Everything posted by jack
Why did you choose an air source heat pump?
jack replied to SimonD's topic in Air Source Heat Pumps (ASHP)
We self-installed a 5 kW Panasonic Aquarea in 2015. Our electrician did the wiring (very simple) and the plumber took care of the plumbing from where it entered the house. We probably paid £400 all up for the installation, maybe less. I did the pipework from the plant room, through the underslab insulation, and plumbed it into the unit. As to why we went with a heat pump: Despite there being gas on the road and the bungalow we were replacing being built in the 1950s, there was no gas to the property. It would have cost us time, money, and disruption to install gas. We wanted to avoid paying two lots of standing charges. We'd used an induction hob at a friend's place and wanted one of those instead of a gas cooker. We were going for PassivHaus class insulation and airtightness, so we knew that we wouldn't need a massive heat source to heat it. The idea of a low-and-slow option seemed more compatible with the house's thermal characteristics. We wanted the option of cooling. Having lived with it for about 8 years (we didn't enable it for the first couple of years), this is probably one of the best reasons to choose ASHP in a well-insulated house with UFH, imo. We (well, I!) wanted some sort of home automation, and I felt that an ASHP offered more interesting control options than a boiler. We haven't actually integrated the ASHP in the way I'd thought we might (the modbus module for the ASHP was too expensive to justify), so this point was somewhat moot in the end. We installed a lot of solar (8.5 kWp) and I thought we'd be able to at least partly power the ASHP with excess solar. With the benefit of hindsight, I'm not sure this was a great argument. I'm genuinely unsure how often we generate excess energy at a time when the house needs heating. In the shoulder months we often don't need heat, and in winter when heat's required, we often generate very little solar, let alone excess solar. I don't remember whether I considered E7, E10, or any other time of use tariffs at the time we made the decision to go with an ASHP, but cheap overnight rates have since become of the strongest reasons for using an ASHP imo. For example, I have our system set to prioritise heating during the 6 hour cheap window with have with Intelligent Octopus Go. I allow a little bit of overheating during that period, and allow things to cool down a little more during the expensive period before turning on the heating. There are sometimes periods of several days where the heating is only on during the cheap period, which is quite satisfying to see given it's about a quarter of the price than the peak rate. The main concern I had was DHW recharge time. That hasn't turned out to be a massive issue, except when our younger one - Mr three-hour-shower-of-power - is home for the holidays. Upon reflection, I'd have gone for a larger tank than the 250 L one we installed. That would have allowed me to lower the DHW temp even further, while ensuring ample hot water. I don't know how repairable boilers are, but I get the sense that ASHPs could have a very long life, at least while parts are still available for any given model. How repairable any particular issue is depends on the failure mode. About three years after we installed the unit, either the control board or the pump failed. Apparently both are replaced at the same time, because it isn't possible to tell why one or the other failed, and one of them failing can bring the other one down with it. Sounded like bollocks to me, but I did a bit of research at the time and this seemed to be a common view. I don't recall what that cost us, because it was tied up with some other work, but certainly it was several hundred quid. I think the pump alone might have been £400, which sounded like an utter rort for a smallish pump, but I wasn't able to find a cheaper equivalent. It's since continued running without issue for a further 7 years. If something catastrophic happened and the whole unit needed replacing, I'd just go and buy a new one for £2-3k and install it myself, reusing the existing wiring and plumbing. The units themselves aren't that expensive, even for decent brands. For example, the current equivalent of the model we installed is about £2700. -
Fabric and ventilation heat loss calculator
jack replied to Jeremy Harris's topic in Heat Insulation
For those using SketchUp, here's a potential alternative way of working out heatloss, based on SAP principles: https://forum.buildhub.org.uk/topic/46635-preliminary-sap-and-heat-loss-tool-for-sketchup/- 204 replies
- heat loss
- ventilation
(and 4 more)
The architect who designed my house has just released an extension for Sketchup. As I understand it, you build a very simple model in SketchUp, select various values from drop-down lists, and it outputs a draft SAP report. You can use it for heatloss modelling, or to estimate what impact changing components etc. will have on SAP score. It's really designed for architects and designers, but there's a 14 day trial if you want to take it for a spin and see what it can do.
I agree with this, but was just commenting on the MVHR balancing point (and not suggesting the MVHR is the solution here). @Potatoman, for a short term fix while you figure out what's happening and what to do about it, consider getting a dehumidifier. They can make a world of difference and aren't expensive to run (pennies per hour). If you consider this option, look at Meaco. They're a British company who make very good quality units for not crazy prices. Three year warranty as standard and I've heard of them helping people beyond that time too.
I fell off my bike, so I'm ravin' mad ....
jack replied to ToughButterCup's topic in General Self Build & DIY Discussion
One of my kids lives in Amsterdam. The roads near where he lives are being redone. It's taken a year but you can really see the quality of the work. -
The system should definitely be balanced by system design, but some units (including all Brink ones, I believe) auto balance by adjusting relative fan speeds. I seem to recall that some actually allow you to set a slight bias one way or the other, to slightly pressurise or depressurise the house.
I meant to mention this. A lot of suppliers won't separate out their costs in an estimate. I think a lot of people would be very upset to see how much of their money goes on materials in something like a heat pump installation by a typical heat pump installer. Also, for a lot of trades, this would be an onerous proposition. Imagine the effort that would be required for an electrician or plumber to provide an accurate estimate or invoice including exactly how many metres of cable/pipe, switches, valves, backboxes, couplings, etc., etc., etc. It just isn't feasible to quote or invoice at that level. We tried this a couple of times. Some suppliers would only give trade discounts to tradespeople. From their perspective, if they put the invoice in the name of the self-builder, it becomes a consumer transaction with all the force of consumer law behind it. Many suppliers don't want that risk and would rather keep it business-to-business.
This winter's been bad for tarmac health. It feels like it's barely stopped raining since the first week of January, and I've really noticed the potholes in the last couple of weeks. I saw something the other day from one of the larger county councils (I think) saying that their entire annual budget for potholes would, if they could spend it all at once, fix less than 10% of current reported potholes. There's a massive crater near my inlaws that's had a traffic cone in it for weeks. There are bigger potholes on bigger roads that will need to be filled first so I can't see it being done in the foreseeable future. -
To be clear, I don't begrudge anyone marking up a product up if they're sourcing, picking up, etc. Whether something is overcharging is very much a matter of degree. I guess if you can see the price you can get something for (taking into account eventual VAT reclaim), you have a good basis for understanding whether what a tradesperson is proposing to charge seems reasonable in the circumstances.
I don't think there's an easy answer. Trades often just buy at the last minute and so will buy materials wherever is in stock and most convenient. We had a few cases where we were paying for materials and were told that something was needed within the hour - not a great option when the best deals are online. Same when trades were buying on our behalf. They'd often just ring the first place they thought of, happily paying more because it wasn't their money they were spending. In some cases, trade discounts are so high that it's cheaper to just pay the VAT. I specifically remember that our tiler was able to get tile trims for half the price we could find them anywhere. I think in that case we actually submitted his invoice from the supplier with our VAT reclaim and explained that it was accidentally in the name of the tradesperson. It was accepted. In fact, we had one invoice where we bought in person, and the invoice had a completely random company's name on it. I assume the supplier just used the last name on the system or something. Either way, we explained the situation when reclaiming VAT and it worked. I think the only way to get ahead of it is to speak with every trade up front and find out what they're willing to offer. It sounds good using their trade discount, but they might expect to mark up their purchases given they need to cover warranty issues. If you're buying, you also need to be on top of the trades at every turn, to find out what they need and when. You'll overpay every nearly time if you wait until they ask you for something. I bought from all over the place and never asked for a VAT receipt. Receipts from places like B&Q generally show VAT, so nothing else is required. In fact, we had a few receipts that didn't show VAT and I just calculateed what we would have paid and noted it in the covering letter when reclaiming VAT. Everything was paid out without question.
Don't underestimate the potential costs of using one of these. The wear charges on diamond discs is eye-watering. When we did our spalled garage floor (about 45 m2) with something like this a few years ago, I think the wear charge would have been hundreds of quid on top of the hire (we got it through my wife's family's plant hire company, so thankfully we didn't have to cover it). Admittedly the slab had been there for several years, so under the spalling the concrete was very hard, and I had to take quite a lot off to get it even roughly flat, but just be aware of the potential costs. An alternative would be to scrabble with something like your first machine to remove anything loose, then a primer to stabilise, followed by a thin layer of epoxy floor covering to smooth over any residual roughness.
Mat Wells yay or nay and if yay what mat?
jack replied to Beau's topic in General Construction Issues
We have recessed mat wells at our front door and utility room door. I think they work really well (pardon the pun). They look better than having a mat lying on the floor, imo. The mats we have are rubber-backed coir. We don't do more than vacuum them now and again, and they seem to have worn fine after 10 years of constant use. I seem to recall it was a little difficult/expensive to get a mat large enough for one of the wells, which is admittedly very wide. We didn't do a well for our back door, because it's right in the kitchen and would have looked odd. As it turned out, the gap underneath that door is so small that we can't have any sort of mat there, which isn't ideal. If I were doing that one again, I might have worked out a way to do a shallow well, perhaps sized to accept carpet tiles. -
Just say you want to be in by Christmas, but don't specify which one. Job done. I agree with the SIPS comments by others. Do a bit of research in the relevant forum and you'll see some of the problems people have had with them.
Low points: and how to get out of them
We don't need more funds. When we run low, we ask for donations, and generally that gets us what we need to cover costs. All BH staff are unpaid volunteers and that won't change. "New blood" isn't needed imo, but we don't have the advantage of lifelong endeavours like farming, gardening, or photography in terms of keeping members engaged over long periods of time. Many of our members join, hang around until their build is finished, then we never see them again (obviously for some *cough* @Pocster *cough that time could be measured in decades). Over time, there'll occasionally be the need for a new mod or administrator, but we've handled that as needed. Most of the current staff have been here for many years and have no intention of going anywhere. I don't know why you think BH dropping down the rankings suggests we'd be trying to sell it. I can categorically state that there's not even the hint of a glint of an idea to sell. We have no income other than donations. I suppose someone could take over and try to monetise the site, but I don't think there's a lot of money in forums any more, plus any potential buyer would have to know that they'd lose a lot of the membership if they added advertising, sponsorship, or membership fees. I agree that the info in the site is of limited value, especially given it's publicly available to all. -
The UK has some of the highest energy prices in the world, but that's driven by regulation and how the market is structured. I doubt increased local extraction would have much, if any, of an impact on energy prices. I agree, however, that high energy prices are one of the biggest issues facing the UK at the moment, both domestically and industrially.
WC only sets the ASHP flow temp, and I'm pretty sure it does so using only the exterior temperature. When running perfectly, the higher flow temperature completely cancels out the increasing heat loss as it gets colder outside. Once WC is properly set up, interior temps are solely a function of whatever thermostatic feedback you implement. For example, I have a 10 year old Panasonic Aquarea. I only have the dumb controller without a thermostat. All interior temperature sensing is handled by my home automation system, which controls a relay across the relevant switched live contact. The ASHP knows literally nothing about the internal temperature of the house other than indirectly via switched calls for heat.
Observations on need for heating upstairs
jack replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
Just before Christmas, we passed our 10 year anniversary in an MBC house. Overall, we're very happy with the decision to not have heating upstairs. My wife would probably prefer things a little warmer in the bedroom(!) but honestly, it's fine. Bedrooms rarely fall below about 18.5 degrees, and I have our heating system (UFH downstairs, single zone, polished concrete on insulated raft) set to come on if the upstairs temp falls below that. Currently the kitchen slab is 21.8 °C and the upstairs hall is 18.6 °C. My main regret is not putting in some form of UFH in the bathrooms. We even designed in dropped joists in the bathrooms to allow for insulation and flooring build-up, but in the end decided to save our pennies. It's not that the bathrooms are particularly cold, but the tiles feel a little chilly underfoot when upstairs is at its lowest temperatures. We ended up retrofitting IR panels to the ceilings. They help, but they're definitely not as good as UFH would be. We probably spent quite a bit more doing this than if we'd just put in electric UFH mats during first fix. If I were doing it all again, I'd definitely add UFH of some sort to the upstairs bathrooms, but would not add heating anywhere else. I would, however, consider installing air conditioning for summer. After a long run of hot days, it gets very warm upstairs. That said, I think purge ventilation could be a good alternative or complementary strategy if you don't live in a noisy area. Best to add retractible insect screens to bedroom windows so you can open them as soon as the temperature outside drops below the temperature inside, and ideally add a central openable rooflight to take avantage of stack ventilation. -
I'm not sure what you mean. We, and much of the west, exported our manufacturing (and energy/fossil fuel consumption) to China. I posted the chart to show that we're chasing net zero to our detriment while China forges ahead. What's misleading about that?
I didn't say they could build cheaply, I said more cheaply and quickly than the UK. How much are the two most recent UK nuclear plants costing? £40 billion each by the time they're finished?
100% For the most part we've just exported our dirty industries to places like China. They then got a lot better at it, provoking Jevons Paradox, and here we are: Look at the UK, saving the world with its carbon reductions.
HS2 was announced in 2009. It needn't take 41 years to design and build a nuclear power plant. Much of the delay is regulatory. We can do both. The UK is one of the most expensive places in the world to build nuclear power stations. I understand why it's cheap to build them in China, but there's no good reason why somewhere like Finland or France is able to build so much more cheaply and quickly than the UK. It's absolute insanity that it's no longer terminating in central London.
Agreed generally, but the way such subsidies work is a failure of government policy and negotiation. There's no reason for curtailment payments to wind generators to be anything like as lucrative as they are. The failure to increase grid capacity and interconnectivity is also unforgiveable. The fossil fuel industry also has the advantage of being able to avoid the costs of negative externalities. It's easy to conclude that the dead eagle at the base of a wind turbine was probably killed by the turbine. It's more or less impossible to attribute specific cases of lung cancer, emphysema, asthma, etc. to the burning of fossil fuels, but it's undoubtedly the case that it causes serious negative health impacts on human health, including huge numbers of unnecessary deaths every year. Fossil fuel extraction, transport, and use, have similar issues of their own. This is the one point I agree with wholeheartedly. Adding more renewables without dealing with the baseload required to cover periods of low renewables generation and drastically increasing storage at grid scale is completely unreasonable. Most people who want more renewables seem to not understand this. Imagine where we'd be now if government had decided to spend the HS2 money on fast-tracked nuclear power stations?
Most western car companies have been (pardon the analogy) asleep at the wheel. Look at the Top Gear episode from around 2012 where they visited China and ripped the piss out of what was being made over there. To be fair, much of it was dreadful, but I remember reading an article from probably that time plus or minus a couple of years where car experts opined that the Chinese wouldn't be able to replicate the complexity of existing supply chains etc in less than a couple of decades. They also said that China were too far behind in metallurgy to make good quality ICE engines. It's quite extraordinary how wrong they were. The Chinese have addressed the supply chains and metallurgy issues in short order, plus focused on EVs where the component count is much lower and the need for super high spec materials and machining is reduced in any event.
Nope, not me. I do look wistfully at their site every couple months. It's utterly insane how much prices have come down over the last few years.
