BotusBuild
    10
Everything posted by BotusBuild
  1. Thank you @dpmiller, that seemed the logical way.
  2. And before you ask, there are no instructions in the box
  3. Should the red plastic knurled screw on the top be loosened off after fitting? left tightened? removed?
  4. It was a rhetorical question 😁 But answer your Qs: Yes it's been planned. HWC Buffer tank for UFH UFH manifold for lower floor The electrical CU's A comms cabinet The MVHR (already there on the right) H & C manifolds ( to those pipes on the left)
  5. Welcome to madhouse πŸ™‚
  6. The whole "planning advice request" is a con trick to collect unnecessary fees from unwarranted members of the public πŸ€‘
  7. Run away, leave them to their own devices.
  8. That's not going to plug the £20bn black hole 😁
  9. Just recalled our BCO (Stroma) said next time he wants to visit if completion. No first fix had happened at that point 😁
  10. Or, gradually add 2p pieces until you get level, then you can measure the depth of 2p pieces. If it's 2cm (10x2p pieces), you've got a 2% slope. Other coins are available.
  11. From the second photo, it would seem you are replacing an existing gate. JFDI 😁
  12. @Omnibuswoman, knowing your back story, and who is doing your electrics, I agree that you should get your first fix electrics all in one go, and use hot and cold manifolds or plenty of isolation on the plumbing. FYI, just had our house electric first fix done. It took him 4 days. I had put all the conduit in place, and the sockets where we wanted and marked up where all the lights were going. This approach is likely to be cheapest in the longer term. PM me or call if you want a sanity chat
  13. That'll be a nice drive 😁
  14. Stephen, Is there a simpler way of just taking a spur from an existing socket? Or inserting the new socket in an existing ring ( this should be done by qualified electrician, but your suggested solution will also require qual. leccy as well)
  15. If you can get the screed pourers to float it level then you might be able to lay flooring directly. Otherwise, a little levelling screed mixed as runny as feasible πŸ™‚ to make sure it finds the dips
  16. Does you LPA (Local Planning Authority) provide a"pre-planning advice" service? It may be chargeable.
  17. Welcome Dave. What is/are the reason/s that you will need planning permission for the workshop/garage? Size? Location relative to house? Conservation area? Something else? You may fall under permitted development and therefore no planning application required
  18. That sounds like a reasonable way to do it. It will work. The key is whether there is enough insulation. Can you add 50mm PIR on top of the EPS and then the screed with the UFH pipes. This would increase your overall U-value and make the heating a little more efficient (= cheaper to run). Insulate as much as you can now before the screed is poured
  19. I've seen this at NSBRC - https://www.tilingsuppliesdirect.co.uk/product/jackoboard-plano-tile-backer-board Seems to be a good alternative. Not sure on price in comparison to the yellow gypsum board
  20. I did that on our brick retaining wall when our kids were toddlers. Removed later as earlier stated by someone. Would re-used on several other projects over the years. Only recently took the last of that wood to the tip (26 years later)
  21. The sister-in-law always brings her dogs πŸ™‚
  22. Munaf, I think you have the answer in your question - you made some changes in settings. I suggest revisiting the settings and revert to what you had before (I hope you remember what they were), and check if the boost kicks in at the next shower time. If the boost doesn't kick in, then maybe the humidistat is faulty.
  23. Knackered - the body is complaining πŸ™‚ Redundancy at 60 is a b1tch - combined with a bunch of other situations, it is time to focus on the new house Just realised that includes VAT, so once reclaimed that figure will come down a little.
  24. To OP: Using the Quality/Time/Cost triumvirate, we are letting time run away with us to keep quality and cost in control. We are doing as much of the build ourselves. So far, I have forked out for the following work to be carried out - groundworks, steel frame (one wall of house, one part of roof and balcony), concrete pours, windows, GRP roof, and electrics. So far, it's taken 4.5 years on a part time (weekends and holidays basis). We are weathertight and in first fix phase. I'm about to start working on it more full time having been made redundant and realistically we think about another 9-12 months. Just been catching up on finances and the current "already spent + forecast future costs" show a per square metre cost of approx Β£1200. (Β£1900 if you include cost of plot) So, it can be done.
