Brickie
Everything posted by Brickie
You're losing me here-are you proposing to build the entire job with block coursing at different heights on adjacent flanks?
Mmm,transferring levels like this isn't the best-if you're levels slightly out then you're not getting a true reading,then you've got slight human error (could read the bubble slightly wrong) which accumulates every time you move your steel. If you don't have access to a dumpy or laser level,I'd buy a water level. Don't think they're dear & are very accurate.
Are you using thermalites below dpc?
Does your Dpc level on new build match that of the existing? Your build is all rendered,isn't it? If yes to both-I'd chop out a brick straight above damp at the point where new meets old & just lap your new dpc onto the existing one.
Check with manufacturers but I believe it's 9m for block work. You want ties every course either side of the expansion & de-bonding ties with sleeves every 450mm vertically. Sometimes an exp joint can work to your advantage in terms of breaking up the run into more manageable sections. Can whack a profile up it & away you go.
Control of suction is critical to avoid cracking,as has been said. If it were me I'd look into using a lime/cement/sand mix both for the build & the render & be sure about your positioning of expansion joints. Hiding one behind a downpipe is always good,if possible.
Why on earth didn't they mark the joints into the render a la Ashlar Markings system??
Apparently,Storm Doris caused Hull several million pounds worth of improvement.
Starting again is serious money-all the more reason to seek alternatives. Any future re-insulation is still going to have the issue of breaching dpc. If IWI is a no go then maybe air bricks would help? if there are no issues anywhere else than one bedroom,have other causes been ruled out? is the house in an exposed location?
Might be worth getting professional advice on whether weep vents might help. As it's already built,perhaps drilling 10mm holes @450mm centres in the bed joints at say,dpc level,1st floor & then eaves might alleviate the problem. Just throwing it out there..
The 'Installation of the Wireless Hub'?
I want to make a brick. How hard can it be?
Brickie replied to Construction Channel's topic in Brick & Block
Why not build it in your workshop out of red rubbers & carve the design you want? Must be untold youtube videos showing how it's done. -
Easier in what way? Are you having dot & dab plasterboard on your internals? if so,no chasing out required (afaik).
Telescopic vents in a garage slab???
Brickie replied to Vijay's topic in General Self Build & DIY Discussion
Don't know much about CAD but I'd guess he's copy & pasted from a beam & block floor detail & altered it to show your solid floor. No reason I know of to have it in your design. -
Can't you set your level up in the road,knock on the neighbours' door & ask to take a reading off their floor & transfer it then?
So-are you trying to establish what height your neighbours air brick is in relation to their own ffl? Most of the time on housing developments the air brick would be laid in the last course below dpc so,by rights,top if air brick should be near enough ffl. If you follow the height along the wall to a doorway that should help-doors are traditionally sat straight on dpc level (until very recently when the fashion for level thresholds & patio means dropping the frame down one course. )
How to clean brickwork of hearth/chimney?
Brickie replied to TheMitchells's topic in Stoves, Fires & Fireplaces
For an un-lined chimney,we were taught at College that lime was inadvisable as it reacts with the products of combustion to the detriment of the structural integrity. From demolition experience,I can tell you I would clean mortar off bricks all day from a stack-virtually clean themselves. -
Unless you live in an exposed location & are planning on doing the insulation yourself,I'd give serious consideration to using full fill insulation. Trust me-the finished job you'll get if the builder fits the insulation will give you a lower insulation performance than on paper. The care & attention to detail needed when fitting is beyond 99.9% of bricklayers,honestly. With fulfl fill,you're more likely to get what expect.
What about a render skirting? just a thought
- 56 replies
- skirting
- floor tiles
(and 2 more)
Doorway in solid wall to brick up
Brickie replied to Calvinmiddle's topic in Bricklaying, Blockwork & Mortar
Depends how much value you put on your own time. To drill & fix wall starters or individual ties versus too thing out & packing mortar in-I know which I'd go for! -
If you use lightweights I'd go one step further than Declan suggested & Eml across the lot,to help prevent cracking in the render. Wall starters on both door reveals,too. -
No good for me with my hip replacements :))
Diesel in the bucket's what I was told. For a more Eco approach,maybe some of the enviro-friendly washing up liquid could work?
- 19 replies
- digger
- techniques
