Everything posted by Conor
In winter, during a prolonged cold snap, it's not unreasonable to assume you could be consuming 20kWh a day. And your PV could only be generating 1 or 2kWh. 2kWh (based on my 5kW producing as low as 200Wh on a dark day in November and December.) You'll need an alternative power source. Re the mortgage issue. You'll potentially run across this every time you remortgage, and will not get the best rates. Also, what if you want / need to sell in the future? How many people are prepared to pay full market rate for an off-grid house? Finally, you'll be way, way, way over producing in the summer with all that electric going to waste. If it were me, I'd still go for a decent array, but get the grid connection as well. I hope you can get the price down.
Building plot conveyancing fees?
Conor replied to flanagaj's topic in General Self Build & DIY Discussion
Just the same as house conveyancing, we paid around £1200, but then a few extras (indemnity policy, extra searches) brought it closer to £2k -
Do I need planning permission? - Conservation Area house
Conor replied to NoviceDIY's topic in Planning Permission
Almost certain you would for cladding and balcony. And quite possible uPVC cladding will be rejected. A lot depends on local context. -
There's a fair bit of time pressure actually as the thing is fully visible from the road and we're using it to screen the garden from the road. I'd be aiming to get the frame and cladding done over the Easter break, so 3 or 5 days. Hiring does make more sense and I can't see myself really needing it again. £45 for a long weekend hire, makes lots more sense than £300 for a new machine that I might never use again. https://www.balloohire.com/product/equipment-hire/finishing-nail-gun
Watched a video where you basically build a 4x2/3x2 frame all around the container, with bolts at the corners through the lifting eyes into ply board blocks so you don't fix through the container at any point. I'll be fixing into 3x2s at 600mm centres, horizontally. (Instead of the domino clamps which are £80 a pop, I'll be making my own out of treaded rods and routered wooden blocks.) I'm also planning a GRP roof with sedum on top, with large overhang on one side for a potting area. That side will also have a living wall.
thanks Russel. Hadn't considered nail finish, but happy would be happy with lost /part buried head rather than having a head on display.
I'm planning on cladding my shipping container with an alternating widths mix of 25mm thick softwood. I'll have thousands of fixing pints, don't fancy doing that with the impact driver. What kind of nail gun would be best for that and also things like fence panels, decking etc? I've a Makita collection but don't see anything suitable in their range. Something like this gasless first fix gun work? https://www.powertoolworld.co.uk/dewalt-dcn692n-xj-18v-xr-brushless-1st-fix-framing-nailer-body-only?srsltid=AfmBOoqwQGfkNGoyVZQk24KRdVQDvKzm6mnDr2idh6UWV_EFg9j5tvRijTY
Just don't over twist or kink them. Or over tighten. They usually have rubber o-rings and don't need much more than hand tight.
My mate owns and runs a ground works company. His mates rate for him and his machine and accessories is £55/HR. Worth it. I do some diggering, and I'm planning doing some grading, garden wall founds, and landscaping next week. Will be about the fourth time I've hired a machine for a week or so. You do get the hang of the basics pretty quickly, like skiing, but I'm not tackling a black run any time soon. He can do at least twice the work I could do in a day, and far higher standard. Same as any trade really.
Measuring for composite front door and threshold design
Conor replied to Novice Becky's topic in Doors & Door Frames
You really want the company supplying the door to do the measurement. It can't be that hard, fairly standard in the industry. Doesn't matter who then fits it, just make sure the supplier takes the liability of measuring. -
The 15mm pipework and stop tap on the incoming supply will be a bit of a bottleneck. I'd replace the old lead pipe, probably encrusted and causing a fair bit of friction. Check your water suppliers policy, it should be free on the site if you replace yours ast far as the boundary.
Nice. All that south facing glazing is going to cause overheating galore in the summer. Its about the same as we have so I know all about it!
badly scuffed UFH pipe - repair or leave?
Conor replied to Tom's topic in General Self Build & DIY Discussion
I feel your anguish. After nicking a pipe with a grinder while making room for a shower tray, I decided to leave it. It was pressurised, pipe didn't swell or leak. Though if it ever did leak I'd just isolate and forget about it... Only a small WC that has a towel rad anyway. However... That's significant damage. The aluminium layer is there as a gas barrier and will degrade now it's exposed. Aluminium and cement do not like eachother. -
Sunamp is a heat battery, based on phase change material, but it's still essentially a large mass that is heated by electric wires. You can just use a solar diverter on your existing tanks - assuming that the immersion element is at the bottom of the cylinder. You don't need 3.6pkW, likes of an Eddi diverter can work with a couple hundred Watts. Resistive heating is resistive heating, no matter what the packaging or sales pitch is. For heating when not sunny, you can time the tank to be heated on off-peak electric. Will be less efficient (higher standing loses) than a sunamp, but how long would it take to make up the difference based on the cost of three sunamps?!
These kind of meter boxes often have a removable tool to turn them on or off. Deep down, on the supply side of the meter, there will be a small hex, slot or square shaped fitting that is the top of the valve. Get a torch and have a look down there.
BCO was happy with my own spreadsheet showing flow rates.
The correct way to exit the property with 110mm waste?
Conor replied to Rlove90's topic in Waste & Sewerage
Change the 90⁰ bend for a long radius rest bend. -
Have you ever observed this moisture when it's been cold and dry? Like the other week during that cold snap.
The dimpled surface is the part that sits on the mould. The white patch area is where water settled during the casting process. The top surface is smooth. If the pavers are just set on compacted sand, fairly simple to lift and flip over.
Getting house signed off - Northern Ireland
Conor replied to DG77's topic in General Self Build & DIY Discussion
Same as @cwr, I asked our BCOnround for a pre final inspection walkover. Pointed out the things hat he'd want to see finalise before his inspection. Really useful and helpful was more than happy to do it and commented that he'd like to see it more often... Lots of time wasted on inspections with things that should have been sorted before hand. In the end, only a handful of issues that once sorted, a few photos emailed over were enough to get the final cert. -
Triple Glazed, preferably Aluclad Timber suppliers
Conor replied to peekay's topic in Windows & Glazing
Fyi aluclad PVC is about half the price of aluclad timber (internorm) -
Core drilling 200mm concrete wall - what kit required?
Conor replied to BotusBuild's topic in Concrete
Hire somebody. I got 5x 180mm holes drilled through 200mm RC for £250. -
Solid Wood v UPVC/Composite exterior door
Conor replied to Clark Kent's topic in Doors & Door Frames
Doors might be a small % overall, but in the spaces they are located, they can be the dominant factor. E.g. in our entrance hall, 90% of the external facing structure is a door + side light. We went for the highest spec door we available in our budget, and it's something like u0.8. In super cold weather, the outside face frosts up and inside the hall is just as warm as the rest of the house.
