Adrian Walker
Everything posted by Adrian Walker
Welcome to BuildHub, a friendly bunch with a fountain of knowledge.
External door opening inwards or outwards?
Adrian Walker replied to patp's topic in General Construction Issues
Yes, outward opening doors are more secure, hence the reason why inward opening doors are preferred by the fire service, easier to get in. -
Apologies, I missed that post.
Did you go with the Moralt FD30 in the end?
Thanks. I think I need to see and play with one in the flesh. I have demoed a Semiens super hob and the usability of the interface was very poor.
All the Bora's are greater than 600mm (720mm) because of the centre vent.
I didn't know that, as it listed on their website and catalogue. What is the replacement called "Pure"?
Currently looking at a BORA Induction Hob. Has anyone got one and happy to share a video on how easy it is to use the controls? Thanks
If they have the correct gear (water cooling, 330+mm laser welded diamond blade, etc) they should be able to do the cuts with 1 blade, but these can be expensive, so perhaps ask for a cap on the number of blades? It's going to be very noisy so good to warn the neighbours
Foolish not to check for services before piling?
Adrian Walker replied to Dreadnaught's topic in Foundations
Make sure you have insurance against this. Contractors are not liable if they cut through any service. I had a digger cut though an underground high voltage cable.- 15 replies
It looks like a SIP system to me.
Local supplier are useful to be able to see the items in the flesh, but you can get everything online, these day either in the UK or from Europe direct. . Eg Duravit white goods can be found here If you want to support local suppliers ask if they will price match
I have used Helen Morris Ruffle at Visionary Planning UK/Town Planning Expert (http://www.tpexpert.org).
Welcome to BH @TomBee Congratulations on considering a design based on Passive House Principles. Before you approach the Council it might be worth looking at the current planning policy, both the Government National Planning Policy Framework and the Councils to see the best route. For example there are Community Policies that involve asking local residents what they would like (Localism) and Para79 (outstanding or innovative design).
Is the £2995 a price for you to supply and install a SunAmp?
I do occasionally know what I am doing
Adrian Walker replied to Dorset Dabbler's topic in Introduce Yourself
Welcome to the forum @Dorset Dabbler Nice to see another person from Dorset. What are you planning, new build or renovation? -
Welcome to the BuildHub. I 'm just finishing a Durisol bungalow, so happy to share some experience. Have you looked at ISOTEX which is also a woodcrete product?
Mixing slips : is it possible to copy this?
Adrian Walker replied to ToughButterCup's topic in Building Materials
Set makers in the film industry could do that -
First costing of project, opinions required
Adrian Walker replied to Spainy86's topic in Costing & Estimating
Just had a quick look at your build cost spreadsheet and the House Build of £54K is a bit light as is the garage at £10,800(IMHO) Groundworks and retaining walls can often be tricky and hence costly. You have made a good start at costing. -
It worked very well and needs very little help to get in all the places it needed to be. It eliminates power floating which can be time consuming and noisey. I will see if I can find a better photo that shows the finish. This was an ISOQUICK insulated slab with UFH.
Just a single pour. The last one I did used Cemex Evolution concrete which is self leveling/finishing. - https://www.cemex.co.uk/evolution-self-compacting-concrete
Simpler stairs: concrete winder
Adrian Walker replied to ToughButterCup's topic in General Construction Issues
In the is example, because of the difference in runs on the concrete base, it's not going to be very nice to climb IMHO and, I would expect a few tumbles until you get use to it. -
Polarwall is a good system, BUT it needs lots of bracing. That concrete has a long way to fall and they should have used a reducer to slow the speed.
