Everything posted by Pocster
Wisely I installed one of these so I can drain the outlet pipe from macerator . Had a few times where I need to drain it . Problem is this cap leaks - it’s just a screw cap with a washer . I’ve tightened with grips but can’t really go any further . Are all end caps equal ? . Nothing I can smear round the thread that will make a water tight seal but won’t glue the cap on !!? . I did think of plumbers tape - but it’s too awkward to get to …
badly scuffed UFH pipe - repair or leave?
Pocster replied to Tom's topic in General Self Build & DIY Discussion
Ffs . These are the ‘professionals’ yes . (expletive deleted) me … 😵💫 -
Replace . Is op planning to tile this floor ? I.e no chance of ‘easily’ fixing later if a leak … -
Supporting 250kg steel beam on nothing?
Pocster replied to knobblycats's topic in RSJs, Lintels & Steelwork
I’d crane that in . Have before . Otherwise it’s a heavy mofo situation -
Acro props . Cheap to buy - with some wedges so they don’t drift . I had to do this for a large concrete ceiling . Rather than hire 50 of them I bought them . Left them in situ for 3 months - SE said 1 month was enough . But you know …. -
Looks like someone dropped their nuts through the floor twice .
So clean any grit etc off then just spray the entire track ? ( not just the wheel runners ) .
Sliding doors at the rear have become very difficult to open. I assume grit etc. is causing the issue. How should I clean this to get a smooth action again?; just tip water over track to flush out grit?; wd 40? Cheers
Far too neat for my liking
Just a thermostatic mixer off the UVC. Plenty of power ; no issues ( with shower or uvc/ashp for that matter ).
Flexi’s can fail for no obvious reason . Agree some must be better than others . Now ( after experience ) I only use flexi where I have too - do a visual inspection every 12 months for any sign of decay / leak . My new kitchen I installed copper rod fittings . I feel happier about that .
Checked it just now and it’s off ! Turned it on off a few times and was fine …
Ceiling Speakers Recommendations
Pocster replied to richo106's topic in Networks, AV, Security & Automation
Yeah - a pita . changed all IP’s instead .Messed up lots of things - but almost back to 100% now … -
Just installed a new dimmer . Never noticed this so assume the problem wasn’t there after install . Turn lights off ; 1 light stays a bit on . Notice it’s last and first to power up before the others . Led failing ?? Photo of lights off
Take my new robot vac . Couldn’t get it to connect to my WiFi. No idea of the issue - no error message except fail Googling … only apparently connects to 2.4gz not 5 . Mines both with band steering . So I disable 5ghz - still doesn’t work . How would you explain how to do that to someone without a lot of detail ? Google more . Apparently for reasons unknown doesn’t like a router address of 192.168.8.1 - exactly what I have . So I change that ; which naturally breaks everything else . Explaining how to do that would be very difficult if the person you are explaining it to is just following your commands . That thought gets it working ! - shame everything else is bust though due to router IP change … -
No it’s not difficult. But that depends on your knowledge and understanding of these things . People think sometimes you can write a step by step guide that you just follow . But you can’t ; as there are plenty of unknowns and what ifs . Router config , firewall , ip address setup etc. etc. There are video guides online . But again if there’s any variation in what you have to the video and you’re simply copying the steps ; then it might require a fuller understanding.
