TonyT
Everything posted by TonyT
Plyontech
Go full DC route so no DNO involvement
No rings, we are going radial what are the practicalities?
TonyT replied to MikeSharp01's topic in Power Circuits
Bigger consumer unit. more cost for rcbos more cost for cable However for minimising inconvenience to trips it’s a plus. -
Joint at the manifold so any potential leak is above floor level
Bet you wished you just set the conduit up to the floor level and then back down and saved that £25 All in the planning
What would you do differently if you could do your PV install fresh?
TonyT replied to Gill's topic in Photovoltaics (PV)
currently consuming 1.5 watts according to the energy meter on the EV charger feed. its 9 pence during the cheap slot compared to 38pence(ish) so definitely worth charging at that cheap time -
My EV charger is a dumb as a box of rocks, activated each night at 12:30to 04:30 to benefit from the cheaper electricity tariff just the way I like it -
The lid to the immersion heater
Cost of Landscaping. Does this seem a reasonable quote?
TonyT replied to patp's topic in Landscaping, Decking & Patios
It’s nice that it’s broken down, not sure where you are in the world though -
Insulated Concrete Slab Garden Office - Questions
TonyT replied to Ticky's topic in Garages & Workshops
12mm -
Wall drying out, paint preventing wall breathing so plaint blistering
seal/paint interior shed ?
TonyT replied to mickespite's topic in General Self Build & DIY Discussion
A coat of watered down pva would be the cheapest option then just coats of normal emulsion, splash the cash on masonary paint if you want. any expanding foam will do the trick, smallest can possible, or line up a few jobs and do lots at one time. -
Salts coming out of stone/brickwork?
Last minute objection from neighbour's surveyor
TonyT replied to CPT2023's topic in Party Wall & Property Legal Issues
https://www.ibstockbrick.co.uk/wp-content/uploads/2015/08/Get-It-Right_Chimney-construction_a.pdf -
Do you have chimney pots? -
Maybe there should just be a qualification similar to working on gas boilers, fire etc and a card like gas safe or the Sjib/jib card electricians have, I recently sat the EV installation course, doesn’t make me an expert but covered the safety requirements to do a good design… and take away MCS registration
Do you need to stagger plasterboard
TonyT replied to Eric's topic in General Self Build & DIY Discussion
Crack on! less joins always better, can you get 2.7m easily, manage to fit them? -
Court Judgments like this make me happy
TonyT replied to Adsibob's topic in Party Wall & Property Legal Issues
I must be spoiled then I deal with professional architects, consultants & trades -
Why wouldn’t the architect not advise to leave a gap? why wouldn’t the builder not advise that the architects drawings were rubbish to the client. seems like no one with any sense volunteered any info client may or may have been an arse but that’s not the point, you do the build, you get tarnished too -
Data cable too probably unless the unit works off 4G personally I would fit ducts to proposed positions, pull in cable such as EV ultra, or separate Swa/ data.
Underground workspace - how to shore up and waterproof?
TonyT replied to BodgeBodge's topic in Garages & Workshops
Sika additives into concrete/render/ French drains tanking to external relandscaping to ensure water stays away from building as much as possible -
Dehumidifier in damp house to speed up plaster drying time
TonyT replied to Adsibob's topic in Plastering & Rendering
Not worth the risk, crack open some windows and get some through air movement. keep the dehumidifier for drying the clothes or after a leak -
Can’t really see the drawing. Maybe inside the plant room, so that running subsequent services are easier? borh my gas and electricity meters are inside the house and I never found it an issue
