Everything posted by JohnMo
Please see the other response on the other thread. The article uses 25mm of polystyrene insulation under the slab so downward heat losses are huge and make the whole article a bit of a joke and at best misinformation. The lowest output they mentioned is a mean flow temp of 35 degC for 47W/m2. Highest is 95W/m3 at 56 degC mean flow temp. All pretty huge, maybe ok for energy rich USA.
UFH pipes in concrete slab, on insulation or tied to mesh
JohnMo replied to Chanmenie's topic in Foundations
See my other response. Plus below on the article From the article "This increases the time required to warm the floor surface to normal operating temperatures following a call for heat. It also lengthens the cool-down time after heat input is interrupted by system controls. A fully “charged” slab can hold several hours worth of heat that will continue to flow into the space as long as the air temperature and / or interior surface temperatures are cooler than the floor surface. This can be a real problem in buildings with significant internal heat gains from sun-light or other sources." Comments With batch heating the long storage time constant is what you want. Heat for 7 hours, live off the heat for next 17 hrs until next heat cycle. Charge with a low hysterisis thermostat ensure little temp overseeing in the rooms. Well insulated ensures heat doesn't escape and also floor surface is only a couple of degrees warmer than the room so the floor output self modulates. One of the FEA models I constructed is shown in Figure 1 (on Page 14). It consists of a 4-inch concrete slab sitting on 1-inch-thick extruded polystyrene insulation. Comments - 25mm of polystyrene insulation is a joke and undermines the whole premise of the article. -
Not sure what to state is real in reality. Unless your heat losses are huge of course - but then you wouldn't be installing UFH unless you were mad with money to burn. If I needed 70+W/m2 the house would require 13kW to heat, reality is I need 3kW at -9. So why would I design the UFH to give out that much heat. Mines at the bottom of a 100mm concrete pinned to insulation and at 300mm centres. Slow to respond yes, does it make any difference - no, as you keep the slab (60 Tonnes) up to temperature, by low and slow heating or batch heating on E7.
So basically using the UVC in reverse as a buffer. I would plumb as a 2 port buffer. So basically it simplifies the install. The grey box is your boiler there is an oversized tee on the top connector, this forms a hydraulic nul point, after that you have a secondary circulation pump. Water flow is to central heating first, zones closed flow is automatically diverted to buffer, no zones open around buffer only. You control the secondary pump by the heating demand, you control the boiler by the cylinder thermostat. You are likely going to need a larger heating system expansion vessel to match your increased capacity. How it works - So cylinder hot, house heat demand the secondary pump pulls from the buffer until the buffer calls for heat, then the boiler starts. Once house demand is finished secondary pump stops and the cylinder is heated ready to go. At the end of the heat season switch the boiler off, but it likely your solar excess will do that anyway. The DHW would look like the top image below, with a Watts solar diverter. You need a cold water safety group and expansion vessel if not already installed. Safety There must be no valves (if valve the handle removed) between cylinder and heating system expansion vessel and safety group. Or you install the full safety group on the cylinder - this is a zero cost option as all the kit comes with cylinder anyway.
Just checked the house dew point and it's about 14.5 degs currently, the UFH manifold is just feeling cold but looks dull so some water is starting to form. But I operate cooling for 3 hrs in the morning and 3 hours in the afternoon with 1.5 hrs off around midday, allows for hot water production, but also keeps me mostly away from dew point. Flow temp starts at about 17 and takes the cooling period to get down to 12. Found last year if you try to leave it cooling all day you start to get drips from the UFH manifold. If I run any warmer the heat pump cycles too much. At 12 Deg set point it run non stop the whole cooling session. Also found last year UFH cooling really just helps temper the temperature and stops the extremes, rather than real cooling. Our living room is currently 25.6 at 1.5m high and it's 23 in the hall at 0.5m high, but feels more like 22. The floor is pulling the heat from your body, similar to wind chill in some respects. Humidity is 56% in the house (MVHR) and the summer house where the fan coil is is 52% (with dMEV). Without underfloor cooling the room with all windows and blinds closed gets to nearly 28, because of the wall of glazing. Windows and door will be opened to purge the hot air in a while.
Just looked at our fan coil, it's being supplied with about 12 Deg water same as the UFH, no condensation at all. Fan coil pipes aren't insulated.
Yes, I just slip them on the spring prongs that hold the terminal in place
I use similar to those in all my extraction points, it's amazing the amount of stuff they collect in 6 months, and makes you wonder how contaminated the ducts would be if not using them. The main MVHR extraction side filter is almost always clean when I inspect.
Surplus solar diverter + battery storage issue?
JohnMo replied to lakelandfolk's topic in General Alternative Energy Issues
Ours is similar, only once battery is fully charged and the PV has no where to go but export, does the CT clamp pick up and divert to immersion. -
Thermal inertia prevents this. A passivhaus or one close to it doesn't change temperature quickly, also we are talking specifically about UFH not radiators. UFH systems are ultimately a huge buffer of heat store. The only way to prevent temperature overshoot by a simple anyone can use, low hysterisis thermostat. A normal thermostat will give an undershoot (in our house) of 3 degs and the same overshot. So a 6 Deg swing in room temperature. The 0.1 hysterisis is closer to 0.3 swing in 24 hrs, with heat pump running cycles and long off cycle. Through practical experiments I and many other have proven this works. Cooling I use the same thermostat set to cooling mode, mine is in the hall, but every house is different. You get temperatures in different rooms through balancing the UFH. UFH cooling isn't the same as Aircon, which cools the air. Underfloor cooling,room air temperature stays warm, but the room feels cool because the floor is sucking the heat from you. It doesn't have to, I paid £1300 for mine. The rest you are talking extremes, that makes no sense. The fact is you can set the target flow to any temperature you want, the heat pump would struggle to get there due to the floors thermal inertia. The heat pump sets it's actual flow temp based on return temperature first, to manage dT. Once dT has started to reduce it adds to the flow temperature... I have done the maths and the experiments. The facts are Anyway you heat the floor, the floor settles to approx 1 to 3 degs warmer than the room air, depending on the house heat loss (delta between inside and outside). Otherwise you overheat the house. The closer the room temperature is to floor temp, the less heat that is given off to the room. So if the floor is at 23 the room cannot get any hotter without an additional heat source. You set flow temp via calculation and experiment (combination of flow rate and mean flow temp).
Nearly all Scottish builds are dry lined (not skimmed). Joiners do the plasterboarding, and generally make a good job of it. I have lived one new build that was skimmed and all can remember is the huge amount of cracks after a few months. This house we are in now, was dry lined, nearly all our walls are over 3m tall and all ceiling vaulted so lots more joints than a normal house. Good job has little or no issue with finish. Dust - anyone doing it properly, will use a sander that has a hoover attached with HEPA filters to limit dust. But as with most things, do what is normal in your area. It's no use saying dry line and you can't find a decent dry lining company. Same with skimming. Get that sorted first as you line the walls differently with either taper edged or straight edged plasterboard.
You know there is only one way to answer that on an open forum, so why ask?
Trench for ASHP pipework, electricals - tips?
JohnMo replied to oranjeboom's topic in Air Source Heat Pumps (ASHP)
I didn't post it direct just in reply to another post. Been looking and I didn't photograph anything either. -
What company will tell you what size pipes, ASHP?
JohnMo replied to CalvinHobbes's topic in Air Source Heat Pumps (ASHP)
Thought you building a passivhaus or close too. Sounds like you are being quoted for a ventilated shed. -
What heat pump are they buying that costs £10k for a new build? And yes it is normal for any trades people not to pass vat to yourself. We had materials way in excess of £10k plus vat. If you are paying stupid prices like that get it MCS certified and let them claim £7500 back from the government. No idea what they do about vat returns don't really care. They aren't allowed to pass on vat to yourself under vat rules.
Ashp enough guts to power a shower?
JohnMo replied to vincrscotland's topic in Other Heating Systems
Don't see any issues our shower is twice that distance away. 8m and a rise of about 3m isn't much. That seems odd, was he a plumber or a random person off the street? -
Don't need MCS for anything solar. Unless specifically asked by a supplier, keep quiet. It may get complicated otherwise.
Front of shed. Rectangular box is where pipes exit shed to go underground, the come back up by the cream watering can. -
1. Sounds ok 2.yes and yes 3. I built my own insulated pipe, 110mm flexible hose, 28mm Hep2O and 25mm wall thickness black closed cell foam, had loads of aluminium tape, so taped over the insulation before inserting into flex duct. The ends of the Flexi duct I used stainless steel mesh foamed in place to stop rodents etc. About a 1/10th the price of bought stuff and does just a good a job. I placed mine ASHP behind a shed (insulated) and log store, so ran some of the distance in the shed, and the power supply etc were all housed in there. Near constant flow of air through the log shed help get the wood super dry. Back of shed -
Really not even sure you need to use weather compensation on a passivhaus build, ours isn't and it just added no value running wise. Also found that even though the heat pump can deliver 25 degs, you actually have to run 28 to 29 as the floor doesn't cool enough to allow the hp to restart after a heat cycle. Two options 1 Batch charge floor on time of use tariff, set flow target about 30 to 35. 2 Run with a low hysterisis thermostat (0.1 Deg) such as Computherm Q20RF as a single zone flow at 28, the low hysterisis will stop overshoot and undershoot. Both I would do on a fixed flow temp, or a slight WC starting at +3 Deg add 3 degs to -3 to compensate for defrosting. Simple is best. I started with 7 zones, now have 1 Had a buffer - now I don't Had a mixer and pump - now I don't
As mentioned above materials installation etc by a trade company are zero rated for vat. You get the bill just the same as anyone would, but everything is zero rated vat. Same is true for labour only. Material only you pay vat and claim back. On our build I did all the plumbing except gas boiler, which I supplied, plumber came and was a time for labour only bill. They had no responsibility except gas safe compliance and initially commissioning boiler. If you want the plumber to 'design' and install, you really need to let them also supply also, then it's their fault if things are not as expected, any other way it's your fault because the stuff you supplied was wrong... Or design yourself and supply and the plumber is just a pair of hands doing labour.
If you store at Heat pump temps (48 deg) your standing losses are extremely low. Your boiler efficiency improves with lower return temperatures, actually heating the water up 5 degs will drop boiler efficiency so be careful on that side of things. The UVC cylinder will require all the G3 bells and whistles, as the volume in the cylinder is a trapped volume, so will be pressurized to incoming water pressure. Because you are feeding to an additional heat source doesn't change anything, with respect the design premise of the cylinder. I would use the cylinder as a normal UVC and let it supply your DHW only, set your boiler as priory demand hot water via the central side. To keep things simple just up the central heating flow temp a few degs at a time until you get the cylinder up to 47/48 degs. If you feel you have excess PV during winter pass the return water though a simple Willis heater. Why, 1. central heating not on in the summer when you have lots of excess PV so everything excess can go in to DHW 2. Preheat to return leg of the boiler will drop boiler efficiency throughout whole heating season, when not much excess PV is available. If you do have plenty of the PV in winter excess, use a simple Willis heater. 3. Even upping the central heating flow temp to allow DHW heating with keep boiler inside condensing mode. 4. You need to do G3 regs so do it for proper DHW. 5. Preheat water requires additional diverting valves to stop boiler firing every time any hot water tap is opened. 6. UVC cylinders are way better than combi for water delivery time and flow rates 6. Its simple
What do you think of the passive smart thermostat?
Not sure how it sets flow temp or if it can? Optimised start and stop is available on a several thermostats (Salus SQ an WQ series for example)g, so not really seeing any advantages over a £60 thermostat. It saves x% is meaningless rubbish in rubbish out, with facts to back it up. Weather comp or batch charge on time of use tariff, for good running costs -
Warm flat roof - builder installed 100mm insulation only
JohnMo replied to Jit83's topic in General Construction Issues
Tell him to as per drawing nothing else, if he has to redo at his own expense, that's his issue - he should have read the drawing. 2 layer of 100 and 50mm on top is ok. But do vcl it as per drawing.
