Everything posted by JohnMo
Warm flat roof - builder installed 100mm insulation only
JohnMo replied to Jit83's topic in General Construction Issues
What do your drawings specify? - he should be building to the drawing not make it up as he goes along. -
Or fan coils, more expensive but you never have to run above 35 degs and you only need them in the main living spaces, design bedrooms for 19 degs not 21 and a smaller radiator will do.
They may not be more energy efficient as far as frames are concerned, so make sure you know what you are actually buying. A good frame with a good double glazing unit will be Uw 1.2 the same glazing unit in a bad frame could be Uw 2.0. They will quite two figures Ug and Uw the g just covers the glazing - W covers the whole window heat loss. We renovated an old house in a conservation area and we were not allowed to install uPVC. So check before you buy.
Basically you need a new EPC or SAP report when you first build or then go on to alter the fabric of the building. Nothing is blindingly obvious. A lot of SAP reports can be shite in, shite out, so make sure they use the correct assumptions i.e. check. Not sure what you mean by a '4' as EPC ratings are A to E?
I hope it doesn't burn in my Durisol blocks also, surrounded in concrete and woodcrete (which doesn't burn)
Cooling may not be very effective with radiators as the water just stays at the bottom of the radiator. A thermostat when in heating or cooling mode just switched it's own logic for call for heat. You need a setting change in the heat pump to make it cool. I would reset to your original settings, those settings are for heating, I suspect the 25 degs is min flow temp. When in cooling mode the parameters change to ones suitable for cooling. Some heat pumps are sold without cooling as standard, but all can do it, some need additional bits to make it work. Mine needs a zero volt switch to move it from heating to cooling.
Best electrical back box for ICF
JohnMo replied to freshy's topic in Insulated Concrete Formwork (ICF)
I did a 50mm service void, so just a big standard one for plasterboard. -
No it's definitely not a a DPM of vapour control. It keeps the screed from going under the insulation and stops hydrogen being produced by the contact of aluminium and cement, leading to lots of small holes in the surface of the screed. To save going so deep just dump the 100mm EPs and use 50mm of PIR instead. So you have 2x layers of 100mm PIR. Save you 3m3?
75mm/90mm mixed diameter manifolds
JohnMo replied to Sparrowhawk's topic in Mechanical Ventilation with Heat Recovery (MVHR)
https://www.epicair.co.uk/products/ae48c-dbox-adaptor Instead of a Y piece use one of these, duct in and the other vent use the second termination point. https://www.epicair.co.uk/products/ubbink-ae48c-valve-adaptor-90-degree-125mm?pr_prod_strat=jac&pr_rec_id=e37282fe1&pr_rec_pid=4581960974424&pr_ref_pid=4581960417368&pr_seq=uniform -
Buy by the lorry load is the cheapest and direct from the quarry, not the builders merchants. Bags have a bagging fee in the cost, builders merchants just get from the local quarry and add profit and a bagging fee.
I would look to use something like RockWool Flexi. It's nice and dense, easy enough to cut and squishes into uneven gaps. Plus it's not massively bad to work with. Another is Knauf Frametherm 32. Similar to above not quite as dense.
The window at the opposite side of the shower. So you have a 1200mm long shower base? From what I can see in the video your shower configuration doesn't match the instructions of the linked shower screen as that is supposed to have 3 walls around the shower? Maybe it.is and just don't see it from the recording. Is that what you have?
Looks like you have a top rail not installed - looks to be a bracket there, but attached or not being used. Is the window opening the issue?
Never realised there were regional areas, not sure I would bother using them anyway, just use the technical areas instead.
Well done retrofit with decent amounts of insulation 😃 make sure the insulation is gap filled with expanding foam and all joints are taped. Not really sure what the heating grid brings to the party though, I would delete it, replace with polythene sheet (separation between the aluminium foil and cement in the screed) then use staples to hold the UFH pipes in place.
Do you have a plot? Either way you need a design that is fitting for the location. There are several ways to go about a project and it's a balance of time, cost and value. Also of consideration is house price ceiling where you propose to build. Centre of London you can spend what you want and still make a good profit. Where we are there is a price ceiling, so we had to be careful with our design and build cost.
You take it through the house as shown by the photo by @nod. And your middle drawing (lintel). You then take it into an inspection, use the chamfer to get the drop you need. We have several chambers and drop about 2 to 3m.
Repurpose gas combi for hot tub (analysis/shortlist stage)?
JohnMo replied to NIMAN's topic in Boilers & Hot Water Tanks
I did -
Think you are over thinking things. Why do you need to tell BC anything about the hot tub? Only inform them on what they need to know - no more, no less. Your post was too long, you are over thinking a lot. Your combi needs to be in an unvented circuit, so it gets a permission to start. Get yourself a plate heat exchanger - cheap enough on eBay. Plumb your primary circuit to the primary side of the PHE and the hot tub to secondary side with a circulation pump. Use a thermostat and timer on the hot tub to heat as and when you want. Set the heating side flow temp to about 40 to 45 so you don't boil yourself. But a return water pipe stat on as well set to protect you should things get a little hot without you knowing. -
That's not really the issue G3 protects against, it's the phase change to steam and the expansion of circa 1500 times and the resulting side of the house turning to rubble.
Never experienced just a single circuit tripping, normally throws the whole board off
The drawing shows the long L shaped room need supplemental heat, could see any others that do. There is a calculation sheet you can print out in LoopCad, it shows all the room by room details including what is required heat wise and being supplied and temperature and flow rate etc.
F-Gas certified is for refrigerant, gas safe is for natural gas. Not all MCS certified techs (they are not Engineers) do not need to hold F-Gas certification, so probably don't. Monobloc ASHP always come pre filled with refrigerant.
