dpmiller
    4
Everything posted by dpmiller
  1. buy the whole thing justincase, but only send the plug?
  2. you can, if your careful put SDS in a normal chuck... and a cheap TCT core will do it
  3. a/c linkage is simple startup yep.
  4. yep, that contact overrides the current mode set in User Mask, according to Chris...
  5. not always. SBRs do an aeration/ settle/ decant cycle, within a single chamber.
  6. practice and youtube. There were some great videos from (IIRC) Volvo in the US that helped me understand some of the stuff I'd watched my groundworker pal do so delicately
  7. If you only want cheapo softwood linings, Howdens do some useful sizes, like 115mm for 89CLS + PB
  8. post a photo of the top of the soil stack at the roof
  9. getting that glazing bar at the right height can reduce costs too as it can allow a downgrade in the glass above it. Our archtect designed this into our large front windows.
  10. blue square thing looks like a transit foam that hasn't been removed from the unit?
  11. Our Bronpi does the same kind of thing occasionally, I think the term is "cold plug". Gotta use a bigger than expected starter to get things moving.
  12. Do you really need a Radon survey? Look at the map yourself and see what the risk level is first...
  13. B&Q manage to get ex-tradies with *some* level of knowledge, to assist the punters
  14. add another rubber washer
  15. I'd presume it was above FFL but hang on for confirmation...
  16. you've sorted the loose seam in the asphalt yes?
  17. The Excise boys are pretty active this side of the Irish Sea- North and South- and it's not unusual to see main roads stopped for fuel checkpoints. Where I get red at the pump for the digger, and for testing heaters and things, there is a constant stream of pretty new snazzy cars filling up at the pump. Often tradies that are working daily on a site some distance from home. Seems the losing the car and being find isn't enough of a dis-incentive? A couple of litres for a digger or dumper aint even on the radar...
  18. so have you confirmed that it's even a septic system and not just a leaky cesspit?
  19. surely a cesspit doesn't have any outlet?
  20. still available at the pump, locally.
  21. we had similar to contend with, swan-neck did the job fine
  22. put a radiolink into one of the Aicos to make the whole system accessible, then get a relay box or better still the EI414 alarm interface.
  23. the pre- sown weeds and haz waste residue are free!
  24. Coolenergy pumps are OEM'd by Sprsun. They may brand for other retailers too. You'll not find too many similarities with the big brands as Sprsun use a suite of control gear from Carel whereas Panasonic, Samsung etc do it all in-house
