Thorfun
Everything posted by Thorfun
And we were ok with that as the toilet is far enough away to not get wet. It’s the entrance to that area that’s the concern. But not for water as that’ll dry relatively quickly with UFH and MVHR, right? It’s more any sort of slope to get to the loo.
@Nickfromwales are you going to tell me that @pocster is ACTUALLY right for once? Jeez, what’s the world coming to! is a door the best solution? I can fit an 1850mm tray but the slope will be where you walk to the bog.
Why’s that?
I prefer to use language that infers death as the outcome to let her come to the conclusion. I find it has more of an impact as the ramifications slowly dawn on her. I'm just not a sledgehammer in the face kinda guy.
cheers. I have a browser tab open with drench.co.uk on, just haven't got to look at it yet.
just showed her a ceiling pole and she agrees that they don't look good. I showed her thinner bars and she's ok with them now. I also played the 'safety' card and we don't want screens wobbling or falling on the kids in the shower and she has agreed to use bars now! 👍 is that enough hair for you?
sage words of wisdom as always. she is happy with ceiling support and I've found some screens that have optional vertical support to attach to ceiling so that might be an option. the research continues.....
interestingly this screen doesn't have a bar and no mention of needing to fit one. https://www.victorianplumbing.co.uk/arezzo-800-x-1950-square-matt-black-framed-8mm-wetroom-screen?categoryId=72890a41-577b-478d-bbe9-fb1474346ac3-2DF7:en-GB so I guess it's possible to not have a bar!
so no bar for you then? how wide are your screens? and what thickness?
from the bar or from a.n.other cause?
To Tank or not to Tank? bathroom advice required
Thorfun replied to TryC's topic in Building Materials
actually, thinking about it some more and (completely monopolising this thread now) is it possible to do a hybrid solution with the Impey membrane on the floor and a liquid membrane on the walls? that way you get the benefits of the decoupling mat but also not the expense of using the expensive membrane on the walls. -
thank you. don't suppose you have a photo of how it's held in do you please? we only need 800mm max screen. any wider and the kids won't be able to get in to it! 🤣
further to the above I've re-read this thread and your post where you extol the virtues of the Impey system albeit a bit of a pain to install! -
hi @Nickfromwales. I'm researching tanking for our shower areas at the moment. we are going with impey aqua-dec formers. I know from reading other threads that @ProDave used the same trays with the aforementioned Impey membrane kit. I'm curious as to know if you think the Impey solution is still expensive when you consider it is also a decoupling mat for the tiles when compared to a paint on solution with a separate decoupling mat? Also if we're going to use the Impey UFH mat on the former (which I believe is possible) it says that their tanking solutions works perfectly well with their electric UFH and that their UFH mat is thin enough to not affect the level of the tiles to maintain a level floor throughout. what say you? -
next question! glass for the kids' showers..... what thickness is recommended? the wife doesn't want a bar going across from the glass over the shower. what are our options? vertical bar to the ceiling? glass from floor to ceiling? is there a maximum glass size where a supporting bar is not required?
have discussed this with SWMBO and we both agree on the 1100mm former with the flat entrance area. only time will tell if we made the right choice!
anyone got any opinions on the shower former size we should go for here please? i'm keen to get them ordered and in place as i need to finish plumbing first fix so i can get boarding! i'm leaning towards having the slope of the former start at the entrance to the shower end. so about 1100mm and having a flat 'entrance/landing'.
it's a good question! we like the idea of keeping the toilet and shower 'hidden' so it's like a secret gem behind a wall. also the bath will fit perfectly between the two walls so we don't have to worry about blanking the end of a bath etc and it will also house the towel radiator above the bath.
thought it might be best to put a plan view of the en-suite up to show the proposed layout. dimensions are not accurate as we extended the bathroom 400mm to give more space between shower and toilet.
we have discussed shower trays etc but are happy with a potentially damp area of flooring for the aesthetics of the wetroom look. i'm sure it'll be fine. 🤞
that is definitely a risk but the shower heads are 1.8m from the toilet so any shower splashes should be minimal. also we will have electric UFH which should assist in helping to dry out the floor. and MVHR extract of course. this is the design our architect came up with and we're too far down the line to change it now so it's the space we need to work with.
basins will be on the camera side of the stud walls on the left and a bath on the right. yes, flush with finished floor in a wetroom style. 🙂
can you go liquid screed at 50mm? would give you an extra 20mm insulation. we have Cemfloor screed and it's so quick to pour and can work on it within 48hours and tile after 4 days with no laitence to remove. if you're stuck with 100mm then as was mentioned above the Kingspan phenolic insulation will give slightly better performance that normal PIR.
