JohnMo
    200
Everything posted by JohnMo
  1. Could you have a 'store' instead of playroom? A storage room needs no light or heat.
  2. We used Cameron Ross, they seem to cover most of Scotland. Worth a call. Our architect did out percolation test. You may need a small digger on site for digging the holes required.
  3. We got quotes for uPVC windows, I suggested to the wife we look at them before committing to buy. She not like, so went for wooden framed at more than double the cost. But they do look really good
  4. Because 5.12kW is bigger than 16A, so was G99 scheme, not G98.
  5. No I think my use of words are correct. You are not separating cooling systems, you are separating multiple pumps from interaction with each other.
  6. You are correct, my typo
  7. hope the homely thermostat isn't as clunky and slow to load as their website. Doesn't fill you confidence.
  8. You could run you piping to the rads and use two close coupled tees on the return line to supply the UFH. So the return water out of the rads if no UFH is on would flow direct back to the UFH. If UFH is on, water would be borrowed from the return via the first tee, then after flowing through the UFH would return to the radiator return via the second tee. Using the close couple tee there is hydraulic separation, between to boiler pump and the ufh pump. You will need to find the min flow rate and system capacity for heat pump and make sure the system is big enough and there is enough flow Run the whole lot as a single zone, will keep the system from short cycling.
  9. G98 is after the event, not before, permission is pre granted up to 16A per phase. G99 is prior to install, as you are seeking permission as the array is bigger than 16A
  10. I also did my own also, did the trays, pre ran all the cables in conduit, mounted isolation switches, inverter, electoral guy did the rest and signed the G98 form. Mine is 3.1kW, just over £2.5k for everything. Electrical costs lost in the new house wiring costs. I think only the battery can go into island mode, PV cannot, not sure how legitimate be artery islanding is within G98/99 rules. Not sure of the maths of batteries yet. I self consume everything the PV gives me, via a diverter to heat hot water. Battery no use to me.
  11. How do you manage to use 50kWh a day of electricity with a gas boiler. And export 25% of electricity generated. We're averaged around 9kWh of electricity and 2kWh of gas over the last month, we are home 24/7. With 3.1kW PV
  12. Obviously a good at energy saving, possibly not that good on money saving
  13. Good job you don't use a kettle for making an espresso! We would be well out of pocket, wasting all that hot water heating. Buy a coffee making for £200 to save 1p on every espresso
  14. I would discuss with a structural engineer first. You need to ensure the existing building and foundation are suitable for the additional weight.
  15. Basically yes, but that's the logic they are using. Somewhat not in touch with reality. But the butler makes the tea, so why would they know any different.
  16. Reading the thread that mentioned "Which". An old kettle had the element exposed to the water, so you had to put a minimum amount of water into the kettle. Modern kettles have the elements away from the water so you have no minimum water level. So based on only putting the minimum water in the kettle, and comparing an old design to new kettle, the new kettle will use less kWh per year, as it is required to boil less water. So is more efficient in it use of energy. Not much use for most people as they just fill the kettle up, then boil it, same amount of water for 1 cup or 6 cups of tea.
  17. We had this during the build, when ever the tilers were here, the electrics would keep tripping. The transformer they were using was good for the skip as it had an internal issue.
  18. eBay item 354231297695 is the 3kW, they do a 5kW and bigger ones also. They do an inverter one also, which controlled via an App. You get a better price if you call them.
  19. Basics what is your heat demand and flow temperature to the UFH?
  20. I am in a similar situation (or will be in a couple of months) one solution is a split Aircon. The other is Aircon where the unit sucks and blows through holes the wall, not as good CoP but around 3 so ok. Both will do heat and cooling. Also have looked at a dreams ASHP and if I did I would also drive the house UFH from the same unit, would only be looking to sub 30 degrees flow temp, so the CoP would be good and it does cooling straight out the box. You can get 3kW ones for £1300 ish
  21. Looking at the sunamp, big cost for little advantage, have you considered a normal UVC? Perhaps make the downstairs shower slightly smaller and use that space to site it? Willis heater assume is for UFH, you should install two, one for backup as an installed valve isolated spare.
  22. Question is why do you need it at 55. Many other on here operate the cylinder at 47/48, with no issue. That way you get a better CoP. Other that no idea how you change the settings.
  23. Don't think any thermostats are that good with a slow reaction heating system. We are in 100mm concrete screed, thermostats just cause over and undershoot. Smart controls cannot deal with the timings. You just have to balance the energy going into the slab, low flow temp for long periods, or slightly higher flow temps for a set period. Then balance the system room by room, to get the room temperature you want.
  24. Mitsubishi SRK20ZSX-W was the A2A I referred too.
