TerryE
Everything posted by TerryE
Grundfos Pump Occasionally Stalls on Willis based UFH system.
TerryE replied to TerryE's topic in Underfloor Heating
John, I pressured the UVH to 1 bar on commissioning and topped after initial dissolved air bleed off. I haven't needed to top up since. I chose 1-bar because the Pump spec called for a min ½ bar and I could see any advantage in going above 1. The circulation is on the lowest pump setting and this seems to circulate the water fast enough. A good safely check is the willis temp as this rapidly climbs if the pump isn't circulating the water through the slab, and I do have a safety check on this. -
@Gus Potter, I agree with you in many respects, but also take an opposite view on some. I had just turned 65 when we moved in. Doing a self-build was only feasible for us at this stage in life when we had enough capital and time and effort available to take of some of the trades and jobs ourselves to reduce cost. You mention a 50-60 year objective, but we optimised for about 30 years, as I doubt we'll be around much longer than that. We put a lot of thought into our design and material choices to ensure that the house would be pretty much zero maintenance for that sort of time-frame, but the house should be good for at least another 30-50. If you are talking about a 50 year horizon, then the other key point is that the house has to be electric only -- which it is. The number of UFH loops is just a small design detail that should be matched to the house characteristics. In our case we need to put about 2kW (coldest midwinter) into the slab to keep the entire house at a cosy 22+°C, so 3×95m loops controlled as a single zone works fine for us. The UFH tail length (if long enough) is pretty irrelevant. I feel that your position about automation is about similar to the argument that our predecessors might have had 100 years ago about replacing gas and paraffin heating and lighting by electricity. Technology moves on, so reject it and get stuck in the past or accept and embrace it: this is a personal choice. In my case, our design choices reflect some principles (like all-electric and near zero maintenance), but beyond this they were largely driven by return on investment (RoI) criteria: I have minimised our running costs, and we won't invest in "improvements" unless the discounted savings over a 10-year per period exceed the net investment cost. BTW, I wrote my first computer program 57 years ago and my career was spent in IT so I am very familiar with programming and approaches such as integrated logistic life cycle management. This is why, for example, my CH system is independent of my Home Assistant (HA) stuff; why at a component/module level everything is pretty-standard multi-source commercial off-the-shelf, and i keep enough spares to be able to do cold-swap repair in less that 24 hrs. Putative new buyers could rip out all of the HA system and its IoT devices, but this would leave them a working CH and HW system. They could replace the entire CH / HW control system for under £2K if they stuck with resistive heating, or by then Octopus will probably have a bundled deal to install an ASHP with demand-side managing your CH, HW and EV on some flat-rate tariff. -
I do VPN into the house routinely to keep an eye on things. I've also got email alerting of any errors like this so I don't miss something on my TODO list. I do cycle the pump for 6 mins every 3 hrs - mainly so that I can log the slab temp, but doing this routinely cycle the UFH and stops any crud selling out in the pipework or pump over the summer. BTW, the Elec Installation sec of the pump manual warns that the pump can have an inrush spike of ~8A at on/off, so advises that any relay should be rated to handle this i.e. have AgSnO contacts (e.g. a contactor) so you might have cycle life issues with the Shelly causing it to fail after a few years. As to spinning these up, it's a two min job and there's even a YouTube howto on this. Next time send the customer a link and say this is a routine home owner job - or charger a hefty call out fee. BTW if you are passing the MK area and need an overnight / nice meal then give me a shout - so long as we are in country that is. 😄 -
It's a Grundfos UPM2 15-70 CIL2 that runs at about 40W. Easy to bump start manually except that I am in Greece at the moment and my house is over 2,000 miles away in the UK, but back home in just over a week. In the meantime, I've downloaded the manual for this model and will read it. I will also monitor the HA system to see if we get any more stalls. The water is inhibited but there is little scope for electrolytic corrosion: no rads; just the PexAlPex going into the Wunda manifold and a short loop-back through the Willis. The expansion vessel and fill input is T'd off this. I need to give my live-in son some basic plumbing and home automation lessons. 🤣 -
Short version: We have an 8 year old passive-class all-electric house running on and optimised for the Octopus Agile tariff with electrically heated wet UFH. We made the house ASHP ready, but didn't install one during the build, instead using an inline Willis heater as a "temporary" solution to allow us to size the ASHP on actual house performance. In practice the running costs are low enough that we've never made the RoI case to install an ASHP so here we are 8 years later and still using the Willis. One of the major advantages of my design is that it has very few moving parts so pretty much no servicing maintenance is needed: some CU mounted contactors, some commercial ESP based modules, the Willis and the UFH pump. I keep cold-swap spares for the relays, modules and the Willis. But now the pump has occasionally stalled. Is it time to get a cold-swap spare or should I just have done and replace it? @Nickfromwales you are the oracle on such matters. Longer supplementary. My CH control system is a NodeRED based app comprising about 1K lines of JavaScript and some NodeRED flow including maybe 50-100 other NodeRED nodes -- a fairly small app by NodeRED standards. This uses MQTT to talk to the ESP modules and to share data with a Home Assistant instance which I use as a general Home automation interface. My basic strategy is to move any time-shiftable electricity loads to the cheapest Agile tariff time slots: white-goods, EV, HW and CH heating. This is workable because the thermal capacity of the house is so high that it doesn't really matter when I schedule heating so long as I top up enough each day overall. Each day just before tariff roll-over, the system calculates the heating required for the day ahead and allocates a heating schedule so that we do this at the cheapest price. So our typical electricity use is a base ripple of stuff that can't easily be time shifted, plus big blocks of power draw at the cheapest prices that day. See the graph below which is an extract for 32 hours starting 4 AM yesterday. The top plot is our spot energy use taken from our smart meter; the bottom plot is the Willis temp, plus the average out and return flow temps from the UFH loops. The cheapest price slot was 04:30 - 06:00 so that was when the main UFH heating slot was scheduled (the spike to 9kW spike was when the HW immersions also kicked in) ) You can see the typical UFH heating curve: The Willis quickly heats to ~27°C with the average out flow to the UFH a couple of degrees cooler and the return at 19°C (the overall slab temp); these all slowly rise together by about 2½°C over the next 90 mins as the heat transferred warms the slab around the UFH pipe. This pattern happens on four heating cycles during this period. BTW, the out & return flow temperature readings are steppy because these thermometers are only read if the circulation pump has been running for at least 5 mins, because these rapidly settle to the ground-floor ambient temperatures without circulation. The pump is cycled for 6 mins every 3 hours to enable the slab temp to be tracked. Note that some went wrong at 14:41 and the following 01:31. Here the Willis suddenly started heating rapidly until the 35 °C safety trip was exceeded and the CH system turned off the Willis. The system log shows that the pump relay was still on but the water wasn't circulating: it had stalled at 14:41 and was still stalled when it came on again at 01:30. What is odd is that it started correctly at the 3:30 heating slot, so the stall is intermittent . Very odd.
BTW the little <> icon in the post form can be used to insert code, e.g. try: dt = parse_ts(s) assert dt.tzinfo is not None and dt.utcoffset().total_seconds() == 0 print("OK ", s, "→", dt.isoformat()) except Exception as e: print("FAIL", s, "→", repr(e)) It also does nice syntax highlighting. You can also use the TR ... icon to edit previous posts and add code formatting 🙂
Fabric and ventilation heat loss calculator
TerryE replied to Jeremy Harris's topic in Heat Insulation
@flanagaj IMO this is in the noise. JSH's sheet is an approximate indicator for general sizing. Yes, you could net off the fenestration area, but then again windows etc. typically have ~10× the U-value of decent wall profiles. Also you also get additional edge-effect heat losses where surface meet such as where walls meet and where fenestration meets the surrounding wall. This is roughly of the same order as this netting out, so I wouldn't bother. This simple model is a useful tool but will always be maybe a 20+% under estimate because of this edge effects and bridging losses that always creep into as-built houses.- 204 replies
- heat loss
- ventilation
(and 4 more)
Can't connect the SWA cable. Practical help please.
TerryE replied to saveasteading's topic in Power Circuits
BTW I personally always use crimp terminals on multi-core cables going into screwed connectors, especially if the cable is carrying a sustained high current load. However, these aren't needed for Wago type connectors as the connector maintains good contact if the multi-core deforms under clamping load. -
@saveasteading YouTube is your friend here. There are lots of howto videos; watch a few. One trick that's important is making sure that you cut the SWG sheath neatly and to the right length. You need to mark the snip line and use a decent pair of wire snips that are man enough for the wire gauge. I don't know if its the recommended way but I have an old fashioned adjustable pipe that rated up to 28mm copper. I just cut the outer PVC sleeve with a knife as a guide, then do a dozen + turns to finish cut into the SWG to notch it. Doing it this way keeps the wire well clamped for the nothing I then cut back the outer sheath to the notch ring and then fatigue break the SWG wires around the notch; cut back the outer to size according to the fitting instructions. Slide the other cover and locking ring over the wire before rolling around the centre 4 / 4 core to flare the wire sheath so than the gland can easily slide into it. As I said look at the videos. After a few fitting, this only takes a few mins mad you will end up with neat jobs like @JohnMo's. -
Planning self build, Northern Ireland
TerryE replied to Kevan Marshall's topic in Introduce Yourself
TBH the regulatory framework in the UK has relaxed as well as ASHP prices dropping a lot in the 10 years since we started our build. If I were 10 years younger and starting now I would probably include a ~3-5 kW ASHP for slab heating / cooling only, with the inline Willis for backup. Still no CH for the 1st and in our case 2nd floor and just immersion heated high insulation for DHW; as for both this keeps complexity down and initial costs low. For us now (on Agile tariff and time-of-day optimised heating) we wouldn't get a 10-year RoI case so these don't make sense to me. To consider an upgrade to ASHP for the UFH, we would still need to get the total "project" costs (including making good) for procurement and install to around £4K for this to give us a viable case for doing this -
I remember Jeremy talking about how nearly all ASHPs are actually Aircon enabled internally but this function is disabled in the UK to qualify for MCS grants. IIRC, in his case he had to flip a DIP switch to re-enable. In other cases, there's a buried set up option to re-enable.
I understand the SAP / EPC issue, but in our case this also very flawed. We now use a double immersion heated 250 ltr OSO and our W/M and DW are in-appliance heated cold-fill and we almost always use ECO wash cycles time-shifted for cheapest Octopus Agile tariff rates. The OSO has under 1 kWh / day parasitic heat-loss and we (3 adults) use maybe 50 ltr at 50°C from our hot taps except on the occasional bath day. And again our OSO is heated at the cheapest Agile slots. The bottom line is that our DHW typically costs less than £1 / day, so it is really hard to come up with a cost benefit justification for the complexity of using alternative means of heating the HW. We don't currently have a ASHP but if we did I'd install a 5kW UHF only unit at a max O/P temp of 30°C direct into slab UFH at an SCoP of around 5.5.
As @ProDave says they are probably OK, but I personally would (i) check immediately under the joins for any evidence of dripping / water damage, and if so bite the bullet and replace them. (ii) don't disturb them unless you are going to fix them properly. The last time I got burnt by a joint this bad was about 40 years ago (I am not a professional plumber but only have done the plumbing on my own houses). In this case I left it but the joint then failed after I replaced the CH pump. I couldn't resolder because it was at a low point and I couldn't drain it down. I ended up cutting out a section and managed to put in a small insert with two new end-feeds. When I got the failed bit out and looked I found that the plumber had never actually soldered one side: the flux and gunk were all that was sealing the joint! Nick is the expert on this. He is my Sensei. 👍
My vote as well . I believe it to act as a keying surface for the mortar bed; a smooth surface is more likely to shear, and the slabs to loosen. 🙂
Our LPA were a bit arsey on this. Our old farmhouse next door and the listed cottage across the street were made of the locally quarried stone. The PA told that they would turn down flat reconstituted stone or machine cut stone because it wasn't character. We need a 1×1 m sample stone panel plus sample slate, and bricks used for the chimney and eve detailing. We used the sample to make up when we put up the porch plinth. 🤣
Is it worth having a gas connection for self build house?
TerryE replied to Wadrian's topic in Central Heating (Radiators)
We have an all-electric house. This was a design decision for our build, and one we've never regretted. -
Advantage of an induction hob.
TerryE replied to SteamyTea's topic in Kitchen & Household Appliances
We installed a 4 ring induction hob and a 2 ring propane backup for power cuts when we built the house ~8 years ago. I think we used the gas rings once in anger just to see if they worked. All cooking means have their foibles, but IMO I'd never go back to gas or conventional electric. -
I did maths and operations research as my degree, and then spent over 5 years doing physics based modelling in a management consultancy before moving into systems / IT, so this type of approach is "in my DNA": I trust an evidence based engineering approach. That's not the case for Jan who came up a different educational route. The key is finding a common evidenced basis to informed agreement in your partnership. Take an example Jan wanted a fire in LR, and I knew from the modelling that this would a disaster, but the argument that swayed Jan was my point that she really looked forward to spring, when we could clean out the hearth and decommission the fire over summer; the new house would be at this temperature all year round inside, so when would we ever want a fire? The final nail was a tale from someone who was talking about his passive house, and they'd put in a fire. They decided to light it one Christmas when the extended family was visiting. An hour later, everyone was standing in the garden with the doors and windows open waiting for the fire to out and the house cool off because the open plan downstairs was about 35°C. That was the one and only time they used the fire. 🤣 How many houses of the class that plan to build have you both visited and talked to the owners about the strengths, weaknesses and realities of living in their house? We must have visited ½doz or so. You expressing your views and research is one thing, but listening to others talk of their personal experience can be more compelling. Maybe your architect can link you up with other clients? If you are willing to share you post code area or nearest town, then you might be able to hook up with other members on the forum who would host a visit.
Surely you need an evidence-based conversation and come to a joint decision. Jan's comment was "it's going to cost a fortune to get the heating and cooling right: you've got to take the long view." You need to do the heat loss and solar gain calcs and make sure you both understand the implications. 2G panels have about 8-10× the U value of your walls and introduce lots of opportunity for air leeks. Do the sums; share them; own them and their consequences.
We have a passive class TF build with external stone cladding 2 storeys with 2 rooms and en-suite in warm loft, so really 3 floors. We have UFH on the ground floor in the poured slab and nothing on the two upper floors. Not having to stick rads on any walls is a real boon for laying out your rooms and planning built-in cupboards and furniture. BTW, all of our wardrobe space is in built-ins / walk-ins, so no VAT, and again keeps living space uncluttered. What we saved on CH costs easily paid for our (self-installed) MVHR. IMO, air-tightness isn't really a major cost as long as you've factored into your design and build rules. It's attention to detail and making sure everyone understands the rules and follows them. When you say "I'm building" this can mean a spectrum from "I am really paying a builder to build it for me" to "I am building it all myself". Where are you on this scale? In our case, we used a specialist sub for the slab and TF, another for the fenestration, and a good local builder for all of the ground-works and stone skin. We also used a couple of his regular and recommended tradesmen for electrics, tiling, slate roof and plaster boarding. I also got a local architect technician to do the plans for the planning application for a few £K. Other than that we did the overall design, project management, procurement, quality assurance, and various trades like plumbing, woodwork, MVHR, CH, so pretty much all internal second fit; also planning and BCont docs and sign off. TBH neither Jan or I realised just how much work this would really entail, and we were exhausted by the time we moved in. Still 8 years later, and we live in a pretty maintenance free house with pretty much no post move in problems or things needing fixing. We have a high quality house and saved a lot on our build costs by doing a lot of the attention-to-detail stuff ourselves. One Q I would ask: Why so much glass? It costs a lot more than TF/blockwork and dumps heat like crazy. I know that it can occasionally help you connect to a stunning view, but if you are overlooking the street or neighbours, then do you really want to connect to them or have them looking into you private space? There's a 1970s/80s estate close to us where the architects loved having full 2-storey wall to ceiling window panels. Maybe 95% of the houses have since bricked in / insulated clad the bottom halves and fitted conventional 2G/3G windows instead. Architects might love it, but IMO occupants usually end up hating it.
Just to support what @torre says, we split our garden and did our new build on the bottom half of our garden. We were chatting to the estate agent who was handling the sale of our old farmhouse and he was quite interested in what we were doing, and gave us this piece of advice: "If you are ever thinking about doing a loft conversion, then the best time to do it is when you build the house: this works out far cheaper in the end and involves less disruption." That one aside was just so valuable: we raised the pitch of the roof from 40° to 45° and put in a warm loft during the build. This increased the effective size of our house by maybe 35% for very little extra build costs. My son has his bedsit on the loft floor now. We have an MBC (passive class) TF, but the builder (who did all of the ground works and stone skin) showed us around a couple of his own self-builds. In one case on the Planning Application it was "two storey", but he had a huge walk-in cupboard on the landing which had a loft ladder to a huge warm loft that was already built with roof lights and to code for conversion to living space. His reasoning was that since his application was for a two storey house, then he would get it signed off as that. This also avoided all of the costs of second-fit to the loft and hoisting the sales price. His intended buyer was going to wait a few years and then put in a planning application to convert the loft to living space. The Regs for conversion are slightly more relaxed than new build, but the way the house was laid out it was already fully compliant: it was just a matter of installing the 2nd flight of stairs instead of the cupboard and doing the 2nd-fit in the loft. You could consider either of these options to future proof your build so you could add the extra living space if and when you need it.
@Sparrowhawk, I'll add you as soon as I've those creds, ditto you @MikeSharp01 We do have an issue about where we store all of our secret stuff like creds than is excluded from our public repos. Maybe it's worth rolling it all up into an encrypted 7z file and putting this on our cloud server. That way we only need to share one password.
I think that I've worked out what is going on. The GSE property was set up years ago when HTTP was our default and /ipb/ was in the URL. I've just added https://forum.buildhub.org.uk/ to my GSE account. If you WhatApp me your Google creds, then I'll add you in Users and Permissions for this site.
@Sparrowhawk, methinks this is your forte rather than mine. Care to take a look and analyse the Google Search Console. Thanks It might be still worth adding rule to remove the gash /ipb from the URL. IIRC in the very early days the DocRoot didn't include the ipb directory so the rewrites added it, but on some VPS move we just made the DocumentRoot /var/www/ipb (see service/apache2/conf/extra/ssl.conf). This predates the move to Docker since the change isn't in the git logs.
I have made the ACP change and sitemap.php seems to be giving the correct URLs now. So let's see if Google picks this up. The change that I added to robots.txt was to add the sitemap directive. Before that google was just indexing from the homepage.
