BotusBuild
Everything posted by BotusBuild
It's time for the final consumer unit for the house. Electrician said get the largest available, but even I think a 29 way unit is overkill 🙂 So, on the basis of future proofing (PV and battery, external feed to garage, and other unforeseen SWMBO requirements), my thoughts are that a 20 way would be enough. I have seen recommendations on here for Hager (expensive end of the price range?) and to stay away from MK. Our local electrical wholesaler stocks Hager Lewden Fusebox CGD Elucian Schneider Electric Crabtree BG (none with enough ways at this wholesaler) Luceco Scolmore Eaton Which of these should I consider (and which should be avoided)? Thanks
Advantage of an induction hob.
BotusBuild replied to SteamyTea's topic in Kitchen & Household Appliances
So, in effect you have to cook at arms length. Therefore, no leaning over to see what's happening inside the pots at the back or cooking anything you can't lift off easily. All seems a bit risky to me. Maybe the pacemaker is being affected?? -
FYI - can't be used by someone with a pacemaker -
Hello I’m Mike and new to this site
BotusBuild replied to MiketheViking's topic in Introduce Yourself
Get a pallet 🙂 -
New windows flexing in wind??
BotusBuild replied to junglejim's topic in General Construction Issues
+1 -
So, in all the quoted examples above, there is a possibility, however low that might be. Ergo, these things should be tested for. And that testing can be carried out without specialist equipment. Regarding the last point, I bought a 1980's built property in 1997 and had to have about 25% of the wiring replaced as the cable had hardened and cracked. Sometimes, you get shit materials and knowing the quality of the rest of the property I can believe this builder was get stuff from wherever they could as cheap as they could. 🫳🎤
Finaly have our Completion certificate
BotusBuild replied to Buzz's topic in General Self Build & DIY Discussion
Well done -
I can't see why not. I think it's been suggested already.
After 20 years cable can deteriorate (unlikely but possible), and cable connectors can loosen. Don't ask me how but it happens. Whenever I get a problem like this I start with the simple things - tighten the connections, then swap out units, then call a qualified electrician to run circuit tests (that way you're not touching live shit!) Often one of the two solves the issue.
If you think a critter has gnawed a cable, then you'll need a tester to be able to check insulation --> time for an electrician. If you suspect a switch, check connection tightness of cables on the switches and/or swap each switch in turn with a known good switch (tip: mark up the good switch so you know which is which after you get distracted 😉) While you're at it, check cable tightness on all the light housings as well. As above, by swapping out with known good units.
False lintel - what material and other questions
BotusBuild replied to BotusBuild's topic in Building Materials
Nice stonework. Does the steel angle sit underneath those stones? FYI I will not be fitting a door in the opening, so the lintel or whatever i put in will be on full view -
This might be in the wrong forum. On our build we have an opening that leads of a balcony, the one on the right below: We are stone cladding, and I want to put in a "false lintel". In other words, it will look like a lintel, it might be installed like a lintel, but it will not have any load bearing work to do. I am prepared to cut some notches at each side at the top of the opening and slide a false lintel into them. Alternatively, I could have something that "wraps" around the top of the opening, but this would obviously take some fettling to make. Two alternative materials come to mind - oak and granite (because we're in Cornwall). What other materials should be considered? Does anyone know of a company that would make up the "Wrapping false lintel"? Could this be done with granite, similar to making a granite trough? The opening is about 1200 by 350mm. The stone cladding looks like this:
Right, resin is a no-goer according to the Epodex website. Minimum temp for use - 150. Recommended temp 200. As the floor standing stuff is due for install next month, those temperatures are not going to happen Quarry tiles it is 🙂
Rookie with longshot dreams of building on old orchard in AONB
BotusBuild replied to ACF's topic in Planning Permission
What is the square that is in the old orchard, just below the Old Orchard pin? Looks manmade. Walls of an old building perhaps? -
Used on garage floors, so I think so🙂
Agree with that. So, either would do?
Other option is resin. Thoughts?
Good idea or just plain stoopid? I like the idea, SWMBO is persuaded. Am I missing something apart from dropping my mug of tea with the predicted outcome?
I've just paid £2600 for 1.5 storey about 35-40m length for 12 weeks
Entry 10: Redundancy helps progress
BotusBuild commented on BotusBuild's blog entry in South East Cornwall Low Energy build
Item 1 on the latest list is complete 😁 -
We hope to camp out in Feb as expressed towards the end 🙂 -
BotusBuild posted a blog entry in South East Cornwall Low Energy build
So a quick recap - back in December 2023, what may be my last ever employer decided to ask me to leave. I had mixed feelings about this. I took several weeks to think about next steps and actually get around to writing a father of the bride speech which I'd been putting off. After the wedding in March (a great day and a great speech!) I started to look more seriously for a new job, but being the wrong side of 60 now, the IT industry is not a good place to be looking especially when so many other people have been let go as well. Coming up to the end of May, we sat down and took some tough decisions; we bought a static van on a site about 3 miles from the plot, I stopped looking for a new job, SWMBO did an internal job transfer, we rented out our current house (instead of our original plan to sell up) to three newly qualified doctors (our niece and two others on their first F1 rotations in our local hospital so that worked out well), and we spent 6 weeks decluttering, and moved down SE Cornwall (Kernow) at the end of July. In the last blog entry I ended with a list: Finish ventilation system Finish insulating the GWW Finish backfilling Electrics Floors Walls ASHP and HWC Kitchen Bathrooms The remaining plumbing Outer wall coverings This is how it looks today Finish ventilation system Finish insulating the GWW (Great West Wall) Finish backfilling (on the back burner) Electrics (first fix) Floors (now on the back burner) Walls (En suite partition walls to be done) ASHP and HWC (being done in January) Kitchen (planned for January or February) Bathrooms (temporary loo and basin installed, cold water only, temp bathroom planned for January) The remaining plumbing Outer wall coverings (rendering done, stone cladding starting next week) What I missed off the list, and has taken most of our time: Sound insulation (R35 rockwool and resilient bars) Plasterboarding So a few photos are required I think: MVHR unit in place (since removed as plant room walls have been put in and waiting to be plastered inside) Ventilation distribution boxes and pipes fitted: Plaster board arrived (in May): My cold water manifold has pipes attached for the first time (one now being used for the temporary toilet and basin), no picture of it but just to the right is the hot water equivalent: We powered up the sewage treatment plant for the first time (nearly 4 years after it was first installed!): We started plasterboarding, first a large room into which we moved all our stuff that was in storage so saving a hefty wedge per month on storage fees, and then the much larger and more complex open living area: We took some time off in early October and went sailing for a week, and when we got back some kind fellows had installed some scaffold (first time on this build), and in the following few weeks we had the renderers in thanks to the Kernow weather gods: Meanwhile back inside, we finished plasterboarding the large living area, and during this last week the plastering started (kitchen area first!). We set off a couple of insect smoke bombs as we had a cluster fly infestation and wanted rid before plastering started 🙂 : Dare I add a what's next list 🙂 ? Well, here goes .... Plastering finished in the open plan area this coming week (by others) Remainder of stone cladding arrives and work begins to get the most inaccessible (high) parts put up before the scaffold gets taken away - this means cladding two 7m x 2m wide walls Plumbing pipework ready for ASHP installation Gabion basket and pad for ASHP to be installed on Mist coat and first coat on plaster (SWMBO is at the ready) Begin fitting upstairs UFH Front door being fitted (January) by others Take 3-4 days off for Xmas ASHP installation (January) by others, that will allow for hot water and the downstairs UFH to be available ... Fit a temporary bathroom ... Fit out utility room as temp kitchen ... ... and this is why - Move out of static van for the month of February (rules is rules!) and decamp to the house Well, I'll let you know how it all goes 🙂 -
Week 5, Scaffold, more ICF and internal structural walls.
BotusBuild commented on Susie's blog entry in The Old Cow Shed
We want more info on the Interceptor 🙂 -
Very neat block work and carpentry. Appeals to my OCD 🙂
Started our build at 57. After 3 years my shoulders were shot, and I now have to find other ways of getting things done that are above head height e.g plaster board lifter. I've always had niggles with lower back pain, and a bad left knee following a rugby injury and too much off piste skiing when younger. I now spend more time planning the HOW, than actually DOING 🙂 Pilates? Might have to give that a go.
