Everything posted by JohnMo
Builder's upstand vs proprietary
JohnMo replied to JackOfNoTrades's topic in Skylights & Roof Windows
You only show what they ask to see. My inspections were prior to mass fill of foundation concrete, prior to plasterboard and when everything finished. Could have used anything for the upstand no-one would have seen or cared (except me). -
No one asked anything. Think there was about 5m linear in total, within a 200m2 roof. Our drawing just said proprietary upstand, which have been PIR insulation so no different really. -
Think it came in manhandled sections and was pinned to the ground with bent rebar pins.
I did a small area on a 50 deg slope, a couple of years later the bags have all rotted away, but it does give time for the plant roots to take over. Much less labour intensive is the correct landscaping mesh then back fill with soil.
Use Compacfoam CF200, 75mm x 100mm. From Green Building Store. Took the joiner 30 mins to do 2x roof light up stands. Might look expensive, but not paying a joiner to faff about for 1/2 a day. Super simple, zero cold bridges. I also lined the whole space with 25mm PIR for belts and braces. -
Sounds super expensive - any other practical route to get to basement, do you need the sand craned in?
Mvhr plenum placement
JohnMo replied to Russell griffiths's topic in General Self Build & DIY Discussion
Why not? Get rid of the worst condensation where it occurs. Have 2 directly above showers, the other directly above bath. -
dMVHR air quality question
JohnMo replied to chromaticmind's topic in Mechanical Ventilation with Heat Recovery (MVHR)
What does that mean in reality? Have you looked at cascade MVHR, such as blu Martin or Fresh-R? Or a home brew version? -
Not sure then either, as long as it's filter and UV treated, and you use most of the cylinder contents daily again no need.
Steico Flex / Pavaflex for sound insulation?
JohnMo replied to Sparrowhawk's topic in Sound Insulation
Our 1830s house (last house) had the rubble, stones and general building waste all shoved in there, almost no noise transfer. Lathe and plaster ceiling and thick pitch pine floors. -
You actually run that? Why?
MVHR and windows open
JohnMo replied to Trw144's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I have just been away since Thursday visiting. Was like a breath of fresh coming home, light, fresh airy feel, as soon as you walk in the door. Good old MVHR. -
My Atag boiler did that also, unless you have UFH then it just screws the system up because the dalay caused by the floor heating up, same as Mitsubishi heat pumps do - they say not to use with UFH.
Evaporator is on the wall side of the heat pump, so always in the shade, sun would never get close to the area to be effective with aiding defrost. Your heat pump reads the air temperature it sees going via the evaporator, compare it to ambient on a sunny day and report. Mine is exposed to early sun, if it's cold and sunny the air going through the evaporator is also cold.
Off-peak energy storage for cheaper heating
JohnMo replied to Originaltwist's topic in Other Heating Systems
You do need to start with this approach as the heat pump is really needed to be 3x oversized for the house (so maybe a typical MCS install). And have a smart meter that actually communicates (unlike mine). I run E7 with 6kW heat pump and 60T of floor. My heat demand is 3kW and on the coldest days I need to pump heat for 12hrs. So in my case the cost for the same amount of energy (electric 14p kWh) is £560 instead of £300. -
Why would that happen with a well set up system. He has UFH not radiators. My gas system started with lots of zones, consumption of gas was through roof. Did various forms of WC (with a d without zones), fixed temp for long periods works really well. I did lots of experimenting with the gas boiler and batch charge worked out cheaper with that also.
As above, also the unit is pulling a huge volume of air through it, so it's making its own strong wind. (Bold section) No
That makes no difference, except make sure it's a heat pump suitable for a coastal location.
I bought my two units as new (other) units on eBay, one came with a faulty fan motor. Titon were great, although out of warranty, they helped identify the issue supplied parts etc, at my cost. Now been running for a couple of years no issues. Like that you can speak technical to someone in the UK, get the parts quickly and easily. -
Internal partition walls cost block work vs Stud
JohnMo replied to MariaD's topic in General Construction Issues
No idea on cost comparison, but stud walls are quick easy, double bottom rail single top rail, and the verticals at 600mm centres and noggins at 1200mm centres. All wiring in drilled holes in studs (3x2 non structural), 50mm insulation, plasterboard, done. -
Intumescent paint for use on OSB – who would you recommend?
JohnMo replied to Chris HB's topic in Building Materials
You shouldn't need to take it off for the life of the building. Having seen it applied on our doors of the last house, I would avoid if possible as the surface finish is pants
