Everything posted by ProDave
BUT just when you thought we might be on the way to easier and cheaper ASHP installs, THIS comes along https://www.homebuilding.co.uk/news/heat-pump-defra-review A different part of the same government now complaining they are too noisy for most urban settings with high density housing. You can just see it in a few years "My boiler has broken down, I can't buy a new one, but neither can I fit an ASHP. Just what am i supposed to do?"
Hi and welcome. Sounds like you want a bare croft, unless you already have a plot in mind?
Wow design without blowing budget
ProDave replied to Stonehouse's topic in New House & Self Build Design
We have vaulted ceilings upstairs and a mezanine in the largest bedroom that goes over the smallest bedroom adjacent to it. My top tip for that if building room in roof, is do not use attic trusses, but design the roof as a cut roof supported on ridge beams. Then you end up with an uninterupted space to do as you please, leave it open to the ridge, or fit a ceiling, whatever you want. It you want a full gable wall of glass, first look at curtain / blind options. Then you will end up like most with nothing. Not what you want if that is your master bedroom overlooked by other houses. We did a token to the gable window thing in our sun room,but as 2 halves with a post in the middle to support the ridge beam. Save the expense of a steel frame and only detracts slightly from the full glass look. -
To me, the obvious thing is cut a hole in the OSB, remove insulation from below and see if you can see a sign of a leak? Less disruptive and easier to put back than cutting a hole in the GRP from above.
That sounds like a standard 25 year old Scottish timber frame with just a 4" frame. It sounds like the end walls will be a 50mm cavity then blockwork and harled end walls. And the side walls are clad in timber instead of blockwork. I would definitely be wanting to add more insulation, which potentially you could do with external wall insulation over the existing 4" frame, and then replacement cladding but it will make the overall wall thicker so the detail of how that joins the blockwork end walls will need some thinking about.
If it is Douglas Fir i am surprised it is end of life after 25 years. Is it just a case of it's a bit weathered and tatty looking now? Pictures? More information on complete build method before anyone can advise on more insulation.
The GRP used on my boat is almost an inch thick. I doubt a GRP roof is anything like that thick. It still should not leak if laid properly.
But June was a very dry month. July was very wet, so if it was a leak I would expected it to start showing when the rain came in July.
Just an off the peg suggestion. 11M by 6M is within the size limit for a "caravan" so build it as a moveable structure and call it a "caravan" and no building regs needed.
Low energy density, but interesting all the same.
ProDave replied to SteamyTea's topic in Boffin's Corner
Capacitors in general don't suffer the lifetime issues of batteries, and don't get in a huff if fully discharged so I guess power density is what has stopped them being used for energy storage in general? -
Well not on my own build, but wiring a new build not far from here, I had a stand up finger wagging argument with the joiner who wanted me to route the cables his way and did not understand safe zones. I won the argument but we never got on for the rest of the build and i ended up getting the plumber to tell me when the joiner was not there so I could go and finish off in peace.
Loft storage room conversion to loft bedroom
ProDave replied to Hemmy82's topic in Building Regulations
Unless you are very lucky and whoever did the "conversion" fitted enough insulation to meet current building regulations then assume you will have to strip back to a bare structure and start again from that point. -
Stubbed Eaves Attic Truss Roof Lift
ProDave replied to Paddyflyer's topic in Lofts, Dormers & Loft Conversions
Attic trusses like that is one way. An alternative which may give more open and flexible space to use upstairs is a cut roof made on site hung from a ridge beam, assuming there is a gable end to support a ridge beam from. -
I used Tescon Vana, available from a German supplier on ebay much cheaper than any UK supplier (but you might now have to pay VAT and duty when you import it. Siga Sicral (sp?) is another really good one but more expensive.
What about headroom and how will you fit a proper staircase? Headroom above the stairs needs to be 2 metres all the way. If you can't achieve that, no point even trying. -
Hi and welcome. There are several of us on here around the Inverness area (I am 20 miles north) Are you in the town or rural?
Just starting out on this building journey...
ProDave replied to SarahC's topic in Introduce Yourself
Hi and welcome. Most self builders at the end of the build say "never again". But then then go and do it again, and sometimes again....... (recently finished self build No 2) -
If that was a "roofer" that did that, then what I would take away from this, is when you get someone to replace the broken tiles, choose a different roofer. He has failed his trial job in my view.
No I don't. not in the slightest. I only use catchup if I miss something or my PVR fails to record it. Fringe area aerials are a black art. At the previous house, I put an aerial on a pole on a shed while we were living in the static caravan. It worked okay. When the house was finished I moved the very same aerial onto a pole on the gable end of the house, higher and clearer view of the horizon. I spent a whole afternoon trying and failing to get a decent signal, even trying different bits of coax in case I had a dud bit. At the end of the day I put it back on the shed where it has continued to work for 20 years now.
I had one a bit like that. Wanted to turn a circuit off for a repair. Shiny new CU but nothing labelled. Turned off the MCB's one at a tiime but my circuit did not go dead. It turned out which ever "haven't got a clue" changed the CU but each end of both rings into their own 32A MCB.
Can I be the first to say that roof is in a shocking state generally and needs some serious work. Sorry.
At least my own one has a switched plug at one end. (cough)
Accidentally converted a listed building without consent
ProDave replied to Pedro29's topic in Planning Permission
More details needed. YOUR house is not listed, correct? But they say the outbuilding is attached to a listed building, so it it attached to one of your neighbours houses that is listed? If you are SURE you converted it more that 4 years before you go the enforcement notice, then I would pursue a lawful development claim. To avoid muddying the waters, I would stop the holiday let business just now and put it back to residential use for the house. Get the planning or lawful development issue sorted out first. -
I don't subscribe to the earth fly lead. Unecessary congenstion in an already tight back box. As long as one of the screws is into a fixed lug, most regard an earth fly lead as not needed.
Imagine getting building regs to agree to restore that, as it was.
