joth
    5
Everything posted by joth
  1. "a series of minimum safety standards [..] will be required, with BEIS holding the MCS registered installer process as one particular example." That doesn't sound like they're entirely intending to set up MCS as a monopoly on this, although I agree calling it out has the high risk of having that effect. Seems very challengeable though: the minimum standards must be documented, and it should be possible to demonstrate they are met via other means. If nothing else the onus surely has to be on NICEIC , Elecsa etc to join the game and provide accreditation schemes - I mean NICEIC already do gas certification, so why not solar PV? But really, and I guess this is exactly what your're say -- it has to meet part P standards anyway, and if it's safe enough to be legal to connect to the DNO at all, why does it need any extra certificate to prove safe enough to receive remuneration for it. And then like any other part P work retrospective certification (potentially after remedial work) seems totally plausible too. Hmmm.
  2. I guess I should join the other forum to post the question too, but in http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=12591 fostertom says "vapour resistance at this (or any) point in the wall buildup is BAD." ... "VCLs are bad news" etc Which if taken at face value means Smartply Propassiv is bad news, period.
  3. Great! Hopefully this is fail safe, in that they all turn on for "situation normal" (i.e. are none are warning indicators) so any erroneous reading from the tape talling off will trigger further investigation, rather than be misread as everything is normal ? Aside from this niggly issue, I *think* this latest news has pushed me back over to consider using a SunAmp battery, once again.
  4. Tape or heatshrink an optic fibre on to each LED and run out to somewhere more useful? https://www.railwayscenics.com/2m-15mm-end-glow-fibre-optic-light-tubing-p-1267.html
  5. Context- retrofitting & extending a 60s cavity wall house to EnerPHit standard. Our (PHI certified) architect is advocating moisture open approach and has specified: Retrofit cavity = Plasterboard | void | OSB | Blocks | cavity filled w/ bonded EPS bead | Brickwork | 200mm Pavatherm | Render New-wall = Plasterboard | void | OSB | 300mm I-beam with Warmcell | 80mm Pavatherm | Render I'm generally pessimistic about the airtightness prospects on cavity walls (a tiny crack on the inside can leak through the entire cavity and out through another tiny crack in the outside, of even down and through the foundations and under the garage slab we saw in one PH tour!) A local builder experienced in EnerPHit (around 10 certified installs) has recommend we totally ditch moisture open design and fill the cavity with closed cell Icynene to in effect completely convert it to a solid wall (and also allows some considerable cost savings on other natural material selections). I've been forced into doing my own fair share of Googling to discover there's still lots of conflicting advice and I'm still no wiser on the "right" answer, but overall feel keeping with moisture open path is my preference. However some vapour permeability questions linger that I'd love some gathered wisdom / opinions / wild-guesses on: Smartply Pro-passive OSB datasheet variously states it is a VCL and a vapour barrier. Does this mean we're already well down the road of a "moisture closed" build up anyway? (Or, moisture "half-closed" to coin a phrase?) If the answer to the above is "yes", does this mean there's really no additional downside in using closed-cell Icynene anyway? Are bonded EPS beads good enough anyway at inhibiting air movement (as suggested here) so I should just forget about foam fill?
  6. This is almost certainly a marketing scam, or outright fraud http://www.solarsense-uk.com/news/latest-news/posts/2018-/july-2018/beware-of-solar-scams.aspx Etc There's been a lot around us recently Our elderly neighbour got a call saying her solar was causing problems for the grid and they'd be around to fix it. She called the police who turned up just after the guy had walked away. She has solar thermal water, not PV...
  7. Does anyway have recent example of the cost SageGlass adds over a "normal" 3G window? As a data point: upgrading to 4G and internal blinds to our Internorm quote adds about £300 +VAT/m2 to our total. This is based on 16m2 over 12 panes (hence 12 separate blinds + motors). Given this adds privacy light and sound benefits as well has heat control, I'm currently favouring this option I saw in another thread @NSS mentioned £1-2k/m2 (plus control system) for SageGlass a few years ago, but there seemed to be an asterisk against that? (Need to factor in discounts and remove the cost of the normal glazing saved) Thanks
  8. We're not planning full disabled conversation, but as we're installing a whole new downstairs shower room these are the things we're prioritising in the layout to make it accessible ready Wide door 800mm clear outward opening Wide pathway through the room Low/no lip shower tray, larger showering area, perhaps wetroom Slightly higher toilet seat height
  9. My office overlooks a giant building site (3 new buildings immediately next to us, part of the sprawling Kings Cross development). It can be quite a distraction to watch! The building directly below us is of particular interest, as it's being built directly over the tunnel out of Kings Cross (just sub-surface level, so more on a giant bridge really) with trains moving directly underneath as they work. It confused as at first they started pouring concrete with absolutely no pile-driving -- made sense when we figured what lies below! Even all the landscaping around that tower block is just concrete over Geofoams. Here's a truck collecting the EPS offcuts: (" you can drop those at my house!") Here's a concrete pour a few weeks ago And here's an excavator unearthing a chunky looking orange cable this morning (I was waiting for the bang)
  10. Icynene is castor (vegetable) oil based, not petrol-chems AFAIK? Been reading up on this a bit: - Polyurethane contains Isocyanates which are strong irritant / health risk while being applied and if not fully cured (risk if poorly installed). - If it burns it can emit cyonide which is obviously even worse (aside from the whole "and now your house is burning down" thing). - Icynene has lower VOCs and generally considered safer, but still health concerns linger especially if it isn't cured properly, and if the "closed cell" (vapour impermeable) version is used. Context: researching what to put in a cavity wall retrofit; Icynene closed cell has be suggested (by potential contractor) for the extra layer of airtightness defense it provides, but Passive house consultant very against it due to it not ticking the Natural boxes. I think on a retrofit, we're going to have to accept some unnatural choices, and having it outside our "main" airtight layer (internal OSB) means any lingering badness is mostly kept outside (Edit to add: as @Ed Davies already pointed out above] The other issue raised is around breathability and risk of (condensing?) vapour in the middle of the cavity.... I read so much conflicting info on that my head spins.
  11. The developer must be very upset about all that free publicity.
  12. Great, Fascinating ideas. Future proofing a spare loop to the loft sound ideal, as from there we'll have easy access to mvhr, loft itself, bedrooms and the vaulted hall light well. Cold air falls so we can drop it down onto any those areas relatively easily.
  13. @lizzie thank! and no worries, we keep just discussing abstractly whether this would suit us, and would love to see a nice example or two (IRL, ideally)
  14. Maybe the context there was lost on this point, but by doing "both at once" i meant cooling via slab and cooling via ventilation duct at the same time. It seems physically plausible to cool both at once, but questionable if it's worth the complexity.
  15. Do you know the name of the contractors? (Not that I dare to look for their prices, but I'd be curious to see the portfolio!)
  16. If you haven't already, have a good read of https://developers.thameswater.co.uk/-/media/Site-Content/Developer-Services/Domestic-and-small-commercial/Building-near-pipes/Building-over-or-near-a-sewer/Building-over-or-near-a-sewer.pdf?la=en It includes costs (page 3) and guidelines on when they can be moved -- both depend on the diameter of the sewer. I'd be looking at getting a sewer survey done, and they surveyor might have some inside knowledge on it to. A key point is whether this is a "new doweling" or alterations to an existing one. Generally I'm told Thames Water aren't terrible to deal with, simply because so much of London is already built over sewers they have to deal with it all the time. But .... we haven't submitted our build-over application yet, ask me again in 6 months!!
  17. <insert "why not both" meme here> Yes, indeed. My spec currently calls for a mid-position value to redirect between UFH and MVHR duct cooling. The thing that concerned me is the complexity of dialing in their respective target cooling temperature if it's driving both at once. I'm doing all the cooling on the basis of "run the pipes now, figure out commissioning it later"
  18. To confirm, this means when switching from DHW to slab-cooling, and back again, it has to first "flush out" a supply-pipe length of hot water before the cold arrives (or vice-versa)? So if there's a long run from ASHP to the redirect valve, it will decrease the effective efficiency? (e.g. pumping cold water through the UVC that it'll then have to heat back up again). Maybe this is negligible, and I'm probably overthinking this, but as I have a long run (aprx 20m) from ASHP to tank, I'm currently thinking it would be better to have the redirect much nearer the ASHP and then send the cold water to the MVHR supply duct (which is off in a different direction to the tank anyway) so it will run in its own "dedicated" loop. Also, perhaps more importantly, it just feels better to have cooling via air-ducts as that will get upstairs to the bedrooms, as the UFH slab is only downstairs. (with caveat there's only a limited amount of cooling you can do via air, but I'm not sure the slab is much more anyway as we don't want THAT cold a floor, for risk of condensation, right?)
  19. I think there's just 2 tanks, UVC and buffer. The first one (second line item) is a "Docking assembly for" [...air source heat pump, hot water cylinder, buffer tank ...] right ? @Jenni There is no doubt an endless chorus you can do it more cheaply if you DIY but FWIW in case this is of help: I'm in the same camp of wanting someone to own specifying and supplying and installing the whole system, to meet my requirement spec, as my limited time is better invested elsewhere on the project. To that end, in case it is helpful I've been given an initial ballpark figure or £11k+vat for basically the same MCS based ASHP manifest as you have (including with NIBE heat pump). I'm still shopping around, I really need someone that can do heat calcs per PHPP format. This is in SE England (Herts), as with everything else in the project I am sure that has a bearing.
  20. Thanks! I'd previously seen there's a modder community adding additional fans, but hadn't realised this isn't just for efficiency but also offers longevity gains https://forums.whirlpool.net.au/archive/1627406
  21. So my plan to put the inverter in the loft really isn't a smart idea then.... ? (passive house, warm loft) Can I put it in an enclosure that the incoming cold air for the MVHR passes over, acting as an air pre-warmer and an inverter cooler? All very well except when the inverter is working hardest probably the one time you want incoming air pre-warming the least.....! Still, nice idea for the shoulder season, maybe?
  22. Architects and fans of Kevin love them not necessarily because they can be completely opened, but because the large wall of glass helps bring the outside in, and makes the garden the largest room in the house, promotes light and and space and union and a feeling of connection with the earth, etc etc. Being able to open them right up is just a plus. This sounds delightful, but we eventually chose an architect that advised against it ; several did but we eventually went with a passive house certified architectural technician who rightly pointed out the thermal liability of lots of North facing glass. Looking at photos of local terrace houses that have added these in renovation, I see they can be excessive. Many times they are opening to gardens no wider than the house, and often of little depth. So rather than of opening up a near 180° vista with deer gambling over the horizon, instead most offer a wide variety of viewing angles of the boundary fences, and perhaps a gently moulding trampoline centre stage We're now planning a French door and window and bringing them both central as we can on the rear wall, hopefully to direct the views to the tree down the bottom of garden rather than obliquely at the side fences.
  23. Thanks. Looks like ATAB-Trappan is the manufacturer. Much as I love to cut out the middle man, I don't think I mind paying a little bit for a local dealer if they're handling the design for UK specific regs and shipping logistics.
  24. Are you purchasing from https://www.completestairsystems.co.uk/ ? Interested what sort of price their quoting for that? Hadn't seen them before, but the style is very close to what we've been looking for.
  25. Yes! If you move to Denmark. Believe it or not, their smart meters actually help, with a peer-to-peer local generation sub-market. See page 29 of https://www.smartdcc.co.uk/media/1321/netcompany_css_technology_review_v22.pdf
