Hi,
We are going to build at Graven Hill (not that it matters where), and have received planning, and signed up a TF supplier.
It is time to start focusing on the infrastructure, and all M&E.
I appreciate the Smart Home world is a vast field of knowledge, and opportunities. Whilst I am not looking to build a house that will shave my beard for me, being a fan of all things tech, I would like to make it a fairly smart home that will be up to date for years to come.
My question is what fellow self-builders have considered / installed to date? What gadgets and features do your homes boast?
My wish list goes as the below, but maybe I have not considered something:
- smart lighting for LED / lighting schemes / ambient / likes of Lutron / Creston / Fibaro and likes
- external CCTV
- internal security (quite fixed and NOT open to integration, as it is Verisure, but comes with a handy app that allows a degree of controllability)
- smart heating / like NEST - although quite limited as for the integration with other things smart
- MVHR / ASHP?
- audio in the house / I have done this on a couple of properties so far, but looking for an adaptable system. Been using ceiling speakers and central AV for Main Zone + Zone 2, e.g. Yamaha RX-V677. Whilst I appreciate Sonos gives the Multiroom option, perhaps there is something better?
- Visual in the house. It will be a 4 bed family home, with one central location for TV in the open plan living room. I appreciate this is enough for the two of us (so far) for now, but it may change. I want flexibility NOT to be made to watch CBeebies all day, or in the evening. So, I would gather that all Bedrooms should at least be pre-wired for basic Freeview
- smart blinds / I always loved the idea of them going up when the Sun rises, and going private in the evening. It may be a big ask (financially for sure), but happy to settle on just electric blinds, perhaps controlled via an app?
- smoke and heat sensors from Nest? Just to give the added layer of peace of mind?
Your thoughts as always most welcome!
Bart
Have you listened to this House Planning Help podcast?
https://podcasts.google.com/?feed=aHR0cDovL2hvdXNlcGxhbm5pbmdoZWxwcG9kY2FzdC5saWJzeW4uY29tL3Jzcw&ep=14&episode=YWY4YzFjZTYtNTkwYi00N2E3LWFiNTctNWRhMThjYTg5MDVi
I listened to it a while back and I think it says over 50% of all new builds in Austria are fitted with Loxone.
Not sure of the quantity of new builds per annum in Austria (doubt they have a 300k target) but it shows how much of standard this type of system has become in Europe.
14 hours ago, BartW said:
... Your thoughts as always most welcome!
Stick to the knitting. The house. You are building in a period of significant organisational change. Prices are not stable.
Put plenty of ducting in (with pull throughs) so that you can network anything you're going to need
You should definitely take a look at Loxone. It'll cover pretty much all of your wishlist.
I've sent you a seperate message.
Hey guys,
Apologies for the slack response, and many thanks for your answers.
I will look into the alternatives, and various ways of tackling this.
No doubt, there will be more questions soon!
Bart
A switch where you can isolate all the electronics and have the lights on in the event of system failure etc
im all for automation but you need to factor in when it fails, currently have a building where the BMS failed, waiting on replacement part and engineer to fit- outcome nothing running in automatic
I would integrate heat and smoke into the alarm but not into the systems such as NEST. They are designed to save your life, relying on something that in its own words was “designed to look good as smoke alarms are ugly” is starting from the wrong end of the requirements ... A decent smoke and fire alarm can be integrated into an alarm system - I’m assuming (hoping given the price..!) that Verisure can do this too.
I think about 75% of the tech installed in new houses doesn’t get used. How often do people walk into the lounge and go “Hey Mabel (other voice controlled systems are available), put the lights to romantic and play Barry White...” This sort of thing takes ages to set up and to be honest I expect that the frustration is when you have left something in the lounge, you can’t just walk in and press a single button to turn one light on, then pick up said item and walk out. If I had to programme a scene to allow me to do this then it would rapidly become pointless.
Depending on your heat method (UFH..?) then smart heating becomes reasonably irrelevant as your ability to influence heat input in any sort of real-time impact is negligible. Multi room systems only work when the rooms are isolated - leave a door open and you have just messed with the controls ..! If you want to trigger something such as a post heater in MVHR then an £20 Shelly will do this for you - you don’t need some amazing bespoke app with a complex control system.
I would really look at your use cases for the tech and then decide what you really need - I think you will be surprised at how much isn’t really a need, it’s a want and it will become very expensive.
I've got the NEST smoke alarms, style over substance to be honest. They also keep randomly going off in the middle of the night which frightens the life out of our little ones. I was in the US a few years back and got a ping on my phone that the smoke alarm was going off.. what can you really do about it? Luckily was a false alarm.
Given the choice to install again - I'd go with a standard wired/linked system. No smarts needed there for your average house.
MM.
I have seen the Nest alarms criticised widely.  And note they almost self destruct after 10 years!
SONOS is not much better.
Anyone got a smart fridge?
3D TV?
People just seem to want to spend more time looking at an app on their phones.
Network cable to TV location
Network cable to PC/Xbox location.
have Alexa sitting on top of the microwave in the kitchen when I want to play music while cooking.
that’s my smart technology.
  • Like 3
I went for z wave .
Quote
- external CCTV
Currently running surveillance station off a nas but might change to blu iris
Quote
- MVHR / ASHP?
mvhr should be self activating but I might link the boost to an event
ASHP again fairly self sufficient
Will control the ufh off z wave relays
Quote
Raspberry pi with max2play I.e squeezebox with a stereo single speaker in each room . Works great
Quote
I’m less concerned on this . So freeview , kodi , cat5 to each tv - so options open
Quote
I believe you can get an auto blind opener that sits on the track - I might look into that .
Edited by pocster
- external CCTV
- MVHR / ASHP?
Still a work in progress here but my list:
  • Loxone for all lighting and heating/DHW control (would do alarm too if you wanted)
    • Lots of Loxone RGBW spots
    • Lots of Faradite motion sensors
    • Has Siri integration now :D
    • Can control pretty much everything if I want/ever get around to it...!
  • Unifi for networking and CCTV - absolute no brainer.  I have complete overkill - UDM-Pro, switches and cams - a full comms rack but that's just for my entertainment!  All cameras are CAT6a cabled and PoE from switch, so no batteries and no 230v supplies needed for them.
  • Zehnder Q350 MVHR with LAN Connect option - again a no brainer if you ask me, couple with a proper steel spiral ducting system with attenuators to stop any noise - professionally designed and working brilliantly
  • Sonos for audio, it still is hard to beat - I did mull a number of options including Apple, Loxone or Raspberry Pi with amp pi hats but I already owned a load of Sonos gear and the Sonos ceiling speakers in the kitchen are really good - sub coming soon :D
  • Wiring for future proof - just drop CAT6 in each room, in each corner if you want behind the plasterboard, you can run anything over that and just dig them out later if you need them.  I ran a few but tbh was quite frugal on that front
  • Blinds - I have the Velux Integra windows with the electric blackout blinds and the Velux Active hub which does scheduled open/close for blinds and also full Siri control.  Cost-wise this was much less than anticipated and not much of a premium over standard Velux - each blind is circa £120 I think
  • Nest smoke detectors don't compy with new build building regs AFAIK so I will be replacing my godawful building regs compliant ones with Nest later this year...
Wow! That is some technology to comprehend!
Just in time before the weekend starts. Can’t wait to make some popcorn, and start diving into the world of unknown.
Thank you very much so far Gentle-people!
Bart
I have 5 DAB radios, all tuned to the same station.  Total outlay less than £120.
Works a treat.
I have a 6th radio, that I can take into the garden, and one came with my car.
For catchup, I use my phone.
Works a treat.
Cornish simplicity
9 minutes ago, Onoff said:
What the inventor(s)?
Cause not
Just the weather, not a lot else to do in the rain, except hide down a mine.  Why we improved the Bolton and Watt engine.
  • 3 months later...
Are you integrating MVHR and Loxone?  If so, ho?
At this point not, I don't see a use requirement for myself.  The Q350 increases flow rate when it detects increased humidity (it's enough to boil a pan in the kitchen).
There's a Python module here:
https://github.com/michaelarnauts/comfoconnect
That could be used to integrate if you wanted to.  The reason I want to use that (eventually!) is to pull the stats into InfluxDB rather than control it per se.
  • 8 months later...
Just a dissenting perspective for anyone considering a Loxone route.  You are looking at something like £10K +/- a factor of 2 for this route, and building, configuring and maintaining this type of system will either require a lot of expertise on your part or having to pay pretty high unit-rate Loxone certified engineer time to do this.  Yes, this type of system might be sensible if you want a 100% automated house, but IMO if you are a more typical builder then an approach of only automating stuff where there is a good reason to do so means that you can sensibly look at options which will cost £100s rather than £1000s.
If you have basic IT literacy and any basic programming skills then such more budget route is to use low cost server modules (such as PRi4s) and open-source components such are Home Assistant (HA) and Node RED.  I spent 35 years in the IT industry from engineer through to CTO and there is nothing "cheap and cheerful" about these H/W and S/W components.  The build quality and documentation are absolutely 1st rate.
I use one RPi4 to run control my CH + DHW, another for HA doing general home automation, and a third as a gateway / general Docker host.  I have around 50 Zigbee devices controlled by HA, plus a few Sonoff and Shelley devices running Tasmota and controlled through MQTT.  The CH system has ~20 directly connected sensors and controls 4 directly connected power relays.  This give me precise control of CH, DHW, various lights and external systems, etc. all for around £500.
  • Like 3
We've got a wired Aico setup so pretty much the de facto industry standard - but I tapped into it with a relay base so that the MVHR turns off in the event of fire. Having done this I also figured I might as well be alerted to this event and so a Shelly relay sends me alert too. As to what you can really do about it - good question and something I've always wondered about what I would actually do! We do have network CCTV so I suspect my first action would be view that to see if I could see a fire. If I could then I'd phone the fire brigade, if not and the trigger remained active I think I'd call the neighbour and get them to go and take a look.
Speaking of Shellys, particularly in the context of a cheap way in to 'smart' environment monitoring/protection, I've also got a couple of their flood sensors placed in areas I suspect to be most prone to flooding (e.g. under kitchen sinks) similarly configured to send me an alert should water be detected.
Edited by MJNewton
I like the word passive and keeping things simple, reliable and future proof.  Smart is to much faffing about to get it working (been there, done it, won't bother again) so kept things as simple as possible on this house.
MVHR, once commissioned, don't touch except for maintenance, if the toilet smells hit the boost switch, same for showering or in bath.  Humidity controls work, but not reliably in our climate. No point in automation.
Heating, one thermostat does the whole house.  Although I have an extra in each bedroom to keep temperature lower than rest of house.
CAT 5 cables in each room.
Fire system Aico smoke, CO and heat alarms.
Simple standalone indoor camera in living room.
Manual light switches, they work a treat, silent in operation the lights go off/on when I want.
PIR with manual override on outside lights.
Manual start and temperature control on showers and bath filler, manual toilet flush.
Me to.  I could live with the odd glitch every now and again, but if that glitch took several hours to find and put right, that would piss me off.
