nod
    72
Everything posted by nod
  1. nod
    Gates
    She’s at my sons body shop and is freaked out when he starts the compressor
  2. nod
    Gates
    Yeah good friend So handy when I need a workshop Won’t take anything for the oak
  3. nod
    Gates
    He’s cut a load of oak slats that simply slide in
  4. nod
    Gates
    Little at the moment Going to be BIG Great Dane
  5. nod
    Gates
    My friend rang and said I’ve knocked you a couple of gates up for around the back of your house Talk about overkill There only to keep my daughters dog off the lawn when she calls
  6. We did most of the building work ourselves But to get started we approached a local Architect for drawing and building regs and engaged a SE Pretty much the same as you are intending to do At a similar price Whilst I think professional fees can get out of hand I think what you have been quoted represents good value and will making it much easier for you to get coatings If you engaged a builder to do this He would do exactly what you are doing with a charge on top for his or her time Good luck with your build GARY
  7. I’m not sure about a door bell But I can answer the last bit There will be lots of questions Your right in trying to make yourself availed during the day
  8. Just a standard letterbox Spy hole would be personal choice
  9. Just called at a site to check if the pre plaster had been done It had None of the straps are fastened down Clout nail will have to do
  10. Get the heat on and you will see your garden again
  11. As I say if it won’t come off with a breaker you can go over it But being as it’s been on so long I would remove the lot
  12. Which ever system you choose A well insulated house does need much heating We never heat the first floor and have the UFH stats set at 18 The temperature rarely drops and when it does the boiler kicks in for a few minutes It costs peanuts to to run But I do agree at some stage soon new builds will not have the option of gas
  13. We decided against ASHP for a couple of reasons I think if your home is well insulated bills will be low regardless of which system you choose
  14. I’m with Peter here it’s not an unreasonable amount Especially if you are happy with the job It’s very difficult to calculate exactly
  15. I did one on my own build and got told off for it
  16. Beat me to the punch Good advise
  17. Unfortunately Tile trims are geared up to transporting in someone’s van So 2.4 is typical If your tile supplier can be bothered They can get you a 3 mtr trim I pay about 3.50 for a ally trim For 3mtr it’s about £12 rack With postage for a tube at about a tenner I normally piece them
  18. I think for the purpose of helping those that are in the planning stages and trying to get a feel for coatings We could break it up into several categories Turn key myself and a few others doing most of the labour and something in between and you have the spec of the build I know on our build we could have saved thousands had we needed to
  19. No I wouldn’t have included borrowing costs or rent in the build cost but some may want to highlight them Why I say this Is one member wanted to include the land cost which would make costing pointless
  20. No land to be included BUT We included in our £830 m2 everything in the house plus two d garages All fees and connection charges We had no borrowing costs But someone who has would be justified in including those
  21. Tiles shouldn’t be noisy on a solid floor They are certainly not cold on a heated floor
  22. I’ve put 159m2 Largest single area 95 m2 I can’t say I’ve noticed any problems If you go down the route of carpets it sorry of defeats the point of UFH Your other option is Engineered wood Perhaps noisier than tiles
  23. I normally use this Dilute 4-1
  24. The planners do tend to play with your lives Which has been a source of frustration to most of us on here For me it was the only time I felt stressed throughout the build
  25. You are best hiring a small breaker Much quicker and cheaper than ruining your own drill Anything that is so hard that it won’t come off with a breaker can be left and gone over The brick that is pictured looks smooth Which is perhaps why it has blown You will need to do a slurry coat prior to scratch coat scratch coat + Wet dash coat £30 m2 UPVC beads Extra for stainless Add a £1 for white cement
