joe90
    139
Everything posted by joe90
  1. I have never plumbed a quooker tap but is it not supposed to be connected to the copper pipe? It looks awful really, get them back ASAP.
  2. Some integrated dishwashers don’t have a kit, but should have instructions, which 4 or 6 screws you remove holding the door inner panel and replace them with longer (supplied) screws that go through the door and into your front panel, some can be a pain to line up tho. (Not heard of that make tho!).
  3. Yes these are standard braces, you will have to wriggle your noggin in and screw in from the backs .then screw plasterboard to it/them.
  4. http://www.limerestoration.co.uk/why_lime_mortar_render.html
  5. Sounds Australian to me, wot I said originally cement out, lime in. Breathable.
  6. (But it’s not finished yet or had you not noticed?)
  7. would it not be prudent to tile the floor before you fix that tile? ?
  8. joe90
    Ah bum !
    That’s what I fecking said ?‍♂️.
  9. joe90
    Ah bum !
    Try a foam roller first.
  10. Ooh er, level playing field?
  11. joe90
    Help
    I hope he is amenable ?
  12. Why the Feck didn’t he just say “your pipes need to be insulated “ to pass???
  13. NO!!!!! But he needs to insulate his pipes!
  14. joe90
    Ah bum !
    Looks like a vinyl paint to me, have you got any more, left over from the spraying?
  15. joe90
    Ah bum !
    I might tend to peel any paint off that’s not stuck, loads of paint on the plaster (many coats) which you can then sand back to match the sprayed paint, them maybe a mist coat sprayed on to blend it in..
  16. joe90
    Ah bum !
    Sand, paint, sand paint, repeat with a fine roller (or cover your walk on glazing).?
  17. joe90
    Help
    Yes, if those vents line up the outside concrete is about level with the wooden floor!!!. No step at the door etc.
  18. joe90
    Help
    I,m with @MikeGrahamT21 above, where is the damp course?, is the outside ground 150mm below damp course, that brickwork looks sodden!.
  19. Yes I would. It also means the other tiles remain flat as it’s a constant level to work from.
  20. You’re tiles, like slates rely on double overlap to carry water that gets between tiles/slates as they have no “joint” between them. The bottom row of half tiles should be cut at an angle so they are under the bottom valley tile “joins” but some rely on lead instead/as well.
  21. Welcome Kes to THE forum, well like you I did renovations for years before my own self build only took 45 years of waiting ?.
  22. But aren’t we trading under WTO rules with others anyway? And the EU pay that tariff fir our stuff.
