Pocster
    29
Everything posted by Pocster
  1. Yep mine are TG . Some years ago but was around the 25k mark
  2. We have 2 of these similar size and weight . Company stated they would crane them in ( need to go underground so an extra complication ) . On install day they moved them by hand with a lot of manpower . I indicated how (expletive deleted)ing ridiculous it was and left them too it .
  3. One day someone will say that to me . On that day the world will end .
  4. I know ! But these are the ‘equivalents ‘ - could t find the real threaded ones
  5. Pocster
    Dimmer issues
    It’s dull . Say 25% of max . Doesn’t always do it though . I believe capacitor can be fitted at the switch . Neutral to earth ( or something like that …. )
  6. Pocster
    Dimmer issues
    Led bypass ; is that what’s needed ? 🤷
  7. Pocster
    Dimmer issues
    It’s on again !!
  8. Ok ! Then you have my blessings with your build !
  9. Awesome . Do you need : decoupling mats ? Mega tile cutter ? please say yes - not far from Briz … 😊
  10. For other readers . That black square it to hide a disgusting image 😉
  11. All done and moved the 160kg fridge freezer into place .
  12. Got really (expletive deleted)ed off with this . All the videos - it’s real simple , no effort . Decided it was time for pliers - pulled the (expletive deleted)er apart . Tiny white clips came out with pipe . Ffs
  13. New filter has slots - like a Hep2o disconnect key …
  14. These end caps are meant to go over the end of the filter then according to ‘easy’ videos you just push in and pipe slides out . My end caps have a thread whilst the filter doesn’t ….
  15. Can’t get this out . Blue clip off easily enough . Depress what ring ? It’s solid plastic . Pipe won’t just pull out … removal tool required ??
  16. If only ; I could claim 11 yrs of Labour …
  17. Glass ; don’t talk to me about glass …
  18. Only on Fridays at the blue parrot
  19. You’ll be fine . As an expert on glazing situations you can trust my judgement. I’ve over 11k of posts and 3 followers ( what is wrong with these people ) - so can safely say I’m not a troll . 🤣
  20. Facebook ‘randomly’ showed me this . Looks interesting … https://cozyhoome.com/products/silicone-thread-seal-tape?variant=48130347630866
  21. I did .
  22. And as if by magic I appeared …
  23. This end cap drain is right on the macerator output . So I assume bit of water pressure and vibration aren’t helping - or should an end cap ( with suitable washer ) be sufficient anyway in this situation ?
  24. Yeah it’s a skinny washer . Very thin . Not brittle or split . I’ll order a new end cap with washer . Replace and see . I did assume hand tighten was meant to be sufficient.
  25. That’s what it has already . By pure luck I bumped into a plumber and just mentioned the issue . He gave me a tube of this …. This do the job ? Ok to use ? . Not glue it !!?
