Thorfun
    36
Everything posted by Thorfun
  1. @Nickfromwales. qq. i have one shower waste that runs in a straight line to the soil stack that is 800mm away. do I really need to upsize that waste pipe to 50mm just for that short distance? seems a bit crazy and introducing extra joins for the reducers at each end for such a short run.
  2. You might change your mind when you see the price of it!!
  3. quote seem reasonable. I'd suggest getting the supply to a kiosk at the site edge for you and attached to neighbour's wall to get rid of both those overhead cables. you can then run from the kiosk underground in to the house as you've suggested you'd prefer. as to the 3-phase/single phase question I'd suggest that's a matter of preference. if it wasn't for the neighbours overhead cable I'd say 3phase is a no-brainer but I would really want that neighbour's overhead out of the way and so it looks like single phase for both properties and chance your luck with a G99 application. so option 5. for £800 to get rid of that cable? I wouldn't even hesitate!
  4. actually, it had nothing to do with any existing contamination but he was worried about the ditch overflowing and potentially contaminating the water supply. i thought it was bollocks but if i wanted my water supply fitted then i had to comply. luckily it was at the beginning of the build so i actually had money. 🤣
  5. here are some of ours. pretty neat and wasn't too much of a pain getting the clips screwed in. I also attached directly to the top and bottom chords. harder to screw in but I bought one of these which was a massive help! https://www.screwfix.com/p/dewalt-extreme-1-4-hex-impact-right-angle-attachment-160mm/354px
  6. our posis are 45mm thick so on clips direct attached to them in either B or D would make them in the 'safe' zone, i.e. 50mm above/below
  7. I put mine wherever I could fit them while trying to keep it neat. some I’ve also just cable tied to the metal webs. I didn’t add extra supports like you’ve shown though. I just screwed the clips directly to the posi-joists. I have pictures if that will help let me know. Once you get going though things just seem to work out.
  8. Our water company said we had to use barrier pipe due to risk of contamination as the pipe runs near a culvert. That’s about 10x the price of standard MDPE. Had to pay around £500 for 50m of 32mm. 😭
  9. after doing all the insulating and airtightness regime for our timber frame I can tell you that, even though we saved money, the time it all takes to do well is a lot! so for me it's well worth sticking with the MBC passive house cellulose filled twin-wall system. if your budget will stretch that is. it's not a regret for me as we'll have an amazing house but I do think sometimes that if we didn't build the basement we'd have been able to afford the MBC twin-wall system and would've finished and be in by now! but, on the flip side, I know for a fact that every nook and cranny is filled with insulation with no corners cut.
  10. welcome! sounds like an interesting project. spend hours a day on here reading all relevant forums and enjoy your journey down the rabbit hole. 😉
  11. we found when we were investigating windows that 3G were about 10-15% uplift over 2G so for a new build I wouldn't really consider 2G at all. I'm sure it won't be long before building regulations mandate 3G with a drive for greater efficiency of houses and so I'd put 3G in now rather than worrying about being out of date at some point and having to replace the lot! just my 2 cents. ps. @ToughButterCup's house is definitely a great looking house!
  12. black CT1 under the lifted tiles and then held down until it went off. it's not perfect but you can't really see it from the ground and no one who has ever looked around our house has said "those tiles look a bit dodgy!" 🤣 tbh, I'd actually forgotten about this until this thread resurrection. it's amazing as people who have already built say things like "don't worry in a year or so you'd have forgotten all the bad stuff" and at the time I think "but it's a massive issue! how could I ever forget about it?". and it has come to pass that I've forgotten about it so all those wise folk were right. try not to sweat this little stuff that seems massive right now! looking at your Instagram posts your place is really coming along and it'll be amazing. don't sweat the little stuff as in a year or so you'll forget all about it. 😉
  13. yeeeee-hawww! 🤠
  14. I agree. Was just wondering how much of the “good quality” stuff is all marketing b******s as it’s all the same stuff.
  15. It’s above the larder so not worried too much about noise and I’ll stuff Rockwool in the dropped ceiling anyway. If noise is the only issue then I’m in the clear!
  16. It was more the vertical drops. Not sure if that’s a bad thing or not! But, tbh, not sure how I could do it without them.
  17. Looks good to me! I don’t think you can have too many clips.
  18. Could work, thanks. Will consider putting 50mm back on the table. once I have confirmation that my waste run plan is ok I can plan the parts I need.
  19. need to get my master bed en-suite waste sorted out. I don't have a lot of space as directly below the area is our MVHR manifold and there are loads of 92mm MVHR ducts, electrical/network/home automation cables and water pipes below! it is tight. I'm thinking of running the waste like this (please excuse the rubbish 3D drawing but hopefully with some text it'll make sense) so, we have double basins and I was going to run one horizontal (with a slight fall) to the other and then straight down to below the floor boards (about 800mm I guess) where it will run for a bit between the posi-joists until it can go 90° down where it will run under the posis and then turn 90° to join the waste from the shower. The basin waste will be run in 40mm solvent pipe. The shower waste will go sideways and then almost immediately drop down about 300mm where it will run horizontally below the posi-joists picking up the basin waste and go into the soil stack via a boss. I really wanted to run the shower waste in 50mm pipe like @Nickfromwales told me but I'm really thinking that 40mm would be simpler to get the fittings for the basin waste to join the shower waste if it was all 40mm rather than getting a 40mm to 50mm swept tee. anyway, are those waste runs ok? with those bends? it really is very congested underneath so I'm thinking this is my best bet. here's a photo of the mess that is in those posi-joists. and with annotations! I also need to get the bath waste to that same soil stack but that's a whole other story. 😞 so, long story short, any concerns with that waste run? it 'seems' ok to me but I've been wrong about my plumbing so many times before I would like to get the opinion of those that actually know what they're doing. ps. forgot to mention that I am building a dropped ceiling below the posi-joists in the room the photo is of (it's the larder) to cover up the MVHR pipes and manifolds. this is why I'm able to run the waste below the posi-joists.
  20. we have Norrsken windows. very happy with them and the service and install we got. install was handled by Norrsken so everything was under the one company. think we were nearer the £600/m2 iirc but we've been through so much since they were installed Dec 2021 that I forget things that have gone before! I did write a blog about our windows though. you can see it here.
  21. how do you know what is good quality? surely they're all made in the same factory in China?
  22. Our tiler said to get 100W/m2 mats. Been looking at the Warmstar ones from eBay that others have on here.
  23. not sure I'm qualified to state whether they should or shouldn't. I simply put the edging strip everywhere! every door, wall, partition etc whether they were internal or external. anywhere the screed was going to touch a vertical surface. our screeders also said expansion joints were necessary to reduce cracking. I put 6mm hardboard across the doorways which they said was fine.
  24. Screwfix stock it. https://www.screwfix.com/search?search=perimeter+edging+strip
