Beefy ridge beam check and plan to reduce size
saveasteading replied to NandM's topic in RSJs, Lintels & Steelwork
Yes. At a certain chunkiness they don't need any (or partial) protection. The one here for example is unlikely to need any. There is no occupation above it. At 300+ degrees it will soften a bit. @NandM Re the splice, and the rest, Russell is right. Ask the supplier for 2 options, in case it happens to suit manufacture or delivery costs (small lorry) But lift it in one piece. If the builder hasn't seen beams this heavy, he either hasn't much experience of beams....or some cash and no regulations clients have unstable houses. Either way, discuss the proposed method for lifting and fixing it.....a 'risk assessment'. -
A pump drain ouulet is very easy as you don't need to keep to precise lines and levels. Usually the suppliers of pumps want to install them. But it is easy stuff. Obv the pipes in to it have to be to falls. I assume you need a day's storage volume in case of power cuts. When you install? I can't say, as you know the site.
Good question. The building regs may imply yes. The reality is it won't burn down until the rest is already gone. -
An advantage is that builders are not much interested. They will have to improve it to building reg standards, you don't So you have a price advantage unless another diyer wants it a lot. I say be pragmatic. Do what is cost effective.
It's a very long span taking a lot of load. It looks right to me . The weight would reduce if you used a deeper beam (perhaps about 450 or 500 deep) instead of that chunky section. But deeper will likely interfere with your headroom/ aesthetics. -
Is the ceiling beneath finished?
- 45 replies
- suspended floor
- ufh
So demo yes you will be waiting a long time for a rebate. But if you use a vat registered company you are only paying them 5%. Landscaping you might choose to buy the plants in and heel them into the ground short term, and get the claim in. Make sure all your landscaping/ fencing etc. is part of the planning permission.
These are good suggestions. Bug any size of tile is stiff once grouted up. Perhaps the grout will break instead of the tiles. Carpet, or vinyl. OR get it independently assessed and the builder to sort it. I don't think it is as spec. You quote an 'architects spec'. Is there an architect?
- 45 replies
- suspended floor
- ufh
Sorry i don't know what that means. I can't see hangers. Are these just nailed into the wall plate?
- 45 replies
- suspended floor
- ufh
Photos are great. The noggins need to be more central or another row of them. But i suspect that isn't the main issue.
- 45 replies
- suspended floor
- ufh
Joists are designed for collapse and acceptable deflection ( 1 in 360 I think). Deflection is always the critical factor in domestic use. If the joists are the right size, and noggined, then they won't be budging. It must be the boards deflecting between joists. Have you tried bouncing on them at different positions, ie on or between joists? Near the wall the joists won't budge at all.
- 45 replies
- suspended floor
- ufh
New homes boarded up in Cornish village in planning row
saveasteading replied to Alan Ambrose's topic in Housing Politics
But that is not the case. Only a story spun by the developers and lapped up by certain of the press.* They know what they have to do, including 10% affordable or whatever (which is nearly always much more cheaply built anyway.. Then they pay too much for the land. They don't lose money on the affordables or subsidise them....just perhaps make less than planned on the overall project. Then they ask to reduce their obligations knowing that the planners don't understand money. Do they lose money? Normally no. We don't get to see the figures anyway. If they paid less for the land then it all works out...apart from the landowner getting 5% less of a windfall. £950k an acre instead of £1M for £10k farm land. Fairer I would say than being subsidised by rates or tax. Whatever, they will sell the finished houses for as much as possible and won't donate any surplus for council houses. *mixed metaphors. Sorry. -
I assure you it isn't rubbish. I wonder at your certainty and out-spokeness. Maybe you went on a different Fire Engineering course. But I'm not saying that any of us, even with expertise, should veer off the white book and equivalents.
Practical experience of ceiling acoustic performance sought
saveasteading replied to dnb's topic in Plastering & Rendering
I'll have a think about that. -
That's the difference between lab test and reality. Lab test is a fire breaking through a construction that has been presented to meet a minimum requirement. I've met the experts who told me that the tests cease at the pass time even if still robust. Also that timber stud does not fail at exposed studs, ie when not jointed. It chars and self protects, plus the pb gives off moisture. But that we should still follow the spec.
Yes it will. All and any plasterboard provides significant fire resistance As opposed to sitting at the builders merchant?
The best performing acoustic floor i did ( school classrooms) was based on it completely floating on dense mineral wool. That spreads impact over a large area. Ply on joists. Layer of plasterboard for density (you might ask bm for seconds or find some offcuts.). Layer of the right mineral wool. T and G chipboard. Underneath, resilient bar and pb. A noise specialist later told me that all the lab test figures are unrealistic and to always go the the next spec up. -
Also puzzled. Don't you have a formal design in place? Why wouldn't you want the the same membrane?
I think that is wise. I've said before that I once assessed a 3 storey building 5 ways. The best way was a kit from a nearby supplier, who were sending out 3 houses a day to a developer. It wouldn't always be so. But on our recent private project we did stick build. The decision will depend on a lot of variables. Plus, the kit builders are rightly wary of providing endless free quotes for speculative projects, so BH actual experiences would be great.
