Kelvin
Everything posted by Kelvin
I lapped the external wall membrane back into the reveals and placed DPC on the bottom then the window was mounted, foamed to fill gaps and then silicone to seal around it inside and out. I used Siga Wigluv tape to seal the window to the timber kit. The joiner then built the reveals as part of the cladding install and I’ll seal these eventually too. On the inside you lap your airtight membrane around the reveals and then tape to the internal frame. I used pro clima profil tape. Practice how to make corners for a neat finish.
Water softener discharge options when on septic / sewage treatment?
Kelvin replied to flanagaj's topic in Waste & Sewerage
Do a search on here as this has been discussed before. The general consensus seems to be it’s fine as it’s not a huge amount of brine. I’m fitting one to mine. -
Do £1500 to £2000 /m2 estimates include everything finished?
Kelvin replied to flanagaj's topic in Costing & Estimating
Materials aren’t more expensive in the SE relative to say Scotland. I bought stuff on-line from all over England cheaper than I can get it locally. Local builders merchants trade on convenience and the ability to same day/next day urgent materials. I’d also say labour seems relatively consistent across most parts. The biggest difference is land cost. -
We have two sets of large double Velux rooflights so mounted side by side. This creates bit of complication with every aspect of fitting them including insulating around the frames and airtightness detailing. I’ve dealt with all of that and have now started to look at how to finish the centre. Velux have two ways of doing this. One uses a centre trimmer post which is quite bulky and the other uses a flat trimmer kit which is neater but only comes in white whereas our windows are clear coated. I managed to secure the last two clear coated trimmers posts in the country (I think as you can only get them in white now) however they are very bulky looking. Therefore the options are fit the bulky but matching centre posts I have or fit the neater trimmers and accept they don’t match. I can’t make my mind up which looks best. The first pic shows an off cut of the post in situ.
Shared septic tank on land of house we want to purchase. Any advice?
The whatever reason is likely to be because their sewerage system is now theirs and theirs alone so any problems is on them without relying on other people. They’ve also removed/reduced one considerable difficulty come sale time. Make sure you ask them where they discharge the water from the treatment plant to. -
French doors are a bit more likely to be used than hauling open the bi-folds. We swapped a large impractical balcony door for French doors and glad we did
Nice layout. You’ve left your address on the drawings in case you hadn’t realised.
If you put the post where people are likely drive into to say turnaround or let others past it will get driven into. We had them at our previous place. We had a shared Y shaped drive. We wanted vehicles to use the long branch of the y not the short branch as it passed a house at the bottom of the drive. This was a condition of the planning. The posts got driven into twice. In the end we put on a large very visible planter.
Pretty much our only condition stipulated how the belmouth should be formed. We got a document that showed all the different types with outs highlighted. I asked how to detail the link between me and the road and was told it had to be done to road spec which wasn’t terribly helpful. Subsequently I’ve got a hold of the guys that do all the roads round here and they are happy to complete this for me for not a huge amount of money.
It’s not cheap to get to a weathertight shell which is what he asked. It’s cheap for a full finish. To get to weathertight including groundworks, cladding, standing seam roof, flat roof, fully insulated, 3G windows and 3G rooflights, first fix plumbing and electrical, and 10m x 6.5m garage we are at £1025/m2 . But I agree in that it won’t get any cheaper as labour costs are still rising. Material costs might come down a bit if there’s a downturn. Hence we decided to crack on with it as waiting would have made it unaffordable. -
The garage is connected to the foul pipework.
My SVP comes up through the roof in the detached garage so no penetrations through the house.
TBC nails it above. Sharing anything with neighbours is fine until it isn’t then it can become a pia. Our previous house had a shared catchment tank and associated pump plant, shared visitor parking, shared grounds, shared drive, bin store, shared large brick shed. We managed all this via a mgt committed run by the home owners. It mostly sort of worked but became challenging as we were selling and got worse after we moved. I vowed never to buy another house with shared anything. -
I have both materials so can compare side by side. The plastisol coated steel looks great too but it looks painted by comparison.
I have a neater pile of bricks.
Protecting Timber Windows from Construction Moisture
Kelvin replied to benben5555's topic in Windows & Glazing
Cemfloor recommend windows stay closed for first 24 hours and then open them all afterwards. There will be a lot of moisture. Most people on here will have fitted timber windows with a screed floor. -
I do too but I’ve never owned a microwave.
Loxone switch vs alternatives
Kelvin replied to BartW's topic in Networks, AV, Security & Automation
None of these comments are being very helpful. He’s already decided he’s putting in Loxone home automation. You wanted HA but decided against it. This isn’t a question about whether to do it or not. It’s a question about how to control it once the decision has been made to install it. First thing to consider is to reduce the total number of switches. I had far too many to start with. You then buy the dearer switches where they are in visible circulating parts of the house. The cheaper touch switches in the other rooms where you want to control multiple devices but are less used. Retractive switches elsewhere. The fact they are different matters less if they aren’t beside each other. -
Having stayed in a few houses with MVHR the first thing you notice is how pleasant the atmosphere is. Cool and fresh. We are still building our house obviously but as I’ve been going around sealing the house up I’ve noticed how stuffy it’s quickly become. Cross ventilation is easy in our house given the way it’s laid out however if I were to rely solely on opening windows I’d spend my days running around opening and closing them due to the rain unless you automated that. If you go out for the day and shut the house up doesn’t it become a bit stuffy again? Ours does but it is still drying out.
