Conor
    12
Everything posted by Conor
  1. Can I get your thoughts on this @Nickfromwales please?! Is 10mm throughout the best option for hot and cold outlets? And one pipe per outlet? I'm thinking 15mm of larger outlets like showers and baths? I think we have 3-4bar mains pressure here. Thanks!
  2. Here's one I made earlier
  3. As above, the brown is for underground only, black above. BC allowed me away with a small section of underground pipe above ground where it joined to a bend, all I had to do was paint it to protect from UV damage.
  4. Don't jet wash. Just brush, clean with detergent (or use fancy decking cleaner), dry out and brush again, then stain. I'd avoid the glossy type decking paint as it never ever lasts. Just use decking stain. I'd suggest a dark grey if you want a change from the brown. You'll have to go darker. Looks like what is there already.
  5. Anybody have a detail drawing on how they did this? We have effectively 175mm outer skin of ICF (75mm of the actual block, 100mm additional EWI). Architect has suggested a strip of compact foam along the underside of the door frame. DPC below this to meet the tanking on the outside. Door sill to be extended over all of this. NB basement below. I'm doubtful that the 175mm of ICF could sufficiently support a foot traffic aluminium sill? Could I bring the compact foam all the way out? It's not cheap stuff.... Any other suggestions? Lose the additional 100mm EWI at the doors?
  6. How are you going to safely inspect and change the filters every few months?!!
  7. I'm not surprised, as I'm guessing the overall performance of the door will be quite poor. I'm guessing in around 1.8 or even worse. Make the decision then, and from somebody that lived in a similar house, there's nothing worse than a cold feeling entrance hall!
  8. Find out the overall U value of both unit options and take it from there. I think you'll be unpleasantly surprised by the thermal performance of the unbroken unit. Have you looked at aluminium or composite doors? They'll generally perform much better.
  9. Corrosion resistant, very strong, cheap, easy to install. Sounds like a great idea. And I bet they'd be really easy to clad with timber or plant trellaces. Nice big slots you can bolt through.
  10. Intumescant paint is normally sufficient. I got a 2.5l tin and wil easily do all the steels in our house. £60.
  11. How wide is the entrance? A 6m or 7m telehandler isn't much bigger than a car but much more manoeuvrable and will easily offload a bail of blocks with a block grab. It'll cost £150+ a day while a crane will be £600+
  12. Run the pipe down the driveway and then in to either the plant room or kitchen. Wherever is a sensible place to have the internal stopcock. You normally run the pipe straight with no bends / joins etc until it's inside the building and above the floor slab. Use ducting then bringing the pipe though the footings and slab.
  13. On the footpath, where it says footpath on your drawing. The boxes are always installed in the public realm unless the closestain is already in private land.
  14. And don't over use a disc... As soon as you have a notch out of it or its worn down a fair bit, bin it. An exploding abrasive disc is not pretty and the bits go everywhere!
  15. As they will be embedded in masonry that will have a high moisture content, they need protection from corrosion otherwise they will corrode and eventually (decades) fail. Your engineer would have specified this requirement. No fire protection needed as they aren't exposed to a flame risk.
  16. If those steels are in the outside course of block work, they need to be either galvanised or bituminous painted.
  17. I couldn't find any that would do both ICF and basements. So that's why I went with a main contractor as they'll provide it.
  18. The conservation officer stipulated no fewer than 12 aesthetic recommendations for our application.... From no PV panels or PVC windows, real stone instead of stick on, cast iron rainware, etc etc. Our architect rebutted every single one of them. Try and find out how bothered they are about these.
  19. We allowed a 2.5% project deposit, followed by four main stage payments and a final 2.5% retention. Seems to be a fairly common way to do it. Remember vast majority of builders have credit accounts for suppliers, so the need for any big lumps of money upfront can't really be justified.
  20. Speak to Scott at Lindab. I contacted them to buy ducting, he asked if I had sourced MVHR units, I said I did and told them the price and spec of the brink from ventilation land. They pretty much matched it (within 150 quid) with an equivalent Zehnder unit, and a good bit cheaper than BPC. It's a superior quality unit (according to my friend that is a designer and installer of various systems) and have it in stock right round the corner from me. They also did a design and a fully itemised quotation. It's (hopefully) coming in about £6k for two Zehnder Q350s and all the controls, ducting, plenums, air vales etc for our 315m² build. (Original quote was £7k, but they included the expensive WiFi units and twin 63mm ducting instead of single 78mm)
  21. The slabs work it's easier to have a "slot" than squares as you want to minimise the number of cables you lose. Your slab company will suggest what's possible. In our case, we left a few strategic gaps between slabs, and where we had a slab run parallel to a wall, leave the side of the slab short a couple hundred mm. When we've all our services though, we'll shutter the underside and pour some concrete in. I've left a gap like this along one wall of the main bathroom, so all the waste pipes, vent stack and MVHR ducts to the first floor will come though here. I'll then build a false wall in front of the gap to hide the services. Coring a 116mm or smaller hole in a 150 slab is easy enough, you just need to avoid the cables which are normally 150mm centre to centre.
  22. Yep, as above. We made numerous ducts though the walls using 110mm PVC pipes. A single opening for three services is easier to seal than three separates ones. If you don't use them, ease to seal up and cover over.
  23. I'm convinced that some people assume you have tonnes of money because of what or where you are building and just quote silly numbers as they think you'll pay it regardless. We're building on one of the most desirable streets in the most desirable town in northern Ireland... There are more Porsches than Peugeots. We are far more likely to have a Peugeot than a Porsche ?
  24. So in the summer you can have it set to DHW in the morning and cooling in the afternoon easily enough?
  25. Thanks David. I think I'll do the same then. Did you put rads in all of the rooms? We'll have four bedrooms and two bathrooms. Have you investigated a cooling setup yet? Something I'm keen to have the option of, even though it'll be rarely used.
