TerryE
Everything posted by TerryE
I've found it. The sitemap.php module is adding an extra /ipb in the forum uri's which gets snotted up in our URIs, e.g. https://forum.buildhub.org.uk//ipb/sitemap.php?file=sitemap_content_forums_Topic_21 instead of: https://forum.buildhub.org.uk/sitemap.php?file=sitemap_content_forums_Topic_21 Rather than change the sitemap module, it's probably easier just to add a rewrite rule to remove the extraneous /ipb. That way I don't need to mode the ICsuite code There's an ACP option one the SEO tab to fix this. 🙂 @Liam Jones thanks again for the heads up.
@LiamJones Thanks. We'll look into this. I've noticed that our guest views are down. I did tighten the robot.txt rules quite a lot to minimise the load from the AI bots, but from what you suggest we've gone overboard.
He's got a couple of Velux style (Fakro) roof lights in his main room which is also his bedroom so it isn't too bad -- except if there's a serious hot spell for a few weeks like there was a couple of years back, but in this case he just sleeps in the main guest bedroom. He could probably do with a small A2A ASHP like the one we bought and got fitted for about 1K€ in our Greek cottage, however an MCS certified installer would charge 3× that amount to fit. So we haven't gotten around to it.
We've got a near passive class MBC TF + natural stone skin with UFH in the groundfloor slab. One big advantage of getting those heat losses below a threshold is when you can rely on G/F UFH only to heat the house and can dump the need to heat the upper floor (or floors in our case). This really simplifies the CH design and gets rid of those bloody rads entirely: better aesthetics + saving cost and complexity.
MVHR ? Who needs it? I don't.
TerryE replied to ToughButterCup's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Surely this is more about getting to an end-point in such a way that your BInsp accepts your Test Report as demonstrating your builds compliance (without you abusing the truth to the point where you get caught out). -
We had to make all sorts of design trade-offs and TBH sometimes "shooting from the hip" decisions during our build. Sometimes these were driven by Local Planner push-back and sometimes to avoid exacerbating relationships with neighbours that were getting fed up with the new build going on next door. Good examples here are (i) PV: we wanted to have cassette in-roof PV (similar to JSH) but the planners really didn't like the visual impact on the street scene, so we gave up on this one; (ii) ASHP: my modelling showed that we would be hard pushed to get a 10-year payback for installing it and it would have to be installed quite close to a sensitive neighbour's boundary, so I took the easy way out an put in the pipework and electricity supply but installed our Willis Heater, and deferred the decision on the ASHP unit "until we had a enough data to make an informed decision" -- 9 years later and I still can't make the investment case. In our case MVHR was an easy decision. We had ecoJoist floor voids and this was before boarding out, so this was one of the jobs we could do ourselves, so the cost was in the few £K range and at that time we could self certify for the BInsp. The modelling showed that we had a clear case for putting it, so for us it was a no-brainer. And we've never regretted that decision. The entire house is always fresh smelling and mould-free despite it being pretty airtight (about 0.5 ACH). The system does need maintenance but that's one of Jan's jobs ðŸ¤. And when it comes to the warmer period (maybe 6 months a year), we just open doors and windows if we want direct external ventilation; I don't turn off the system because even if the kitchen patio doors are open, say, you still notice the street noise etc. even in what is basically a quiet village, and it can get stuffy in the bedrooms on the street-side with the windows closed overnight. But in your case Ian, this might be your equivalent of my ASHP decision. The fact is that you now live in the house and have over-wintered without it, so your heating can cope with the heat losses from non-heat recovery air exchange. It is more an issue of CO2 build-up and moisture control. In your OP, you mentioned that you haven't got BCont sign-off. The reality is that there are two design modes for ventilation: the leaky model where all of your windows have get weep vents etc, and an airtight one where none of fenestration includes vents. In this second case you won't realistically get sign-off without an MVHR system installed, and this is a big problem for you. You need sign-off, so unfortunately MVHR isn't really negotiable. My BInsp went through my report in some detail and asked some supplementary Qs on it. Your inspector might be a bit more lax, or perhaps you could just fabricate a piece of fiction, but IMO that's a dangerous path to try. The least risk root is to self-install properly and go through the self-certification exercise (if Bregs haven't closed that path now). -
I am surprised that you aren't into sextb.net or isn't your Japanese good enough? 😂
Yup, the forum went offline. Some gremlin still TBD. We are peaking at something like 5 topic views per second during peak hours these days.
You wouldn't have too much probs doing @torre's suggestion. It shouldn't introduce to much of cold bridge as I assume that you've also got insulation between your roof joists. You just need to be careful with your finishing. Where is your VCL?
What's the problem? We were constrained by BRegs on our landing placement and this is a solid wood fire door because our warm 2nd floor loft is part of our living space. The architrave and frame liners were a bit of a fiddle (22½° mitres) but nothing that a decent chippie couldn't handle. I did all of our internal woodwork myself. I don't think I can recall any visitor even noticing the missing corner. BTW, the door will have to open into the room and away from the landing as mine is hung.
Ah. A couple that runs a separate his and her finances. Life is too complicated for that. 🤣
I've just updated companion Rehosting the Forum Virtual Server topic. TBH, It didn't help that Heart Internet offered us a reduced spec VPS (less RAM, less SSD, less performance) for the same price, and this has involved quite a bit of pissing around / effort on my part to mitigate this. But as @Sparrowhawk commented: the price that we're paying is really at the bottom range of what you'd expect to pay for a 6-core VPS of this spec. You get what you pay for, I guess. We try to keep the annual costs as low as possible to keep the forum free for all, and unencumbered by the need to advertise. We'll just have to keep a close eye on actual performance post cut-over to see if we have any noticeable performance issues. The GitHub issues give all of the technical details, if you are interested in more details. Thanks to @Sparrowhawk, @MikeSharp01, and @AliG for your support.
Should I be happy with this decrement delay?
TerryE replied to MikeSharp01's topic in Boffin's Corner
Mike, I can't recall. Are you using HomeAssistant and do you have Zigbee? I have a dozen Aqara temperature sensors around the house with a couple stuck on the undersides of external lintels front and back. I do use the Metoffice day ahead forecast for my weather comp, but the Aqara sensors are easier to use for trending actuals. As to DD, this is driven by the external S.H per m2 and U-value. In our case our DD is well over a day but that is largely down to the ~125mm external stone skin acting as a huge heat capacitor. This does nothing for the U values but this plus the cellulosic filler gives a long DD. If we'd had PUR insulation and a render or brick-slip cover then we could still have fantastic U-values but short DD. Have a look at my ~2016 blog posts on this. Yes theoretical models, but 9 years later and that how the house behaves in real life. Having a high DD makes using a ToD tariff more effective. -
I have just posted a new scoping issue on GitHub: Rework to Support the New VPS Environment . My thanks to @Sparrowhawk for his input and advice. After some discussion, we've decided to stick with Docker for now. There is just too much else to be done to try to fit this in the Migration time line.
@Sparrowhawk, no CDN at the moment though the ICforum app does support using CDN. This would drop our Apache requests and network traffic by maybe 4× though not our processing load as this is 90% PHP-FPM and D/B load. As we talked about offline, I agree that it makes sense to stay with docker / compose for now. I currently use Alpine for my docker images but having looked at the CLIB vs MUSL performance issues, it makes sense to switch to bullseye-slim. I will ping you on the Github issue when I raise it.
@MikeSharp01, podman in essence has two modes full native podman and docker compatibility mode where docker compose projects are configured the same but the execution is in a user mode account. There are niggle and bumps as you can hide the fact that you are running rootless entirely in the host environment, but I have the stack up and running, first cut. The performance hit for using a container approach is a couple of % at most and having the entire stack under git just has SO many pluses. As far as working with AIs. I actually prefer Deepseek, because its chain of reasoning approach gives a more systematic approach and analysis, but its a bit overloaded ATM. However, Genimi is a standard on a Chromebook and it's fast. The issue is that by default its a bit patronising and treats the user as an idiot, but to be fair to Google probably 95% of its interactions are with idiots. It's definitely a knack getting the AI to kick into expert mode. The risk is that these AI are sincere and convincing but maybe 10% of the time the advice is flawed, so you always need to check -- trust but verify.
You have to reconfirm that you want to stay on Agile before the end of the 12 month term. Just raise a polite case with the helpdesk mail address ASAP saying that you missed the fine detail on the end of contract email and that you do want to stay on the (current) Agile tariff. I say current because they tweak the T&Cs every year and you can stay on an old Agile tariff. You have to accept the current T&Cs or leave Agile. PS. the error message is because some context cookie has expired. Signing out and relogging in will fix this.
By way of background, I am the very aged IT geek that has done all of the SysAdmin since we first set up BuildHub about 9 years ago. I am no longer involved in Forum Management or politics; I just in keep the forum up and smoothly running, pro bono. i have also administered and run a number of community forums and wikis over the last few decades, mostly using open source forum packages such as phpBB and MediaWiki. However when the founding members set this forum up, we decided to use a commercial Forum package (there was a one-time purchase, plus an annual maintenance fee), because this customer funded business model offers us a better feature set and continuous through life improvement. We chose the forum app from the company now called Invision Community. This a PHP application that runs on a LAMP stack on a hosted Virtual Private Server (VPS). The VPS has grown in cores / RAM / storage over the years as the size of the forum and its user population have also grown. Three years ago, I moved the LAMP stack into a Docker Compose project, and the VPS runs this single dedicated Docker Project which is on open Github. If you want to know more then read the README at Github: TerryE/docker-buildhub which explains the setup. Our Hosting Provider is currently doing an infrastructure refresh so we have to migrate to a new VPS and at the same time I am retiring the use of Docker and switching to the open-source equivalent, podman. See this issue, if you want to know more: A Gemini Conversation about Migrating VPs and switching to podman. Warning: it's a bit long (17 pages) and technical, but it lays out the issues and context. This topic is just to keep interested members informed. Any technical discussion / comment is welcomed. I have opened a companion topic in Forum News and Site Issues: Rehosting the Forum Virtual Server to discuss the more general / policy aspect to allow this thread to focus on the nerdy stuff. 🙂 Can I ask you all to keep to the technical discussions here and use the companion topic for general / policy stuff. @TerryE is my user account but I also have the Godlike @Admin account to hide / delete off-topic posts if the mods don't move them to the general topic. 🤣😱
I know that the Geberits are designed to be fully maintainable through the panel opening that is accessible behind the flush plate, though it is a bit like open heart surgery. Small nimble hands help, so in our case this will be a job for Jan.
You shouldn't use a typical smart plug. Some might be nominally rated at 3kW at 240VAC they can rapidly heat up especially when powered up for a few hours. I control my 3×immersions (2 in the UVC and one in a Willis heating my UFH) by decent din-mounted contactors in the MCU. These are rated at 20A at 240VAC for a straight resistive load. These have a design life of 50,000 cycles. Their coils are driven at 24 VDC (at 10s mA) by an IoT relay board controlled by my HomeAssistant system. I've done posts on this if you want know more. My TL;DR is that it can be done but you need to know what you are doing to avoid the fire risks.
BRegs for new builds state that it shouldn't go to the drain, but I think you can be pragmatic when tweaking an existing patio area. You need to do one of the two: feed to soakaway or to the drain. My inclination would be to do whatever is the simplest / least disruptive. Your "usual builder" seems to be suggesting what we did.
Expectations around MVHR
TerryE replied to IanofEpping's topic in Mechanical Ventilation with Heat Recovery (MVHR)
BTW, there is an entire sub-forum here dedicated to this MHVR, perhaps one of mods could move this topic to it?- 13 replies
1. Yes 2. 🫣 3. Probably As @JohnMo says you should have been given a commissioning certificate and report which details how their installation meets BRegs. We have an energy efficient new build with an ACH around 0.5. We did a lot of the internals ourselves where we had suitable knowledge / experience to save costs and guarantee quality. This included the MVHR design, commissioning and installation. That was over 8 years ago and we've had no problems at all with the MVHR including the bathrooms. Yes, we do get a little condensation on the mirrors in the en-suites after a shower, but this clears after a few mins. However, (mainly because evaporating off condensation dumps heat due to the latent heat of evaporation) I do wipe off glass and tiled surfaces with a flannel and wring this water into the waste outlet, so in my case the en-suite is bone dry within 5 mins. My wife doesn't bother, so it takes another 5-10 mins in her case. The extreme case is that after we take a bath I leave the hot water in for 30 mins or so to dump most of its heat into the house rather than losing it down the plughole, and this does steam up the bathroom. This is me being anal, but even doing this, the bathroom is still totally dry within 15 minutes. TBH, I am shocked at their reply on (2). If this is the case, then their installation almost certainly doesn't meet BRegs. Doing the design calcs and commission certification requires you or someone you trust (such as a competent professional) reading and understanding the relevant Regs then doing the proper calculations based on them. You can do the commissioning yourself, you just need a flow anemometer. We used to have a couple available for members to borrow, and there are threads on how to do this going back 8 years or so if you want to browse and review. OK we have an airtight house, but the general design principle is that fresh air goes into living spaces which people occupy. Extraction is done from wet rooms such as bathrooms, utilities, cooking areas. In / Out placement should allow clean flows between them. The system should be properly sized and balanced so that the as-designed and as-installed system should meed BRegs. There are dozens, maybe hundreds of members here that have done this successfully themselves, so IMO any company that claims to offer a professional design and installation service here should be capable of meeting the regulations.- 13 replies
Plant room size - big enough?
TerryE replied to BotusBuild's topic in General Self Build & DIY Discussion
Mine is a 0.8 × 1.4 m cupboard off the downstairs loo. 🤣 The electrical panel and OSO UVC (a later SunAmp replacement) are in the utility. The MVHR is in the loft floor drying / storage room. -
We had a big plot in the centre of the village where we'd lived in an old stone farmhouse for 30 years. We then put in an application to split the plot, so we could build a modern low-maintenance, low-energy house on the bottom half and sell off the farmhouse to free up some tied up capital. The planning process took over 3 years. We had 7 neighbours whose properties shared a boundary with use. 5 didn't care, or supported our application. 2 complained like buggery, but the real nub of their complaint was "I used to overlook a pretty cottage garden at the bottom of my garden; it's now going to be a house." These objections were worrying, but carried no weight in the planning assessment. One of the neighbours kept complaining to Planning Enforcement about all sorts of issues. One of the complaints was that we had built the house ½m too close to their boundary fence. PE came out, measured up and agreed that the house was ½m closer to the boundary than the plans indicated and asked us "as a formality" to put in an MMA to "rectify" the situation. I declined to do this, pointing out that the foundation was the correct distance from our front road and that since the neighbours house hadn't suddenly moved ½m closer to our road, it the position of the house relative to theirs was as per plans. The problem was that the neighbours or the previous owners had moved the boundary fence ½m behind what used to be a 1½ m deep laurel hedge to pinch a corner of our garden. This was a boundary issue between me and my neighbour and not relevant to the planning process. The PE officer withdrew the request in the end but got pissed with us and ran interference during the build. 8 years later and all is forgotten, 3 of the neighbouring properties have been sold. None of the new neighbours seem concerned that there is a a handsome stone clad new-build at the bottom of their garden. Moral: Try to keep the neighbours onside during the process, but accept that you might piss some off whatever you do. (E.g. I didn't make a big issue of this ½m corner-cut when I noticed it, as we were building a new house at the bottom of their garden, but it still came back to bite us.)
