JohnMo
    196
Everything posted by JohnMo
  1. They only bothered with CO2 emissions reduction - blunt stick approach will do
  2. Another way I found was (in US units) V= t(Qhsmin – Qloadmin)/500(delta T) V = minimum buffer tank volume (gallons) t = minimum heat source on time (minutes) Qhsmin = minimum stable heat output of heat source (Btu/hr) Qloadmin = minimum concurrent heating load when heat source is on (Btu/hr) ΔT = change in average tank temperature during minimum heat source on time (ºF)
  3. MCS give this as formula with a worked example. Looking at the system volume. Example: A 12kW nominal inverter controlled heat pump unit (at 7oC ambient and 35oC water flow) can provide an output of 4kW at maximum turn down (minimum output) at an ambient of 12oC and weather compensated flow temperature of 30oC. What is the minimum water content to ensure cycling does not exceed six starts per hour? Assume acceptable temperature drop of fluid is 5oC and the fluid has a SHC of 4 [kJ/oC kg] because it has antifreeze in it (normally 4.18[kJ/oC kg]) Total heat energy required: 4 [kW = kJ/s x 60/6] [minutes/number] x 60 [secs/min] = 2,400 [kJ] Mass of water required [kg] = 2400 [kJ]/(4 [kJ/oC kg] x 5 [oC] = 120 [kg] Assume 1 kg of water = 1 litre, therefore 120 litres required.
  4. It's a difficult call, you can build a basic house quite cheaply, the costs go up with the outside finish, floor finish and kitchen and bathrooms and glazing. Plus bells and whistles that may not be needed. Your going to have to do lots yourself to make it work. GSHP, PV, will kill the budget unless your in the digger doing the trenches, even then you may not see change out £6-7k for GSHP. Your rear glazing may need to be simplified (made smaller, dump bi folds etc), to make the budget work, AC is another £1-2k plus F gas engineer to install. If it were me, and I really needed to control the budget. Find a builder you like, use their preferred build method, render finish, insulate really well, make a reasonable air tightness, to allow MEV, dMEV ventilation that is humidity sensitive, so it ventilates only when needed. Drop the Juliet balcony, drop bi folds and make french doors with fixed panel either side, ASHP, UFH downstairs (single zone) radiators in bedrooms. Find a kitchen install company work with on a good kitchen design, but give them a small budget. Same with bathrooms.
  5. We used real stone cladding, they do a black slate. https://www.realstonecladding.co.uk/black-slate
  6. Just watch your not getting taken for a ride with pricing. To buy the parts you are looking circa £1k per kWh, the bigger the array the more economical it becomes. If you any risk of shadow that includes clouds you need optimisers on each panel. You need an external DC isolation switch even if the inverter has one. It is likely the inverter could fail before the panels, the additional DC isolation allows the inverter to be removed safely.
  7. https://re.jrc.ec.europa.eu/pvg_tools/en/ Use the tool, to get a good estimate of output by month
  8. Little confused. In Jan your output from PV for the month will be around 150kWh, some days the output will be zero, but if we average to 31 days of equal generation, 4.8kWh per day. Even getting a CoP of 4, that less than 2 hours of running the heat pump. So full use from PV without any other loads. In summer you are generating circa 400kWh per month, 13kWh per day, a couple of hours doing hot water, would 5.6kWh, other background uses, washing machine, dishwasher etc plus immersion to bump up cylinder temp to max, all the PV is used.
  9. You don't mention size of ASHP nor PV array size. We have 3.1kW of PV and gas boiler (so should be easier for you to self use). Since middle of June I have exported 43kWh (5 to 600kWh generated), this was only exported because my immersion was miss reading and only charging the cylinder to 55 degC. This has since been fixed and now exporting nothing.
  10. Does that make sense? A storage combi should give you an endless supply of hot water, at better flow rates than a normal combi. Our Atag combi was doing two high flow showers at a time this weekend without complaint from the boiler or the users.
  11. Have you got a huge gap in your insulation between roof and wall?
  12. Gas -June to today, average 2kWh, mostly 2 of us, but had a long weekend with 6 in the house. Combi boiler with preheat cylinder upstream, heated by solar. Electric average 8.4kWh for same period. Have 3.1kW solar with diverter
  13. Oil price haven't got to levels they were at during the five years, 2010 to 2015. Think the issue is not the oil price, but processing capacity; as we out sourced most things (diesel and petrol) to other countries like Russia to make a CO2 emissions look good.
  14. We are the same, one heating season no issues. We are on a 100mm concrete screed. We had elevated humidity in the floor, so had to apply a liquid (epoxy) DPM prior to glueing the floor down.
  15. I used Rye Oil Cedar Cladding oil. £200 for 75l. Easy to apply, goes along way, one heavy coat applied 6 months ago, looks the same today.
  16. Thought I understood what you were doing, now just confused.
  17. But who does that - no-one. Small trees are no use for anything, same as the branches they chop off which are just left in the forest. These parts are not harvested unless you do it yourself and air dry for a couple of years before you burn it. True, or not without trying hard. Again true A tree used to construct something - not burnt, will capture carbon will keep it captured until it rots away.
  18. A young tree absorbs very little CO2, it's not until the they are in the middle growing phase that they absorb lots of CO2. The issue is we cut a tree down at 20 to 40 years old and it's in the absorb lots of CO2 phase. And replace it with a tree that sequester very little CO2 in comparison for 10 to 15 years. Planting a tree is good, chopping them down is not. You can kid yourself on, its sustainable but, really it's not.
  19. Its only carbon neutral if the tree fell over, died or the part used to burn fell off the tree and would otherwise decompose where it fell. A tree chopped down for firewood, isn't carbon neutral. As the tree would continue to absorb CO2 all the time it lived. When the tree is burnt it releases all the trapped CO2, but also releases lots of particulates and other pollutants.
  20. Easy enough. VCL/airtight layer below insulation, tape to wall junction. Then install 50mm counter battons, then your plasterboard. Use low profile down-lights circa 15-20mm deep., They come with a small module that is about 50mm high that installs in the void, wiring can be run in the void also.
  21. To be picky, title says "Door to garage - need to be make it air tight"
  22. Not sure it would be that eco. Trees cut down with a chainsaw - hydro carbon powered. tree pulled out of wood with tractor - hydro carbon powered, transported with lorry to processing plant - cut and dried - hydro carbon powered etc etc - possibly clad with wood from the other side of the world. Put together with a gas powered nail gun. Not much eco about it - same as most buildings in reality Made in China, with coal powered electricity and then shipped across the world, not very eco either really. If it used 1W that nearly 9kWh per year that does not need to be consumed.
  23. Garage and airtight - what the point? Your brick won't be that airtight either That door is not meant to be airtight and would not be easy to get it so.
  24. forgot to mention, if you are heating TS via a coil any a system boiler would be needed. If direct heating a heat only boiler.
