share on other sites More sharing options...
PeterW Posted September 4, 2021 Share Posted September 4, 2021 50 minutes ago, Adsibob said: I'm a little confused by the notion that there are gaps to be filled, because this is brand new chipboard being laid on brand new posi joists, so in theory there will be no gaps. Unless the joists are planed then there will still be rough surfaces to fill. It looks a bit like D4 PVA from the photos 1 Link to comment Share on other sites More sharing options...
Makeitstop Posted September 4, 2021 Share Posted September 4, 2021 7 hours ago, Adsibob said: You are probably right, but my concern is not just that there are no squeaks before floor finish goes down. I want no squeaks for the next 20 to 30 years. That's why I went with a product that has a "lifetime guarantee". I guess my only real option now is to double up on the floor tite screws. Egger also show that one can paint over the joins with their adhesive which appears to protect them from moisture ingress, so maybe we should do that as well. Moisture ingress?... from what and where? To me, that sounds like company marketing bs to get people to spend more cash. There would never be enough moisture in the relative humidity in a well insulated and heated house to cause any concerns over moisture "excess". Even if you spilled an entire bucket os water of a section of floor, I'd bet the subsequent absorption would be so minimal, that it wouldn't be noticeable a week later. On the subject of adhesives used too, the pu stuff has far greater gap filling abilities than pva, so that's where it would have an advantage. Whether that's even "that" necessary is debatable, as with fairly close fitting joints on the boards and once screwed down onto joists, all areas of contact would likely be tight enough to provide good solid service I'd have thought. Of course, the pu is probably better, and would likely be superior in terms of flexibility also. As already pointed out though, if a good mechanical fix is ensured (screwed down well) it's unlikely to go far. 1 Link to comment Share on other sites More sharing options...
Adsibob Posted September 4, 2021 Author Share Posted September 4, 2021 These are all helpful comments, thank you. I agree with @Makeitstop (good name by the way) that the moisure ingress is marketing balony. That's what Egger say on the Egger video advert. But even if it is D4 PVA, it is still missing from a lot of joins and so I've told my builder I'm not happy and we're meeting on Tuesday to discuss. Will update forum on the outcome. Link to comment Share on other sites More sharing options...
keith65 Posted September 5, 2021 Share Posted September 5, 2021 If you read the back of PU glue pot, you would not use it Link to comment Share on other sites More sharing options...
LA3222 Posted September 5, 2021 Share Posted September 5, 2021 Rather than all the guessing, either ask the builder to show you what he used or go looking for rubbish - I'm guessing there is a skip knocking about? 2 Link to comment Share on other sites More sharing options...
joe90 Posted September 5, 2021 Share Posted September 5, 2021 25 minutes ago, keith65 said: If you read the back of PU glue pot, you would not use it Why? ( I don’t have one to read!). Link to comment Share on other sites More sharing options...
Adsibob Posted September 5, 2021 Author Share Posted September 5, 2021 8 minutes ago, joe90 said: Why? ( I don’t have one to read!). I was just thinking that. Link to comment Share on other sites More sharing options...
joe90 Posted September 5, 2021 Share Posted September 5, 2021 1 minute ago, Adsibob said: I was just thinking that. Great minds think alike ? Link to comment Share on other sites More sharing options...
epsilonGreedy Posted September 5, 2021 Share Posted September 5, 2021 10 hours ago, Makeitstop said: Moisture ingress?... from what and where? Some floors are laid before the roof goes on. Later there will be moisture near baths and shower trays. Link to comment Share on other sites More sharing options...
ToughButterCup Posted September 5, 2021 Share Posted September 5, 2021 1 hour ago, keith65 said: If you read the back of PU glue pot, you would not use it I can't read script that small now ... add a dose of pollen to the air ... smudge my glasses a bit ... crack a joke, make me cry with laughter ... functionally blind. ? 1 Link to comment Share on other sites More sharing options...
DragsterDriver Posted September 5, 2021 Share Posted September 5, 2021 It will be everywhere looking from underneath Link to comment Share on other sites More sharing options...
Iceverge Posted September 5, 2021 Share Posted September 5, 2021 A little bit of a long video but Robin makes a nice job of this. https://youtu.be/YB78HiD3mlI Link to comment Share on other sites More sharing options...
Makeitstop Posted September 5, 2021 Share Posted September 5, 2021 2 hours ago, epsilonGreedy said: Some floors are laid before the roof goes on. Later there will be moisture near baths and shower trays. Fair point, but I'd not remotely consider putting any particleboard flooring down before a building was weather tight. I'd also have thought that properly functioning baths and showers manage to keep the water where it should be, and, that they don't share their contents with the flooring. If they were to fail, my concerns would possibly be focussed on other more pressing issues than whether my floor ended up squeaking in future as a result. Link to comment Share on other sites More sharing options...
joe90 Posted September 5, 2021 Share Posted September 5, 2021 1 hour ago, Makeitstop said: but I'd not remotely consider putting any particleboard flooring down before a building was weather tight. With our build the floor (upstairs) went down before the walls were built fir the top floor during the winter. At times water was running down the stairwell but I have to say none of it swelled at all. Perhaps it was because all joints were oozing expanding glue??? Mind even the cut edges around the stairwell didn’t swell either. Link to comment Share on other sites More sharing options...
Nickfromwales Posted September 5, 2021 Share Posted September 5, 2021 5 hours ago, keith65 said: If you read the back of PU glue pot, you would not use it Why? Does it say “Do not use this glue after purchase”? Been using it for decades and I won’t use anything else. D4 PU glue is exceptionally good stuff. If it’s summertime or a spell of bone dry sunny weather, I use a fine mist of water or a wet sponge to prep the to-be-glued surfaces / areas as PU is moisture cure and it behaves completely differently when given the required moisture ( there is of course moisture in the air, but it doesn’t get to the core of the glue so that suffers ‘pockets’, air bubbles that offer nothing in terms of gap filling or purchase ). Regardless, you’d see excess if PU glue had been used. 1 Link to comment Share on other sites More sharing options...
Nickfromwales Posted September 5, 2021 Share Posted September 5, 2021 14 hours ago, Adsibob said: These are all helpful comments, thank you. I agree with @Makeitstop (good name by the way) that the moisure ingress is marketing balony. That's what Egger say on the Egger video advert. No, it’s not. It’s a recommendation for extending the amount of time an installed deck can resist the elements. Specifically aimed at TF’s where the deck boards MUST be installed before the second lift can go on. 1 hour ago, Makeitstop said: Fair point, but I'd not remotely consider putting any particleboard flooring down before a building was weather tight As above. Link to comment Share on other sites More sharing options...
Adsibob Posted September 5, 2021 Author Share Posted September 5, 2021 19 minutes ago, Nickfromwales said: No, it’s not. It’s a recommendation for extending the amount of time an installed deck can resist the elements. Specifically aimed at TF’s where the deck boards MUST be installed before the second lift can go on. As above. Well it's horses for courses. If you need moisture resistance because the site is still exposed, then that's useful. But if not, it's unnecessary. Luckily we have been waterproof for a while now. Link to comment Share on other sites More sharing options...
Dave Jones Posted September 5, 2021 Share Posted September 5, 2021 If it was me, that floor is coming up and pu glue used to put it back down. No debate its done. you will kick yourself forever when the first, followed by second and third squeeks occur when walking over it. Link to comment Share on other sites More sharing options...
saveasteading Posted September 5, 2021 Share Posted September 5, 2021 This foaming glue stuff is news to me. We don't know something until we hear it for the first time so thanks for the update. I have had plenty of occasions insisting on any glue at all, never mind fancy stuff. Looking for a supplier, there doesn't seem to be much of it about. Lots of g4, but without any mention of foaming. Then I see that Egger is £11 for a litre, which does 3 boards!. Hardly surprising that the use of pva continues. Link to comment Share on other sites More sharing options...
joe90 Posted September 5, 2021 Share Posted September 5, 2021 6 minutes ago, saveasteading said: This foaming glue stuff is news to me I used this to glue the lining (osb) to my warm roof to make it airtight, very good as the foaming filled every small nook and cranny and the airtight test was good. I use it on many things now. Link to comment Share on other sites More sharing options...
Dave Jones Posted September 5, 2021 Share Posted September 5, 2021 1 minute ago, joe90 said: I used this to glue the lining (osb) to my warm roof to make it airtight, very good as the foaming filled every small nook and cranny and the airtight test was good. I use it on many things now. without a proper vapour barrier, like Alutrix, it wont be airtight by a long shot. Link to comment Share on other sites More sharing options...
James Newport Posted September 5, 2021 Share Posted September 5, 2021 46 minutes ago, saveasteading said: Looking for a supplier, there doesn't seem to be much of it about. Lots of g4, but without any mention of foaming. It's this kind of stuff https://www.toolstation.com/30-minute-polyurethane-wood-glue/p52489 Link to comment Share on other sites More sharing options...
Dave Jones Posted September 5, 2021 Share Posted September 5, 2021 49 minutes ago, saveasteading said: This foaming glue stuff is news to me. We don't know something until we hear it for the first time so thanks for the update. I have had plenty of occasions insisting on any glue at all, never mind fancy stuff. Looking for a supplier, there doesn't seem to be much of it about. Lots of g4, but without any mention of foaming. Then I see that Egger is £11 for a litre, which does 3 boards!. Hardly surprising that the use of pva continues. a litre does way more than 3 boards. If you read the instructions with the egger protect it tells you exactly what,how much and where to use it. Any non-cowboy chippy would know it also. Link to comment Share on other sites More sharing options...
