Everything posted by joth
Regarding power-switching, I'm keen to get all the mains level control onto DIN rails and into closed cabinets. I think this is why, after searching all the more modern open source alternatives, I'm defaulting to using Loxone for most of my core systems controls (lighting + heating, and probably shading too purely because Internorm+Loxone have a tie in) as it's all packaged in convenient DIN form. I first came across SSR in their (5 year old) article on making a DIY solar diverter, and showed a DIN rail mountable SSR so that all seemed logical: put it in the same CU box as the miniserver (or extension) and it can all be neatly locked away together. More I read and look at this though, the more I realize the logic for immersion heater as redirect is to always use it as the final / lowest priority device in the chain, as it can be modulated to "use up the gaps" that can't be allocated to the fixed quantum demanded by other appliances. Thus... any "off the shelf" Solar PV that just always left on auto mode will probably offer no less functionally than having direct control of it from HA - so long as I can factor its live usage into any calcs about other devices to turn on/off based on current generation. Regardless which way I go, this also made me realize while we'll have a dual immersion tank, only one of them needs the PWM modulation. The other I can just power through a mechanical relay (contactor) when we have >3kW of excess generation (and/or fire up the ASHP if the controls for that are compliant enough for it), and the automatic modulated solar redirect (whatever solution chosen) will use up any slack still available on top of that.
@TerryE when you say HA do you mean home automation in the generic sense, or Home Assistant specifically? (It makes sense either way, just curious what stacks folks have settled on)
@Nickfromwales true enough, the improvement is a diffuser that helps retain the stratification even after drawing some water off, and some sensors to measure what the hot water "fill" level is. I too will be keen to get the price, vs comparably insulated and speced Newark UVC.
Still getting quotes - should know in a couple weeks
Great I didn't know about the 1Wh meter slack, but figured there must be something like that. We're on a smart meter so I'll have to experiment to see if I can see where it switches over. At 3kW that's a about 1s grace, so half second sampling sounds minimum. I was looking at this project that suggests the proportional SSR, which presumably just offloads the need to keep up with driving PWM while in a steady state. Still need to sample at about the same frequency to detect household load or generation changes. I like that it is din rail mounted so could all be installed by my electrician and all I have to deal with is sending the low voltage signal into it to set the target heating level. Anyway, I'm going way off topic here! Thanks both for the excellent pointers, as ever.
This is nice analysis, and got me thinking about the equivalent issues on the mixergy tank we're planning to use. (Posted over on the Mixergy topic) I'm curious though that with your focus on avoiding serialised failure modes, you have an HA + mqtt setup you are confident enough for this. That means IP network needs to be operational to get heating on? I've seen too many cascading failures with IP networks to trust myself to run a mission critical one in my own home. My own policy is lighting and heating must work without any IP. Do you have a write up of your HA setup somewhere? Always interested to see how others have partitioned things. One other question: is this SSR relay controlling the immersion? With your proposed ESP32 controller would you modulate it at all, to maximize free excess from PV, or just binary switch it on/off? I'm contemplating making my own PV redirect using solid state contactor with 0-10v input, but again interested in what others have done. Thanks!
We're going with a mixergy tank, in part because plan A was sunamp but it's just looking to finicky (and, not convenient to use with a heat pump) The current discussion on failure mode analysis and designing for line-replacement of parts has me wondering about the overcomplications of Mixergy, I don't think it's too bad because - we're not planning to use it to predict usage day by day, just to allow us to have effectively 200L of hot water tank but expands to 300L when there's free energy coming off the PV - the fanciest bits of the internet connection are for the predicting the future parts. Without that I think we'll get fair use from it primarily through local schedule control. - if the fancy controller or cloud service eventually breaks, it just becomes a normal tank, not a dead lump of salt. The only thing that does concern me is the heat plate exchanger and circulation pump assembly they use for getting most effeciency from a low temp heat pump. I have not idea how tightly the speed control for that is coupled into the rest of the controller circuit. Obviously it already had double immersion as the primary backup, but maybe it would be prudent to order with an internal coil too so we have that as a backup (I have half a mind we could warm the ufh from that, if it became necessary to use it as an E7 time-shift store).
Exterior CCTV camera advice needed
joth replied to H F's topic in Networks, AV, Security & Automation
Do you expect to do other work at height in future? Investing in a small portable scaffold tower would have long term use and is far more pleasant to work from than hanging off a ladder you can't quite get to the place where you want it. -
Just got the first draft of our completed pre-construction PHPP and I did a little happy dance on opening the PER tab: What this says is our 8kW of self-generation (vertical axis normalized to ground floor footprint) is enough to offset our energy demand (horizontal axis, normalized to total inhabitable floor area) and achieve their new-ish "PH Plus" category. So far there's only one in the UK that has achieved this (that I know of) so exciting times ahead! (if all rather arbitrary I'll admit, sure). Anyone else gone through PHPP and got PER charts for comparison?
There is a small market in reselling devices with Tasmota pre-installed. e.g. https://amazon.co.uk/s?k=Tasmota (similar to modems with Tomato firmware) not sure what the markup is on those, and AFAICT AliExpress isn't doing it yet. Other possible downsides with this approach - assuming you can fettle it to reliable state, I guess one thing is you need to have a means revert the house to "normal" switches if planning to resell the house anytime soon. Also.... if you're building the house yourself it's probably fine, but if working with architect or full services contractor to build you'll be forever trying to explain and re-explain the requirements for these systems (vs saying "just put some lights in please") ?
Ah this is good to have confirmed. I have heard reports it works very well, and good price, but was hesitant to recommend without having used it myself as I used to recommend the BT home hub and look where that got us! And wasn't sure about the possibility they'd use it to encourage lock in later... (Fwiw my brother had the Sky equivalent to this and rated it highly for years, but the whole lot went TU over Christmas and now he's a ubiquity convert too) (Oh to add the sky one has benefit each set top box doubles up as a WiFi repeater, but again that just means more lock in)
No problem, feel free to shout if you have questions. I could make a diagram but I'm sure there's already some good ones out there.
This does make me wonder: do any units have filter access from below? Positioning it with its own loft access hatch directly underneath it would be pretty convenient in our install: just stand on steps, open a ceiling hatch and reach up to access the filters.
Oh that reminds me: did you recently add any new devices to the network? My mum has a BT WiFi hub and it generally crashes and won't allow new connections whenever I have used my MacBook on it a while.
My own advice is to organise your WiFi completely separately from the broadband router provided by your ISP. This way there's much less friction to shopping around when your contract does come up for renewal. Ubiquity are considered the king of WiFi APs for home use, but Google WiFi is also pretty good and much easier to setup. (I've used both) Nice thing with both these is if you do get coverage black spots you can just add more APs to fill them in. The mesh roaming is pretty good. Just make sure to use your CAT cabling to with all the APs back to a central ethernet switch (they can use wireless for the back haul, but it's never as good)
oh yes, thank you for this. Yes that's the distinction - this one does say the installation needs to comply with the MCS planning standards, not that it needs to have been done by an MCS certified installer. The standard mostly seem to be measuring and documenting the compliance with noise limits.
Be aware that an MCS installation is (now?) a requirement of installing heat pumps under permitted development rights https://www.planningportal.co.uk/info/200130/common_projects/27/heat_pumps/2 If you already have an ASHP on your PP then nothing to see here.
Never was a member's username more appropriate
Uninhabitable Earth was the first book in the recently formed Climate Change reading group at work, others since then are Drawdown and Sustainable Energy - Without the Hot Air. (I'm behind on them all, but trying to follow the group notes)
Other possible benefits, but it all depends on preference: If you have lots of light circuits e.g. a hallway or large living area, you can group them and have a smaller number of buttons to select scenes rather than needing a "sound desk console" of 12 dimmer dials (or whatever). Scenes can control table lamps and so on, which can easily be relocated without involving an electrician Opens the possibility of automations (e.g. turns all lights off at bedtime, auto lights on/off when away, bring up low level lighting when going to the loo in the middle of the night, etc...) Control from you phone or voice assistant if you're into that Easier support for colour changing and tunable white temperature, if you're into that. (the latter is definitely the new cool hotness) I'm dead set against using wireless light switches, but keep questioning that aversion. If I did use wireless I'd favour something using z-wave as then you can mix and match switches, dimmers, and "smart bulbs" from different manufacturers in a single system. And crucially, you're not locked in when you come to add one more switch or lamp in future. Fabario does seem a top contender for z-wave lighting kit. I'd personally steer clear of proprietary wireless systems, rako lutron loxone creston etc etc I'd strongly recommend avoiding anything that needs internet connection, and thus tend to avoid anything using WiFi as it's a reliability and latency nightmare and lighting is not something I'd leave at the whim of a cloud service to keep running.
PV Self-Comsumption Model for sizing system + battery.
joth replied to Dan F's topic in Photovoltaics (PV)
Netherlands already have exactly this: https://www.powerpeers.nl/about (referenced in the UK smart meter report on making supplier switching simpler) Back to the OP, I had a similar question of "how much PV" but it was solved by the planning office: having a south facing front roof pitch facing into a conservation area they weren't happy about any PV, but I suggested a whole-roof of inline panels and they said OK. So now we're waiting on the DNO to approve 8kW of feed in. In principle this was a simple decision - sure 8kW costs more than 4, but 4 costs more than 2, and being able to self-generate is not going to become less valuable as the energy network moves more and more towards electric. The only snag is the bureaucracy. After 3 months we got the PP for the PV, but after another 3 months we're still waiting on the DNO to reply to the G99 request to connect 8kW to a single phase. For those that say "just phone the DNO for guideline on...." I'd love to know the trick as every time i spoke to them they said they could only reply if we made the application, and the application seems to have no limit on how long they can take to respond. And I bet when the do finally respond it will be a simple "no", with no indication of cost of installing 3-phase and it'll be another 4 months waiting for them to answer that question... :-/ -
Fan Coil Units for use with a (cooling) ASHP
joth replied to ProDave's topic in Air Source Heat Pumps (ASHP)
I was surprised to discover this actually is a thing https://www.airconco.com/no-outside-box-air-conditioning/ This might not be totally terrible if they had a buffer tank and recirculate water through, and use that as a preheat for DHW and medium temperature uses like washing machine and dishwasher. Legionella compliance nightmare and highly disruptive to retrofit so I doubt this is their design in practice. But surprised they don't warn about increased water costs. It actually makes me sad as it's aimed at London flat owners, but SE is already running out of water and Thames water are one of the main culprits of emptying all the streams around us. If you have a stream going through your plot it might be a wholely different argument. But... You then probably have enough space to hide an external heat pump anyway. Edit to add: the above mentioned buffer tank would have to be incredibly well insulated and get used fairly frequently else this is just standing in the boat trying to blow your own sails, as Ed would say. -
Same monoblock ASHP as heating and DHW, about 5kW. Mitsubishi is my M&E guy's go to make, but now we've agreed cooling is legal he's thinking Panasonic is better as it multiple flow temperatures and better cooling modes. I can see myself pouring over @ProDave's excellent research in the near future LOL, yes we're also doing external blinds and calcs say solar gain is going to be negligible. The only reason for the ott cooling plan is that I was getting advise from 2 sides to put heating in upstairs, and didn't want radiator clutter, upstairs ufh would have minimal cooling potential (had to be between joists due to limited head height so no slab, no thermal mass), but recirculating air via a fan coil had been discussed a lot here so thought we'd give it a go. The fact we were designing it this week also leaves its mark. If the air temperature doesn't go below 20 overnight, overheating is eventually inevitable however good the passive cooling design. Definitely, bit the limiting factor is probably not the capacity of the heat exchanger, but the maximum rate the MVHR system design will pass air over it. -
Ouch! In practice the amount of cooling (or heating) you can get in through MVHR ducting is limited as MVHR moves air very slowly, and air has low specific heat capacity, so even worse value with that in mind. So after a lot of back and forth I've moved off that plan to using a separate recirculating fan coil for the upstairs bedrooms, as these can operate at a higher fan speed without messing up the MVHR balancing. As we have easy access to each room from the loft, I'm thinking a single ducted fan coil (maybe like Courier 42EM-09) branching to a small linear diffuser in each room. Return path via door-gaps to landing and a single larger return diffuser back into the loft plenum. I didn't know any of these words a day ago so hopefully that makes sense! My M&E guy thinks it's doable and looking into a concrete plan on this. It's quite a few parts, but may not be too bad compared to 4x fan assisted radiators and associated plumbing and control (or vs. 1x comfopost for that matter!). Also, very little bulk / space needed in each room for it (although the loft is going to become a ducting rats nest). If this was only for the occasional upstairs heating we're anticipating would be needed it would be way overkill... but the fact the design is being done this week has somehow made me very mindful of how useful having some highly effective cooling capacity would be. -
We certainly did!! (Full disclosure: that was my team mate videoing; 4-tandem bike relay team, we'd just done the final pull to get to the top of the pass and they took over for the descent, as he has stronger nerves than me. Here's a shot of us rolling into Kansas early on day 4) 4 years ago now so details are hazy, but... they definitely do work, but I just didn't like wearing them. Large problem is unless you regularly train in >100F temps, and train actually using them, they just add another unknown risk which is the last thing you want on race day. (So long as it's <100F I found the body can self regulate enough given a reasonable forward motion creating movement of air. It's above 100F things rapidly come apart. And this is the only thing Fahrenheit is any use for) What helped me more is various "cooling towels": we kept a stack of them in cool boxes full of ice water in the chase van, each change you could drape those over and cool down quick. And the old favourite: nylon stockings stuffed with ice wrapped around the neck like a french man carrying onions. Exploiting the latent heat of vaporization effect, I now know to call it (thank you, MVHR enthalpy exchanger!)
