scottishjohn
    23
  1. If it was me I would swop plaster board for foam backed type --then you have insulation and keep you service void +extra sound proofing as well use 37.5mm insulated plasterboard and you get 25mm of insulation sounds to me like the TF company are trying to keep to abosulte minimum frame thickness ,or it would just be deeper in the frame and could have thicker insulation behind the service void to get spec you need 140mm frame ,rather than 170mm frame ?
  2. I,ve got a big garage /warehouse 30 miles from stranraer --maybe a biz oppertunity ?
  3. maybe me --but the pictures seem to show the meter is set in concrete --that cannot be correct -it should be in a meter chamber ,so it can be replaced easily by simply turning off the toby and uncoupling the pipes without any digging it also looks like it is not deep enough --is that 450mm under the ground? that will not be to spec --so while you are at it get that sorted to water board spec as well if i am talking crap ,then sure a plumber here will put me right
  4. try it on the floor first and see how much deflection in the shelf with the weight you going stack on it
  5. If you can get a helicopter to carry same 1500 rounds (7ton ) of depleted uranium shells and that monster gattling gun --then yes retire it till then there is nothing that can lurk about like an A10
  6. 600mm wide shelfs will need to be very thick or lots of support brackets . -you can get a lot ofr weight ona 600mm shelf -so really you should be thinking of same spacings as floor joists --16" unless you not going to fill the shelves . mdf --NOt my choice it will bend over time real wood or 1" plywood
  7. A10 that one i would like to have flown with a full magazine and some tanks for targets
  8. he was always sticking them on a wing tip proper flying
  9. yes your devon pilot often did tree top fly bys above my house --waving at the wife i think nice to see an old piston twin being flown other than in a straight line
  10. there is a house on the river Nith at glen caple that is built on theesturay banking which is mainly mud =sand etc they dug down and made a raft from 1metre cubes of eps and linked them alltogether then poured a concrete slab on top --that was built 25 years ago --still there so good eps slab works on anything really
  11. buy correct resin coated T+G roofing board ==not std osb
  12. that would have been robert bolton -king -- our 12000hr+test pilot / type instructor - or basil lockwood -goose ex aviation engineer -his last working project was concorde braking leader of the 6 man build group yes it was one of the first Europas to be home built I got permission to do instrument approachs and touch +go,s --without touching down -- on west freugh when i did my IMC rating training on a c182 I had use of ,as it was closest place that had someone to direct approach right to ground level by radio/radar --think it was good for them for training as well. I had to wear "foggles" --which stop you seeing anything but instruments--to simulate full INSTRUMENT CONDITIONS and full aircraft instrument failure . ,turn +slip all covered up ,all you got is rpm and altimeter and compass all good fun
  13. as i said above there will be sod all compression really to worry about
  14. I agree if there were no other areas taking the load --then yes too small --but you already have found it only compresses very small amount -so the full load will never end up on any one area ,but shared and anyway i am assuming you have at least 6 other fixing at sides of window which will all take some load , so total downward force will be nothing like full weight this cannot be the first time this has been done what is normal solution ? I have used 2 lumps of 5" phonelic roof insulation as packing blocks under truck wheel s to get it 10" off ground -- to give space to get under easy and even with that very small foot print a tyre gives it dented very little even though there would 350 -450kg on each of rear wheels i think you are over thinking this problem really . but if want to make something tough then use expoxy lay up resin on grp woven cloth and lay it directly on the eps in the window holes -- expoxy resin will not melt EPS as normal grp resin would thats what i used to make the wings for the europa aircraft -- blue foam cores covered inexpoxy resin+cloth
  15. 450kg of window --how big is it ? thats one mother on a window ----sounds more like bi-folders than window but no problem just put a row of them to spread load --
  16. heres a suggestion if you going to sit it on the PIR which is no doubt on top of an ICF wall? then how about putting a couple of support screws into the concrete and have them just flush with pir --then if weight gets too much load will transfer i doubt the thermal bridge it could possibly make surrounded by pir is even calculable --but no sinkage
  17. I can tell you ,but really that is of no importance --the fact that energy costs dropped by£1000 is the important bit I had a £1500 lpg bill and when i dumped it my electricity costs went up by £500 -you can,t have abetter comparison than that .,as no other changes were made to the house or its heating system . no fancy calculations just real money costs even if you say my lpg system was rubbish --then you still cannot get round cost to use ashp on a late 70,s tf house --nothing like passiv is£500 for full year in scotland .
  18. from my experience changing from LPG to an ASHP --with no other changes to heating system was a saving of £1000 a year LPG should be your last option
  19. yes i,m looking at one that was last occupied in 1965-has full walls but nothing else - so this would be treated same as a new build then ,even if i did not flatten but rebuild it ?
  20. 5% is alot different than 20% though maybe iam picking you up wrong you are saying that 5% will apply ,but you can reclaim that so in effect it will be zero vat on materials to build ?
  21. very rough calc would say 18cubic metres of something which would be approx 24 tote bags @£35 ? a bag ==£840 or a truck load --if you can get it direct to tip it in
  22. ok next question ruin that has full walls -but nothing else and you are rebuilding basically as it was Do i understand correctly that there will not be full vat reclaim ,only 5 % If so then why would you not flatten and rebuild from scratch ?
  23. well you have learned a lesson to more accurate we all have learned a lesson --hopefully from your troubles always cap any pipes or ducts never leave any open for something to make a home in
  24. 800mm block wall with 1200mm fence on top --no rot problem then and no weeds coming through ?
  25. no one i have talked to is offering as short a time scale all 25 year lease
