jack
    41
Everything posted by jack
  1. MBC Timber Frame. Irish company, but I think they have a factory somewhere in south west UK. I used them over 10 years ago, but several on here have used them more recently. Copy and paste this term into Google search: "mbc site:buildhub.org.uk" You can use glass with lower transmission values (i.e., it's designed to let less light through). A better idea, imo, is to build in some sort of external shading. We have electrically operated external venetian blinds on some windows, which are very effective, but there are other options, like shade cloth. You can get them built into concealed boxes at the top of the windows, so they're more or less invisible when not in use. You might end up with some visible guide rails on very wide windows, but they're pretty discreet. Not the cheapest option, but then neither is installing the amount of glass you're planning! I don't have any photos of my house on BuildHub, but plenty of others have shared. The MBC search above should show some options.
  2. +1 to all this. For reference, our house is almost exactly the same size as yours. We project-managed our build 10 years ago, but we had the benefit of using one provider for the foundations and timber frame. There were definitely some very stressful periods, mainly around poor (sometimes laughably so) workmanship and how that would be handled by the trade that did it. It's certainly doable, especially if you're well-organised and thick-skinned. We have similar amounts of glazing in our kitchen diner and it's one of my biggest regrets. Lots of glass can work okay if the space is big enough to allow furniture to be positioned well away from the glass. In our case, the space is something like 6 x 5.5 m and there's nowhere to put furniture without it being up against a window or sliding door. If I were doing it again, I'd get rid of most of the floor to ceiling windows and replace them with large ordinary windows on low walls (roughly table or back-of-sofa height). I'd also also replace the 5.5 m long slider with a pair of french doors with windows either side.
  3. The ground beam above looks like reinforced concrete, with cages having 16 mm internal longitudinals (don't know the proper term for them) and 8 mm rings (ditto). That said, I can't visualise it either. Selexus, are you saying something like the cages for the ground beams sit higher than the lower level of mesh you want to tie in to, and you're therefore unable to easily lay out the UFH pipe because the tops of the cages are in the way? A couple of sections showing the relationship between the ground beams, the mesh, and the insulation would be very helpful. I have reinforcement beams in my raft, but the cages for those sit below the mesh, in channels formed in the insulation.
  4. It isn't a democracy or a popularity contest. An objection totted out 20 times shouldn't(!) have any more effect than the same objection made once. And lots of pointless objections shouldn't(!) make any more difference to the outcome than none. Fingers crossed, but it sounds like you ought to be okay.
  5. As I guess you know, things like cutting down unprotected trees are completely irrelevant and the planning officer will ignore them. Depending on your council's policy, give the number of objections, there's a decent chance the application could be called into the planning committee for approval. That's an entirely different can of worms.
  6. I don't remember the details, but I asked a question on a plumbing or electrical forum many years ago. Can't remember the details, but it was something where there wasn't much real info online and I wanted to understand the issue before I got someone onsite to quote for the work. All I got was a load of aggressive wankers piled on saying I was cheap for not paying someone for the advice. I've never experienced anything quite like it.
  7. (Context: I'm a moderator.) As you may have picked up if you've spent some time browsing BuildHub, the anti-monetisation vibe runs deep. The site has no ads, sponsorships, or subscription fees. Everything is run by unpaid volunteers. Some of our members, like @Gus Potter, are very much on board with - and defensive of! - that ethos. I personally think it's one of the reasons that experienced people like Gus, @nod, @craig, @Nickfromwales, and many others, are so willing to freely give their time to help other members. I spotted the YouTube reference when you first posted, but in the context of the rest of your post I personally didn't see a problem. In theory, it could become an issue if your channel unexpectedly got very successful and became monetised. Even then, you'd need to keep posting links to the channel for that to become a problem. I imagine you'd get a polite request at that point to stop posting about your channel, but as you say, given your intentions that's a pretty unlikely outcome. In any event, you seem to be self-builders in the fullest sense of the phrase. I would love to have had the time, energy, skills, and confidence to do something similar when we similarly replaced a 1950s bungalow 10 years ago.
  8. Yes. I think the main issue here is that the roofer stopped the skirt when it reached the first lip, which is short and doesn't have an overhang. The skirt should have continued up higher into what looks like it might be the actual drip trim above the screw (see circled bit in my post above).
  9. Agreed. Stick with EPDM, it's great stuff when used properly. That's likely true. As far as possible, membranes should always be designed to direct water over and/or away from junctions, rather than relying on sealants. In this case, it looks like the orange circled section of the extrusion is an overhang: If that's the case, then I suspect the EPDM should have been lapped over the channel with the screw in it and tucked up and bonded into that recess. Can you check the rooflight manufacturer's installation instructions? Don't worry too much about damage to the wood. It's been a dry summer for most of us, so the wood was probably well and truly dried out before the latest rain. A winter or two isn't likely to have caused permanent damage, especially given the seal was probably functional for a lot of that time. If you're at all handy, this is doable without professional help. In the short term, I'd get hold of some decent waterproof plastic and cover the roof light with it, leaving enough at the sides to hang down and cover the area with the leak. Tie it down and leave it like that for a few weeks for everything to dry out. In a couple of months' time, and ideally after a dry, hot couple of weeks, you can install the EPDM permanently. Your rooflight manufacturer can probably point you in the direction of how this should be done, or there are loads of Youtube instructional videos (or ask here when you're ready). Given that the leak is only at the top, you don't need to worry too much about anything other than making sure you get the top edge well tucked up and bonded into the recess, and that it extends down past the sloped part.
  10. Your assumption isn't naive, that's exactly how summer bypass should work. Are you sure the function is enabled, and the mechanism is in working order?
  11. I'd also recommend asking your question in one of the relevant sub forums (Other Heating Systems is probably best). Lots of members don't check the Introduce Yourself forum, plus any useful answers to your question will more easily be found by others with the same problem in the future.
  12. Welcome Kevan. For a house with passive-class insulation and airtightness, it's feasible to do everything with direct electric heating. Have a look at @TerryE's posts on the topic. He uses cheap overnight power to do most of his house and water heating. While he pays more per kWh of delivered heat, he's saved the cost of an ASHP and associated plumbing/electrics.
  13. Welcome! You could try posting your question over in the Ireland sub forum. I get the impression we don't have huge numbers of Irish members, but that's probably the best place to find Ireland-specific advice
  14. Shims are designed to counter the weight of a window or door when it's open and not being supported by the latching system. They shouldn't have been removed. Even with shims, we have three or four large door-window frames that have sagged slightly in the direction that the weight of the open door drags the frame. The bottom seals have rubbed and in a couple of cases completely torn off. This might be due to the frames having been under-shimmed, or the shims shrinking over time (our shitty installers used softwood wedges, not plastic). To fix them now will be an absolute pig of a job. It might be less of an issue on the hinge side, but 100% I'd still put them back.
  15. Please note the comment I've added to my post above. It appears TKC Kitchens might be a different company to TKC (TK Concepts Ltd), which is also a kitchen supplier.
  16. Please note that this poster is associated with TKC Kitchens. Note: Please be aware that TKC Kitchens repeatedly linked to in posts by Tony687 seems to to be a separate company to TKC, which is also a kitchen supplier. It's not immediately apparent whether there's any connection between these two companies, so please be sure to check which one you're looking at before making any decisions. Do with that information (and other members' comments in the Howdens Trade Account thread I've linked above) what you will.
  17. Turns out it wasn't a coincidence at all - well spotted! Sorry we missed it at the time. If anything smells off in the future, hit the "Report" button and we'll take a closer look. Your email address (which forum staff can see) has a LOT in common with the user name in the link above, so you plainly uploaded that article to Medium. The article itself is a thinly-veiled ad for TKC Kitchens. All of your posts on BuildHub have involved pushing this company. Overall, it's clear you work for them (we're 99% we know exactly who you are, but it doesn't really matter). Since you've breached BuildHub's Terms and Conditions, we've locked your account from further posting. Please note that TKC Kitchens repeatedly linked to in posts by Tony687 seems to to be a separate company to TKC, which is also a kitchen supplier. It's not immediately apparent whether there's any connection between these two companies, so please be sure to check which one you're looking at before making any decisions.
  18. Welcome to BuildHub. A couple of points (I'm sure there are others): ASHPs don't heat water as hot as gas boilers do, so you'll want a larger tank to deliver the same amount of water to things like showers. Make sure you get a tank with a heat pump coil, which is longer than a standard coil for use with, e.g., a gas boiler. A longer coil allows for better transfer of heat into the water.
  19. https://www.instagram.com/reel/DLolteQt7Vz/
  20. From ~10 years of reading BuildHub threads, one general principle pops up again and again when it comes to building problems: the junction where one trade's work meets another. The timber frame company's work isn't square? Foundation guy's fault. Plasterboarding guy having trouble? Timber frame guy's fault. Windows a problem? Supplier says it's the installer's fault, installer says it's the supplier's fault. Roof issues? Roofer says the blockwork isn't level and it's the best they can do, take it up with the brickie. Costs aside, for my money there's huge value in being able to point at a potential problem and identify the one person who is responsible. I suspect that in some cases there are fewer chances of problems if it's all the responsibility of one entity, because there's less temptation to cut corners at each stage. If I wanted a shell built, I'd get someone in to do it. That's what we did. And of course, the two biggest subsequent problems were windows and roofing. The window installers blamed the framing company for some of their difficulties, even though they'd approved all measurements and external battening before arriving. The roofers blamed the timber frame company for ongoing leaks before the house was completely watertight. The leaks turned out to be 100% the fault of the roofers.
  21. Our house can get very hot upstairs during long runs of hot days. I've not got around to setting it up yet, but I have plans to boost the MVHR during the cheap overnight period when conditions are such that the summer bypass function is enabled.
  22. At a guess, some combination of incompetence, malice, disengagement, and self-interest on behalf of the council and its employees. Whatever the cause, the outcome has in many cases been deeply unfair. I can't see any reasonable basis for the requirement that every CIL box be ticked before you can even trim a hedge or lay some hardcore, for example. If the law is meant to be that self-builders don't pay, then the law's intention shouldn't be subvertable by councils requiring that a set of narrow formal requirements must all be met before an early, arbitrary, and unextendible deadline. It reminds me a lot of how the VAT self-build refund was operating for a while. The clear intention of the law is for self-builders to be able to recover VAT, but HMRC did everything in its power to subvert that intention by using a definition of "complete" that was completely at odds with any reasonable meaning of the word, and was certainly contrary to how it was used in the legislation.
  23. The last two or three issues of Private Eye have briefly addressed local council abuses of the CIL system, and this person's plight with Waverley council in particular. I don't know much about CIL (it didn't apply when I built), but I'm aware that there are huge potential financial traps for the unwary. Perhaps we should add a sticky post with a warning in the relevant sub-forum.
