Everything posted by JohnMo
You need to do your research, as the yield in winter is pretty rubbish. You will be able to do DHW in the summer , but maybe not the heating. Really depends on array size and how well insulated your are. Big array, you may be ok on a sunny day for a couple of hours, but would make sure your ok paying full price electric.
Front Door and Side Panel - 0.87 or 1.1 W/(m²·K)
JohnMo replied to NewToAllOfThis's topic in Doors & Door Frames
Heat loss difference is basically the area X temperature difference between indoor and outdoor. So let's say the temp difference is 15 for the heating season. 15 x 3.3 x 0.87 = 43w 15 x 3.3 x 1.1 = 54w Heat loss difference is 11w each hour for the heating season, say 180 days. 11w x 24 x 180 = 47 520w or 47.5kWh. In financial terms £4.75 year heating saving at 10p / kWh. Not sure how well insulated you are or airtight, spending the money difference there may be a better use of your money. -
New to new build, keen to get going but talk about bad timing...
JohnMo replied to DAMcN's topic in Introduce Yourself
A day is along time in politics, everything we thought was true a week ago has all been changed today. But I would think property and land prices will fall sooner rather than later. -
Depends on the time of day you measure, if you have people upstairs they are all breathing out moisture. Perhaps your ventilation is less well performing upstairs.
They use a material, that shrinks or expands based on humidity. Use this to modulate the flap, simple reliable stuff that seems to work.
Pressure Reducing Valve - Where one or many
JohnMo replied to NewToAllOfThis's topic in General Plumbing
H, Ii put mine after the stop cock, the outside tap take off and a Y type strainer, but before any inside house offtakes. I think they normally come pre-set at 2.5 Bar. I fitted a Honeywell from either Toolstation or Screwfix. -
Why not replace with something like this. Then they only open as much as required and do it automatically. https://www.bpdstore.co.uk/glidevale-energy-saver-humidity-sensitive-trickle-ventilator/p/182
True
1. No, but many suppliers will want to offer 1.4. Problem is not the glass but the frames, you need good frames to get 1.2 or better. We have a couple of double glazed doors, which I had Krypton filled, they achieve U value for whole door of 1.1. An insulated door will get 1.0. Increase insulation in floor, walls and roof. Adding solar panels. Adding waste water heat recovery. Better airtightness. MVHR. Improved boiler controls. Will all get you more points on the SAP report.
Solic 200 does includes a 90 min immersion override button - called boost 90 mins. Push button to start immersion. So not sure why you haven't seen it.
I would get you stop watch out, and ensure running that regime is not giving you short cycling, your heat pump needs to running about 10mins as a minimum. Other thing to consider is internal heat loss running a couple of rooms only. What happens is you end up running the heating in the rooms heated, hotter than you would if you heated the whole house. That impacts the CoP so you could be cheaper more comfortable running the whole house at a low flow temp. I would certainly experiment. £3 doesn't sound much but that's 9kWh. Or 30 to 45 kWh of heat depending on the CoP. With the current weather you should be getting a mid 4+ maybe 5 CoP for heating.
I would agree adaptive heating with UFH caused my heating to go all over the place, there's to much delay in the floor.
Must agree, the site is excellent. The cylinder as standard does leak lots of heat. Loads of extra insulation has helped. Today it's sitting at 25/26, so heat loss is minimal. In the summer if it is hot it's from excess PV, it occasionally gets to 70 and the room used to be quite warm, the insulation made a dramatic difference to room temperature and also rate the cylinder heated up. Sun's out today, no real need to have the heating on, but with weather comp, the pumps are still running, so excess PV is going to the immersion and is charging the floor.
No. WC basically maintains the return temp. Target flow/return temp is increased as it colder by taking a reference from the external temperature sensor.
Husky air source heat pump, anyone still got one?
JohnMo replied to Simtronic's topic in Air Source Heat Pumps (ASHP)
If the tanks are heat pump ready, tell them you are not replacing, same with the heating system. If you only need the HP replacement that's all they should be providing. Just a bunch of con artists, trying to rip everyone off -
The indoor temperature is controlled in the following ways. Water flow temperature, this needs to be set so trv are not closing down flow, keep reducing flow temp until you have most the house the temperature you want, say 19-20 degrees. Some room like bedrooms may be warmer than you require so reduce the flow through the radiator or UFH loop. If a room is colder than you require up the flow. If when it gets colder the house is getting to warm your temperature curve needs making more shallow, not getting hot enough it's needs to be steeper. Think the FTC is fitted room compensation, you may need to switch that of for a couple of days while you get the target flow temps set up. WC is matter of balancing heat put into the house, with the heat escaping. Trvs set out of the way at max while you set things up. Once set up your trv should be set at a couple degrees above you normal room temp. You need to set a night time set back also a couple degrees cooler than your day temp.
Thanks for the comments, but I have say Nick the idea for the system came from you, and some of your earlier posts on here. I had to do a little refinement at the end but you always do with things that a bit different. The bit that took the most getting my head around was the heat transfer rates through a cylinder coil at very low temps is really poor. When I first started heating the house I was very confused how I could be using so much gas. Had never really come across short cycling, as all my previous House's had been heat seizes. I suppose that's why I keep banging on about, heating system design and the need to design it, to eliminate short cycling - because you can use twice the input energy you should.
Forgot to mention, took the Salus actuator off the mixer valve and it is basically closed so mixing, water just passes through. Wasn't needed.
Well in Scotland the regs say the building should be complete. Which is good enough reason for me. How do you know, for example whoever boards out, doesn't fill the airtight layer with holes for example?
So an update on the heating and hot water performance. DHW Prior to modes, May 2022 gas consumption, for domestic hot water was 260kWh, or 8kWh per day. After mods June - 105kWh or 3.5kWh a day July - 64kWh or around 2kWh a day August - 104kWh or 3.5kWh a day. Had visitors (extra 4 in house) for a long weekend. All other times we were home. So overall well worth the mods. Heating Had the heating on the whole of October, set up to use weather compensation. Flow temps through UFH start at 23 degrees, compensation curve is almost flat, max temp at -5 is 26 degs. Night set back is a 2 degree drop in flow temp. However due to the inertia of the house/floor, night set back starts at 17:30 and finishes 02:30. Floor temp is around 21degs. Room temps 19 degs. Bedrooms temp sits at about 18 degs. All rooms have UFH circulation on, as the thermostats are set at 22, so operate as a single zone. Min turndown of boiler at the flow temps is 6.7kW. But my average gas input into the UFH water is currently 0.5kWh per hour. Boiler runs for about 10 mins and is off for nearly 2 hrs. At -5 the boiler run time should run around 15 mins and off 20 mins. One observation is the gas usage is well below what Jeremy spreadsheet say I should be consuming to keep the house at this temperature. Based on last year's October gas input of 1370kWh for heating and DHW. This year I hope to consume 600kWh or so. So a reduction of about 50% overall.😁
My house was done with Knauf, the guy doing it told me to buy that, as he had used everything else and liked that best.
At the end of the day it's for sap report not you. And a box tick. Hense what the original post is asking. I couldn't get a sap report until I produced a suitable air test cert, completed at the end of the build, my tester would not issue one until the build was completed.
Got our big ones 2x1x1m from a builders merchants, but we'll also got smaller ones about 300 deep various lengths from B&Q.
Lots of builders around us are starting to slow down, cost of heat and mortgage is keeping people's money in their pockets, so may be easier now than it was a couple of months ago
Where the two bricks are length wise should that be a lintel? But generally - see above, a two year old could do a better job.
