Everything posted by JohnMo
Basically produced a whole 2kWh. But was enough for the heat pump stayed off for 4 hours from midday until around 4pm. Currently set to run 24/7 on WC.
Started filling with water, and realised why I hate compression fittings. They never seem to seal first time. One of the joints has been made about 5 times. Lucky it was on the heating coil part so not so much to drain down. Think they must just be piss poor quality. Eventually got them to seal with a liberal application of liquid PTFE over the olive.
No, but I do have space on the frame for another panel or tubes. Sun's out this afternoon, so will have a look later to check how many kWh I produced today. By way of compensation my 22 PV panels are doing 2.5 to 3kW. So for the size ST is quite effective.
I had a similar issue on a motorcycle once, had to change the brake switch in the end. Was fine with a normal bulb.
Advice required - idea to price jobs in a new way
JohnMo replied to 75darren's topic in Building Materials
Is this blatant advertising? -
Recommendations for solar thermal suppliers
JohnMo replied to ChrisSig's topic in Solar Thermal (ST)
eBay is your friend, normally lots of stuff there and can be at very sensible prices. If you are going evacuated tube, you need a nice big bulb size. Whether evac tube is really any better than flat plate in the UK, is a bit questionable. -
Not made any changes so far. It's at 45 degrees. But production window seems to be quite small, about 3 hours as to many tree in the way. Solar startup temperature is 8 degrees above heat pump return temp, by the time the panel water has gone through plate exchanger, its running with a dT of 3 to 4 between the PHE and ASHP return temp. Have heating side pump, which is between CCT and PHE running at min speed (0.19m3/h) and according to the heat meter it's delivering around 0.8kW in to the heating system.
Help - swapping direct for indirect (unvented hot water)
JohnMo replied to newbiehome's topic in Boilers & Hot Water Tanks
Indirect pretty simple change out, just need the feed pipes and zone valve. Pretty easy for a plumber.- 4 replies
- boiler
- unvented cylinder
(and 2 more)
Could you put a pipe stat on the pipe as it comes back towards the cylinder, to cut and start the power to the pump? Then use the pumps time clock or an external one?
Sleep on it, something will pop into your head, when you are not thinking about it.
Obvious question, can you move the battery into the area as the gateway?
The cable between battery and Inverter (all one integrated unit) and gateway is AC, nothing to do with PV or DC. PV ties in to the gateway again in AC. The battery/inverter kicks out up to around 7kW. It takes a charge of 6kW.
Water vapour condensing in pipes?
JohnMo replied to flanagaj's topic in Mechanical Ventilation with Heat Recovery (MVHR)
You should be sloping back to the terminal or towards the MVHR unit. There should be no collection of water. Even if there was, the amount air travelling down the pipe would soon mop it up. Legionella growth is zero below 20. -
I did try that, but the CoP hit not worth it. Have a big enough battery and PV when sun's out. So now just run a simple WC regime.
Looks nice. See you have two supports for the balcony section, increase to four and the huge expense to cantilever vanishes. Not sure how you get passivhaus energy performance with all that glazing? You are also going to need to add plenty of additional insulation to the sip to get to passivhaus standards, so somewhat defeats there advantage. Although you have an overhang for shading watch out for low eastern and western sun, as it will find its way under and overheat the house, if you don't plan well.
Who are you with to that price. My E7 is 0.1516 per kWh.
As I said, very complex. Found myself doing this sort of thing, when I first built the house, slowly undid it all when I started seeing the bills - KISS wins every time.
Summerhouse- 4cm over height of 'permitted development
JohnMo replied to BLISSY's topic in Garages & Workshops
If anyone say anything buy a big bag of gravel and build up ground level. Who is likely to be measuring? -
Order really depends on if you have a service void between vapour barrier and plasterboard. The above sounds like you don't. Assume as you have plumbing, toilets etc you are subject to building regs as a minimum. I would concider mineral wool instead of PIR for between timber, much easier to install, something like Frametherm 32. Did all my wiring behind the vapour barrier on and through the studs. Then just brought the cables through barrier where needed and sealed up. I made the external membrane airtight, with limited penetrations in that and taped to the DPM. Not sure I would do external wiring, does who ever is signing off, agree with that?
You can limit the watts going between the battery and the gateway, your install can set hard stops also, which the end user cannot change later. Discharge and charge power are all setting that can be changed. If this simplified the install.
How is the ashp plumbed into the heating system, do you have a buffer for example? Does your heatmiser control zone valves and/or a call for heat?
Are you sure you need the install to be so complicated? Its complect just reading it, let alone installing and getting to work efficiently.
Sorry no. How far away is the battery from the gateway?
Datasheet datasheet---all-in-one--june-2023- (1).pdf
