saveasteading
    94
  1. So the hopper may be acting as a breather pipe. No windows near? so no problem.
  2. Assuming the toilet waste pipes just disappear into the floor and it all works ok? What are the 2 pipes in the picture, into the hopper, draining?
  3. Really the only way to control this solar gain properly is with shutters or other shades outside. In theory internal blinds and curtains don't work especially well as the sunlight has already entered the room. In practice of course they do work especially if you can use light colour to reflect some light back out, and enclose the space between glass and blind, so that some of the built up heat goes out, or at least stays there. The other solution that avoids air con cooling is simple ventilation. as long as it is cooler outside the temperature will be reduced. Air-con cooling shouldn't be necessary in Glasgow, and perhaps you can reduce the problem, and cost, these other ways.
  4. Door locks are tricky and need decent tools as well as the knowledge. The knowledge is on youtube. But the first time will still be trcky. The tools are in the shops. For a one-off, I recommend getting a joiner.
  5. That pic was from screwfix today . I used one about 4 years ago, because previous owners had left the chimney sitting on the ceiling. ie just removed up to the attic, and a new patch of ceiling in its place and a couple of wedges under the bricks. Building Inspector fine with it, but perhaps as changed. I think if the Engineer says that is ok then is ok. Best to leave the chimney breast in I say, and put some flowers or wine rack in the fireplace.
  6. All very useful, and the test seem sensible enough. 1. I read that the second test requires a flow meter inside the flue. That can't be easy, esp as diy. 2. Have a superb wood burner in Spain that is available in UK, and am considering using in our Hieland hoose. But it has doubled in price on the way. Same model, E500 or £900. 3. In a new house there will be no air coming in to feed the fire unless we open the door, so a vent seems sensible anyway. I am thinking of bringing a pipe in from some distance and underground so that the air is prewarmed, then having a shuttered grille on it. I have no idea if there is a limit to the length of the pipe, or how quickly the heat from the ground will be lost and it becomes a waste of effort.
  7. The chimney usually has to stay as it is an important element in supporting the building. If taking out a section, then the remainder above has to be supported. This is a standard procedure and there are special brackets to fix to support the brickwork above, It absolutely needs an Engineer, Building Control, and a decent builder (general, or bricklaying should do)
  8. Making it dry and even warm, ie into a proper room would be expensive. If that is the worst it gets then you are lucky, and perhaps you can live with it. A small sump and an automatic pump (£100 incl pipes) will probably suffice if you want rid of it. Let's hope that forming the sump doesn't break a barrier and cause more water ingress. Unlikely but take it slowly But first, check if any outside pipes or surfaces are casting water in the direction of this wall. If so, change that as the priority.
  9. Last time I wanted this, B and Q did it without a cutting charge. That size would go on the bus.
  10. There is a wonderful product for this but it can be very expensive. I obtained some flood damaged material from the manufacturer and used it very successfully. Could not hear a sound from next door with baby, and the neighbours got the same benefit. Lead vinyl sheet, in roll form. The same as is used on radiologists' aprons and the flaps at luggage scanning. Hang it loose from ceiling to floor before building the stud and plasterboard and the density combined with looseness appears to kill all known sounds. We didn't attempt to seal it at the joints. What it costs I don't know, but they were considering selling for floor covering in flats, so perhaps not too bad. My contact doesn't appear to have a web presence. I see it by googling lead vinyl sheet. Got one huge price and several POA. Over to you if interested.
  11. Did the neighbour modify the exiting planning permission or submit a new proposal? If the former, then that is effectively the project done. If the latter then the original permission is scuppered as no longer possible. (If he just built something different then he has a potential problem.) In either case it is possible to submit for a building on the now remaining land, as often as they like. Your argument will always be that the original permission was based on the specifics, which now cannot apply. However, a different officer might not agree with the previous ones who rejected the schemes, and you must make the same arguments every time, but now with precedents of previous rejections and the reasons.
  12. Thanks. all useful. re local builders' merchants. For general info to reader about to start the journey.. I always try very hard to support the locals but it is hard work, and sometimes the prices are silly. It was explained to me by a family BM client, (who did not insist that we bought the materials from him!) Even the national companies buy in from other suppliers. eg timber from a timber mill/merchant, insulation from one of the nationals. You would think they could get it direct from the big manufacturers but it seems to be more of a closed shop than that. So for a very specialised material it is best from a specialised merchant. The local BM will usually specialise in one trade eg roofing, and they need to be competitive in that, and for small and mixed orders the convenience has a value. Also I understand that the little builder often has little buying power but needs a credit account for cash-flow. Hence an account at the nearest merchant is convenient, and the prices may not be the best, even with the standard 10% off. The BM cannot offer different rates to different customers. Another tip for those starting out in buying. Never mention a trade name for a product. If you ask for 'Celotex or similar' then Celotex is what will have the best price. If you ask for PIR insulation you will nearly always get a better quote using a less well known producer. They quote a figure and you wait, and a discount appears. Once I was quoted for 1,000m2 of insulation at 20% discount which became 75% in a few minutes. Ask the local BM if they want to match a price. They won't be embarrassed and sometimes it will work for both parties. Never be embarrassed to ask for a better price. Think what even 5% off a £400,000 project is worth. £20,000 just for asking every time. Now double it, and think that way throughout. In every big contractor's hq there are people called 'buyers' and that is all they do as it is a skill.
  13. I see houses. The easy research is by speaking to the neighbours and asking where their water/elec comes from and where the drains go. if they aren't available or don't know. then walk up and down the road looking for iron or concrete covers for these services, and also cables flying in from elec and telephone. the adjacent filed is worth perhaps £10k an acre so logically is not expensive to buy a bit, and solve the drainage problem. But farmers don't like to part with land. If the field owner is the vendor then a small area might ease the sale, esp if explained that this is the only solution and anyone would want the same. Or wayleave as above mentioned. Soakaways must be 5m from a building and from a boundary, which sounds tight but might just work. If the field owner agrees formally then it can go nearer. That is where all the rain is going already, down the slope to the puddle. This is one of the easier tests. With figures you could press the point of needing land for soakaways or even a pond, which is often the best solution. For a quick test i wouldn't do the 2m hole first, but just dig the little hole below topsoil. It will be a decent indicator.
  14. Don't tell us where it is, as these discussions come up in google searches. But can you indicate by words or sketch what size the site is and the topography?
  15. Not necessarily at this early stage. Your lawyer knows what to ask and can make it conditional, and you can ask in principle to the agent if that will be acceptable How to judge the poss costs to you though, and allow in your offer is another matter. I know about these things and still get it wrong. Best estimate and a contingency. if you have the patience, you will eventually find someone at the water and electric companies who will help with the basics. formal enquiries don't cost a lot. Are there any important constraints in the OPP?
  16. This is normal enough and is likely to be acceptable to the vendor. Your lawyer must advise though, not us. The only people who might not be cautious on this would soon be advised by their lawyers. ProDave's points must be examined urgently too, but can be in parallel with the legals and planning. Some of these have high potential costs and others can be deal breakers. My recent experience has been that vendors underplay the problems, and end up not selling. Then they continue to underplay these issues in the hope of a mug turning up. Your lawyer can ask these questions if the agent isn't being forthcoming, but you must check them out yourself To concentrate your mind: 1. You cannot build housing on badly contaminated land. (oil , asbestos, chemicals. Site cleaning is not a commercial option. ..deal breaker,....survey needed at a cost. 2. Cost between zero and many thousands depending on availability. You should not be dependent on the neighbour, but ask for permission to use it until own supply is in. 3. Is there power already? Allow £2k to take it back to site supply then later reconnect. If not then could be £5k to £20k. 4. If mains available (downhill!) then a drain run costing some thousands. If not then a minimum of £4k for pipes and treatment, rising a lot if the land doesn't suit. In worst case there is a small waterlogged site and it is impossible without storing and removal ....Thousands per annum. Get asking these questions right away. When they don't answer, (claiming not to know) they are probably concealing something. If they do answer, it might be true but check it out. You can also ask if there have been previous offers, now withdrawn and why? But let's hope all is good and none of these are problems...but there will still be costs. As an absolute minimum : 1-4 above will cost minimum zero + £500 + £2,000 + £3,000 I would guess. Plus any consultants you need to check these out. I have to say our Scottish lawyer was great and did not charge for these questions and issues on a site that fell through (for just these sort of reasons). She said this happens all the time, and it would be better for sellers to do these researches themselves.
  17. Hear hear. Yes we are all here to learn so do tell: Although it looks wonderful and you must be very pleased, there must be something you learnt or would do differently. Design or process.
  18. Planners look on each application on its merits. I think your argument here might be that the recent new dwelling was based on the original permission which was founded on sustainable design principles. That the owner should then build less is up to them. If they wish to continue with the original permission then it should not deviate from that original permission, at least in principle. However the owners are entitled to submit as many applications as they like. If this matters sufficiently to you, then perhaps have a word with a local planning consultant. They know the clauses backwards (better than the planning officers usually) and the local precedents. There would be a significant cost (a few hundred for a preliminary discussion and a few for a formal objection.) On what grounds was this refused, as this is likely to be a useful start for your objection? If you don't object in principle to more development, but to the nature of it, it is worth making that clear.
  19. A farmer struggles to sell fleeces at £1. This bag of insulation costs £40. If we could just clean the fleeces and square them up it would be a massive benefit to our farmers and to the world (oh, and to our build costs)
  20. Also 'lost' in the building: At what stage does graffiti become history? It has always been a delight to come across the proud script under a floor board of a joiner who built the floor 150 years ago, or a lad from the village making his mark in a barn, or the farm-hands writing each years sheep numbers up on the handy barn door. Or a newspaper under the stair. Must remember to place a time capsule in our project. But what will be interesting in 100 years?
  21. To help the window cleaner to survive, a strategy would be good. I think I would favour access through an opening skylight. Next choice is one ladder onto the lower flat roof (with a tie position permanently fixed at the eaves) then an additional ladder from there to the main roof (tied at the top, and a good idea to have a fixed block at the bottom too. That way each ladder is relatively short.
  22. Does anyone know the approximate rate of water flow through a rad system? It appears to me that the circulation on a loop is about 10 minutes when cold and all rads open for flow.. So normal pipes are not limiting the flow too much.
  23. Are we doing puns now?
  24. Well, you can't do that can you? However the epc could be encapsulated and fixed in the plant room/next to the fuse box, and it could also say that Ferdinand built this lovely house in 2021 and gave a full maintenance manual to the owner. I tried this for a while, by summarising on an encapsulated A4, the building construction, eg the bricks are marley sussex, the tiles are redland xyz, and the insulation is 200 thick abc. the metal cladding came from..etc. and the epc is B+ . The client was not interested but did not object either. You can also direct the owner to the safety and maintenance manual which is both helpful to them, and there as a protection against future claims. Should have done it more often. Then maintenance manuals became compulsory and no need for the little notice.
  25. The pro's prefer the expensive stuff generally. Whether £20 or £200 for 5 litres it still takes a lot of labour. and the better paint lasts as least twice as long.
