Kelvin
Everything posted by Kelvin
I got the same 32 page style report and mostly ignored it. I took some of the dimensions from it and plugged it into the Jeremy Harris heat loss calculator on here which gets you close enough. The as designed tends to err on the side of caution ad they expect to better it as built. In my case it was the cautious as designed ACH target of 3 they quoted me as they know they’ll beat it. I very much doubt they are claiming to achieve 0.3? They are setting themselves up to fail that. Are you reading it correctly?
Leaky “new” roof might be the last straw
Kelvin replied to Adsibob's topic in Roofing, Tiling & Slating
How easy is it going to be to investigate it? One of the best tools I’ve bought is a non-destructive moisture meter. I’ve found it very useful at mostly putting my mind at ease. It might help you trace the problem. They do throw up false positives (screws/nails) -
It’s a new house just at the first fix stage. Screed was poured a few weeks ago. There was a lot of moisture in the air but we kept it well ventilated after the initial 24 hours. If rained a fair bit yesterday after I cut the foam out and there was no evidence if water ingress. We are a while away from plaster boarding so will leave it open and see how it goes. I’ll try and pour water over the window and cladding to see if any comes in. I’m now pretty confident it’s not rainwater though as there would be a lot more off it given the heavy rain we’ve had. If it is condensation, and I’m confident it is, I assume it will be fine when re-foamed and fully sealed airtight?
Yes it seems like interstitial condensation because it wasn’t done very well allowing the warm moist air to permeate the insulation and hit the cold surface of the cladding. We are a few months away from hooking up the MVHR unit. It happened very quickly though as they only applied the foam this morning.
Ok so if it isn’t leaking (as far as I can see) and it’s not coming from the foam itself then it must be condensation which seems rather odd in itself. The house is very warm and it felt quite humid today. I might strip the foam from one of the other windows and see if it’s the same.
It’s as a consequence of a Heb Homes balls up that didn’t leave enough space to get rigid insulation in.
The builder was back today final sealing the Velux windows. I noticed he’d done a poor job of one of them so I removed the foam and noticed it was wet behind it up against the external flashing. I figured he’d sprayed water to help it cure however I didn’t recall him having anything with him to do that. Just called him and he said he didn’t so where has the water come from? It’s been hammering down all day today and been very wet on and off for weeks. If water was leaking in there would be evidence of it somewhere as eventually it would drip in somewhere. I can’t see any obvious water marks and I can’t see anywhere that it might be running inside the building. I’ve gone around the area with the moisture meter and no indication that anything behind the structure is wet. Does expanding foam produce moisture as it cures? I’ve not seen any evidence of that when I’ve used it but then I always spray some water. Could it be condensation forming on the back of the flashing after the expanding foam was injected to fill the gap?
Joining flexible ducting
Kelvin replied to richo106's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It’s what I did using a similar type of coupler. I’ve not taped it up yet though. Job for tomorrow. -
Hello experts- looking to be enlightened :)
Kelvin replied to rcast1989's topic in Introduce Yourself
Most decent joiners will be able to stick build. It just means the timber frame is built on-site rather than built as panels in a factory then brought to site. Stick built will likely be cheaper to build and it’s safer for you financially. A lot of joiners can also do contract builds by bringing in trades to do the bits they don’t do. The joiner I’m using does this for example although I have actually done all of that in my case. -
SNP plans to ban sales of house with gas boilers
Kelvin replied to Temp's topic in General Self Build & DIY Discussion
The rising energy costs have made people more aware of their energy usage so they might well start to look at the EPC rating of houses as key metric in their buying decisions. The market itself might therefore determine the value of the property based on the EPC rating. The days of cheap energy are likely behind us. -
Completely agree. In our previous house the DHW tank, diverter valves, and main circulation pump were all in a big cupboard outside our bedroom door. Not specifically noisy but everything is noisy in the dead of night. This time everything is in a plant room in a separate part of the house. It does back onto the study which might eventually become a bedroom which isn’t ideal but it will only have occasional use. We have no pipework routed within our bedroom other than the MVHR ducting to the living room but that is under the floor of the coom wall that runs through the bedroom.
And there are ARB registered architect firms that can’t send you a single document that doesn’t have an error in it, well other than the contract and the invoices.
When you climb up something to look at the view you don’t just look at the one spot you take in the whole vista by changing your perspective. We are 260m or so above sea level with the valley stretching out below us to the hills in the distance. The view is completely uninterrupted. We can see each end of the hill range which is some 13km end to end. The weather rolls up the valley before hitting the town and turning towards us. We can see it coming for some 30 minutes. It’s mesmerising watching it. Very often there’s a mist that hangs low over the valley and we are looking down on top of it. It’s beautiful. While we can’t quite see the sun rise we do see it from very early and watch it traverse the sky before setting right in the middle of our large picture window behind some trees. We could have put a sliding door and removed the other three large windows but we would lose that whole view so consequently the whole wall is pretty much glass. Arguably we could just stand outside I guess. The big full height windows also let in a lot more light.
I’m sure it doesn’t help. However if you have a nice view you might as well take advantage of it. The alternative is project the live view onto the wall and just have a hidden door. Get the same view with none of the compromise of a window.
11.5 man days to fit windows and carry out some snagging? How many windows?
Matching decking and cladding OR using decking as cladding?
Kelvin replied to phatboy's topic in General Construction Issues
We are doing Scottish Larch board on board cladding and thermopine decking. We’ve had the same debate about which way to run the decking. Haven’t decided yet. -
First thing I checked after reading about it on here
I want it replaced. Given all the shit I have had to sort out because of their incompetence I’m not accepting something that could be fixed.
Having looking into this more the 1 Home bridge only integrates to assistants like Alexa rather integrating one HA system with another so doubt it fixes the problem. I have bought a second hand Mobotix T25 video doorbell which you can connect to Loxone.
If the Reolink doorbell supports RTSP this might solve the problem of integrating it with Loxone as well as other cameras. https://www.1home.io/integrations/loxone-amazon-alexa-monocle-rtsp-rtp-ip-cameras/
I live on a farm that has a large well workshop I’m allowed to use. It’s like stepping back 50 years.
There’s been a few folk visit today. Two spotted it without me saying anything and the other two spotted it after I told there was an issue with a window see if you can find it. I have the incorrect 2G unit here and we stood it up against the wall and it’s the same blue tint as the others. It came from the main Nordan window supplier that supplies the factory.
Sharpening my chains is one of my favourite chores. 😂
Pretty much my approach with every problem 😂
