saveasteading
    94
  1. Also, some sounds are more annoying than others. A distant motorway sound just like a waterfall. There will be a big difference in keeping out all traffic noise, as opposed to occasional big lorries/ sirens etc.
  2. I think you have all the comments you need here now. What I would pick from them is. 1. tell them "I have done some homework and am concerned about the sand blinding. Show me something to confirm that your statement is correct, that this is a recommended procedure." 2. dpc, "likewise show me proof of what you think is an acceptable distance from new paving to dpc". 3. stop work and payment until you have done this. Where to find proof? Suppliers of paving products, Marshalls being an obvious one. for block paviours they will show a sand bed, but I think it is unlikely to be appropriate for slabs. However I can't see anything useful from them, but did find this. https://www.paving.org/index.php/how-to-lay-paving-slabs/
  3. I would be more inclined to leave the PIR as it is bought and the hard work done, but then batten out twice to put in a layer of mineral wool, an air gap then a layer of any plasterboard. I don't think it needs acoustic seals as you have created a very long path for airborne sound. The shortcut might be by vibration through the roof via the rafters, so your resilient bar might be a useful insurance to break the contact to the pb. Is the noise high or low pitched, air-borne or including vibration?
  4. I think they told me about £400/m3 plus 30p/m. Also that the logs were usually cut a year previously and kiln drying is then not standard or necessary..
  5. Do it soon as fading starts immediately. At least the south facing as a priority. I would give it a month of dry weather to move and shrink, otherwise there will be some gaps at joints. I'm assuming this is straight from the mill and not kiln dried, and even that shrinks in my experience. I didn't get any suggestion of any discount from that supplier, but their usp is any timber size to order.
  6. Because they are charging what they can, quite reasonably. I went to a small mill and they gave me a m3 price, but fairly said I would get standard timber cheaper at the merchants. JohnMo, that is beautiful. Are you letting it fade to dull grey, or staining it to keep the colour?
  7. Until you have tried to lay stone to a level it sounds easy. The sharp sand is similar cost to the stone and much easier to lay, so saves labour. This will work fine for a number of years then will fail, and when that starts it continues. The guarantee, I guarantee, will be worthless as it will take you £1,000 of legals to get £500 of repair done. Unless thy of course the contractor admits a problem and just does it for you with a smile. be sure that they do proper pointing with wet mortar and don't just brush in a dry mix and assure you this is the best way. If they do this properly it will allow the rain to run off the edge and away, rather than through the sand. It is on a slope isn't it?
  8. Can you ask them to show you any drawing or written spec that confirms their proposal? A lot of people on here will be surprised if they can.
  9. I think the timber price is steady now, perhaps discounts becoming slowly available, and will drop a little more.
  10. No problem: the discussion has grown towards general theory. Ask your supplier how they avoid shrinkage cracks at box-outs. Perhaps it doesn't shrink? Or they add fibre?
  11. Recently Scotland has brought in mandatory, linked smoke alarms for every house, old or new. As most will be retrofit, there will be a very big market for wireless, so it will be interesting to see if the market develops.
  12. It is standard in laying big concrete slabs, but must have a dpm above it. 1. it makes the slab a consistent thickness and therefore controllable 2. it provides a sliding layer for shrinkage 3. it is cheaper than concrete. The problems come when it is much too thick, as it isn't compacted well, and then gets footprints in it which may remain as voids under the dpm and cannot help crack control.
  13. Yes. And tied with wire to the mesh, so that it stays tight to the mesh, and doesn't get displaced or even lost. This is really important to avoid big cracks from a corner to the nearest edge.
  14. Can I ask why this needs waterproofing? Unless it is a basement or has a retaining wall element the only water should be dampness, not running water with any pressure. For dampness, an inner liner might be ok, but it will be forced off with any sort of pressure from outside, in which case the liner should be outside.
  15. OK I do really know about this. Must have specified/supervised for tens of thousands of these, on mostly very big, but some small, columns. Gus and others are mostly right, but my opinions are based on the difference between theory and practice. You perhaps don't need the theory so here is my suggestion. For a small column, as this is, pour the concrete base solid with no bolts, to 20mm below the base plate level. Make sure the Engineer and/or steel fabricator have not already allowed for this with a shorter column. (That would be clever of them but a nuisance if you do it too). Check the column length on site too, as fabricators have been known to cut the measured length then add the plate. Then you can mark the bolt positions absolutely precisely and drill/ stud/ epoxy. (quality important, see the instructions, and supervise the work) For shims use square fence washers, 3mm thick so you are never more than 1mm out. They will squeeze down a bit when the nuts are tightened. OR (my choice) set spare nuts on the stud to the plate level. Then there is nothing in the way of the grout. Grout up using a stiff dryish mortar mix. Use small size ballast if you can get it, otherwise sharp sand. push under and ram it hard to refusal, so you need a back stop board. Flaunch to vertical or 45 degrees. Why not use expanding grout? Because they tend to assume it is magic and leave it well short of the plate and with gaps in it. Use it if you like but still supervise.
  16. Yes be concerned. I think this is just easier to lay flat than stone. It can't really be rolled or whacked hard either. The problem I see is of rain running through the joints (perhaps in 2 to 3 years, and washing away the sand. As suggested above, if it has enough cement in it then it will be ok. but I think this is just to suit themselves as it is difficult to impossible to lay stone exactly within a few mm..
  17. I would make a real hash of that using a hacksaw, but perhaps a more skilled person would not. Tin snips are very tricky and would not be very straight, but that is what a skilled metal-worker person would most likely do on site, using all three left, right and straight-cut snips. I would probably try a chop saw, assuming there is a metal blade available for it, and first put a timber stiffener into the section to stop it deflecting during cutting. I think that is basically what a window manufacturer would use, albeit on thicker metal.
  18. Because it doesn't burn there, and the only other option is polystyrene. There are signs that PIR costs have steadied. Locals advertising leftovers are not asking for list price (or higher). I am wondering if my post above would better be in a new post, rather than attached to the Grenfell discussion.
  19. Yes, uploading the application today. PIR under the floor, where we only have 100mm available in some places because of existing floor and lintel levels, but will put as much as we can in where levels allow. That is all though, elsewhere will be mineral wool, plus lots of cavities for damp and services, and supplemented by wood-fibre board where we don't reach the targets. Although we only have to reach 'reasonably practicable' insulation , we have hit the target using 'area weighting'. and all areas are close in themselves. I had originally misread the standards, and thought we were a long way inside the target, but for a cold unoccupied building the targets are close to new-build. We would have aimed for this anyway. In calculating the wall effect, 600mm granite, I have used the figure the Scottish Government suggest for assessing old buildings, based on real tests, and that helps a lot*. Have also taken the advice on not ventilating the air-gap between wall and new internal stud, as that would suck out all the heat. so have allowed a compressed mineral wool seal at the head of the wall, closing the gap to the roof void. I don't know any figures but expect that our single-sized sand ground will also perform much better than 'normal' ground. It will be utterly dry. This will partly help in the heat loss through the ground due to the outer walls all being so close together. * Studies show that the central core being over 40% mortar helps a lot, so the granite does not absorb water and thus does not lose heat in wind drying. The mortar gets a bit damp but it migrates down. The bottom metre is damp all year, but of course is the central bit again. We are showing a hyload bitumen sheet to the inside bottom metre of the wall, to keep the damp out, and then hoping to resist any BCO suggestion to ventilate the void to let all the heat out.
  20. It doesn't help that there are class O and class 0 ratings (that is Oh and zero). I have been at a furnace test, and don't doubt the integrity of the test labs. My main memory was of how hot it was on the safe side of the furnace, before it was deemed to have failed. But I learned on a fire engineering course (implied not stated) that the labs can only test what is sent to them, and to the level that is requested. Hence a 1/2 hour rated ceiling with no tile clips might well pass a 1 hour test, but wasn't tested to that level... (I guess the manufacturer instructs that the test is terminated after 1/2 hour) Then the test with clips is done to show a 1 hour pass.
  21. I too have tested very small bits of insulation on a fire. I justify this as being best for the planet overall....a few fumes and a lot of knowledge. Polystyrene burns and melts and drips and spreads Polyurethane , whichever letters, was similar. (presumably I have not seen the more resistant one) PIR burned but went out when the heat source was removed. then burned to nothing when back in....lots of black smoke. Fibreglass makes a little smoke (from the glue?) and turns to sand mineral wool , the light insulation type, as for fibreglass mineral wool as fire barrier just sits in the fire. sheeps' wool, stinks and somehow disappears but doesn't burn as such. mdf/cellulose board....not tested
  22. Thanks ADLIan . Would it have been PU that was a previous issue, and PUR is more fire resistant?
  23. Hi, welcome. You get about 10% at most off the warrant application fee if you use certified designers. Our project is being submitted this week, is by a Chartered Engineer (me) and Chartered Architect, but not registered in the system as working in England. It would have cost about £2,000 each and a lot of effort to get on the registry. I will report on how it goes. If I was the building inspector I would look at the qualifications, at a few details to spot check information and design knowledge, and approve it. But they are entitled to send it out to as many consultants to check as they like. I did I don't have any problems with being checked, but it takes time, and there is always more than one way to do something. I did 3 projects in Scotland but before the registry , and it was much more a matter of trust than in England. The local builders say they have seldom seen a BCO. That is understandable in Highland Region as they could be on the road 95% of the time due to distances. Some on Buildhub say that they simply send reports and photos, which the BCO may or may not look at. I guess it mostly comes down to trust and confidence. It is that in England too, where perhaps 5 visits cover the project and it isn't by spot-check but invitation. So you will save 'much time and effort' mostly by having a good design. If you are not a building designer then you need someone who is, as the BCO only checks bits and pieces, and doesn't do the design for you. Cross fingers for us please, and good luck for your project.
  24. Non-scientifically: The samples I have seen look very different. PUR looks like the white foam you see in packaging for delivery protection. PIR looks like a denser 'Crunchy' bar. I recall having a client's insurer panicking about 20 years ago, because there had been nasty fires where PUR was blamed. If I remember correctly, it drips as it burns, and so spreads fire quickly. It was then withdrawn from use in commercial composite steel panels, although still used in agricultural sheds. I have been involved in picking up the pieces in 2 fires. one was made much worse by polystyrene insulation in the roof, from a very different era. the other was a nasty fire on the outside face one of our own completed steel buildings: arson/vandals setting fire to a huge pile of bagged sawdust stacked against the metal wall. The paint on the steel cladding was burnt off, and the fibreglass cavity turned to sand. The screw fixings lost their heads and washers but stayed fixed. There was no structural damage or distortion. So I had the chance to discuss with the fire officer. He was amazed that the wall stood up to the heat and delighted that the insulation just disappeared. He said they were ready for the fire to enter the building. I told him it was designed as a fire barrier wall, (fibreglass to stay in place 15 minutes before failing) but his opinion was that they seldom worked so this was great. Went on to discuss PIR filled composite cladding. Off the record they hated it and were scared of it falling off the walls, so they never went near it. So, I think the fire service knew of problems with PIR but couldn't prevent its use. I asked if I could quote how impressed they were with our wall, and he said no: they are not allowed to comment on commercial products. If we had used rock-wool instead of fibreglass I wonder how it would have performed. Not as much difference as is implied I feel, unless it was the special fire resisting variety. Grenfell: I recall reading that the sample sent for fire testing had an added sheet of cement board that was never made part of the product. That would make it manufacturer specific. the other manufacturers' products would have behaved in the same way, but had not made the same claim. How to stop it happening again? Nobody was in overall charge. The old position of Borough Engineer would have been that person, but there was none such. Would they have spotted the problem? Probably yes I would say, as they would have had the authority to have it all designed and proven, and not changed without approval from the top. But the other parties would have complained about bureaucracy and interference. Anyway, there is no such role any longer as accountants and 'executives' took control of the councils.
  25. Piling is favourite. Don't hesitate to contact several companies as they have different kit, processes and overheads. I would phone and ask for their Estimator or Sales Engineer, who might be the same person. If it really doesn't suit them they will likely give you another suggestion. Also there are driven precast, driven in-situ, bored in-situ, and gravel piles to consider. If other neighbours wanted the same at the same time, then it could help the cost a great deal, in the arriving ('mobilising') and tidying up costs. Watch for the exclusions. They will want and need good access, hard standings, water, and someone else to clear up the leftover concrete. then you have to cut back the heads of the concrete too. If I had to guess I would say the best value will be from either a small, local piling contractor, or a driven pre-cast specialist. Precast can include tidying the tops off and installing beams to your plan, and I would suggest getting a price for that.
