Mr Punter
I can't see why not. It may be a fair bit more expensive and although it is self compacting, it will not necessarily be level. I would get a decent concrete contractor and use standard concrete.
The distance back from the kerb depends on the road type. The gates take a while to open, so you don't want to obstruct traffic. If the gates are over 1m high you will need planning consent.
Yeeessss we bloody done it.
Mr Punter replied to Russell griffiths's topic in General Self Build & DIY Discussion
Why is the "after" photo 4 years old? Take a new one and post it up. -
Connection to steep sloping lateral drain
Mr Punter replied to JackOrion's topic in Waste & Sewerage
He will probably be fine with plastic fittings and IC. Much simpler. -
Plastic inspection chambers are not designed for steep gradients so you may need to build one to suit. Talk to your groundworker and to BC. What depth is the pipe? -
Vehicle Presence Detection with Loxone
Mr Punter replied to SBMS's topic in Networks, AV, Security & Automation
A friend does automatic gates and access control. He cuts a wire loop into the driveway which seems to be a favourite. Why on earth would you want to tie your automatic gate functionality to a particular manufacturer? -
Passive house Shepards hut ?
Mr Punter replied to Waterworks's topic in Energy Efficient & Sustainable Design Concepts
+1. May as well heat it with the car exhaust! -
Dealing with Kitchen Appliances - LVT Installation
Mr Punter replied to steveoelliott's topic in Wood & Laminate Flooring
Why not just shift the fridge elsewhere in the kitchen, tile where it is to go, then move it back? -
Agreed I have heard this claim but cannot see it in the Building Regs.
You will need mechanical ventilation in the kitchen, bathroom, WC and utility. You also need trickle vents to all the habitable rooms. The fans may need testing also. What did Building Control put on their Plan Check report?
Sand & Cement vs Liquid screed - which is best? (70mm)
Mr Punter replied to Great_scot_selfbuild's topic in General Flooring
I like traditional sand cement screed. 75mm is quite thick for liquid screed. If you go liquid, use Cemfloor as there is no laitance removal needed. I have used Sigma Screed in the past and they were very good. -
I think you need check reveal cavity closers as one of the wings will clash with your brickwork. These https://insulationgo.co.uk/150mm-xt-cl-close-r-checked-fit-pir-cavity-closer-brick-outer-pir-core-insulation/ or if you want fire rated, which may be a better fit with the rigid insulation: https://www.insulationsuperstore.co.uk/product/arc-ecocloser-150mm-fire-rated-cavity-closer-2-4m-length-pack-of-6.html
Strip the roof and re-lay. You need MINIMUM 50mm into the gutter. They are fibre cement slates fixed with nails and disk rivets. You could sort out the rest of the woeful bodges while you are at it.
I have done similar using resin anchors to face fix a timber ledger to the wall, then timber to timber joist hangers for the joists. It means you have more freedom in floor height and better airtightness. Your blocks should be fine for this as the ledger will have fixings every 400mm. Cleaning the drilled holes with brush and blower is key to a very strong fixing.
Another VoC. Take a punt and just start?
Mr Punter replied to flanagaj's topic in Planning Permission
I would just go ahead and do a retrospective if it crops up. -
Don't pay them until they get it right.
A more important factor will be the loss in floor area, which if it is 1.9% on a floor area of 160m2 would be about 3m2, which could be worth between £6,000 and £12,000 depending on location.
Ceiling service void size for domestic sprinkler system
Mr Punter replied to MattD's topic in New House & Self Build Design
I have had quotes for this before and they were very expensive to cover the whole house, but can be handy for smaller areas. Get a flow rate / pressure check. You can request a very meaty supply from the water co. just for fire sprinkler purposes. Have it separate from your main supply. -
Yes, mineral wool is far better than pir for this.
Plasterboarding ceiling with metal shoe at end of joists
Mr Punter replied to Omnibuswoman's topic in Plastering & Rendering
The res bars are good call. Easy to fit as well. -
Has anyone got experience with Hyline aluminium sliders?
Mr Punter replied to lookseehear's topic in Windows & Glazing
I have no experience of them but if they are a decent fabricator and you have seen their installations then why not? -
Only if he gets caught naked.
Why do you think you need a demolition statement? Who is asking for it?
