nod
    72
Everything posted by nod
  1. Very similar to moving glazing panels Two sets of suction cups
  2. The largest I’ve used have been 200 x 1200 and they where very heavy
  3. No you will have 6 for the matting Which ever tile you use 20 adhesive for the 2.4 x 1.2 tiles
  4. You will need 6 mil for the underlay 9 mil tile would need 10 mil of adhesive making 24 mil build up A larger tile means less adjustment = Thicker bed
  5. They are fine with it not being signed off We were in 3 months before sign off The insurance started two weeks before we moved in All they said was obviously if you move your plasma screen and Rolex in the two week period They won’t be covered But the general fabric and decor will (Adrian flux) They really didn’t go into any depth Just asked about an electrical and gas cert and how long the house would be empty Gave us 30 days on the later
  6. They are fine with it not being signed off We were in 3 months before sign off The insurance started two weeks before we moved in All they said was obviously if you move your plasma screen and Rolex in the two week period They won’t be covered But the general fabric and decor will (Adrian flux)
  7. Yes they are more costly as it’s a two man job and the bed needs to be thicker 20 mil He can hire a tile cutter that will cut across the tiles We tend to use a wheel for most of the heavy tiles Expect to pay 40m2 You are right to pay the extra for Italian Tile leveling system won’t help if they are not flat There are some cheap imitations out there
  8. We came in at 815m2 but had to do most ourselves and had the advantage of another 100m2 over you which helps spread the cost I would expect to add 40% to ours in the SE Though I do think you are over allowing of your professional fees
  9. Quick call will give you a good idea Un my knack of the woods a crane about a £1000 per day Scaffolding 20m2 Though I would expect your location to be more
  10. I would go with steel and block Your obviously trying to keep the cost down I’m in the NW of England and find your costings to low London prices are going to be even higher Bathrooms and kitchen Windows Doors Garage doors can be expensive Kitchen and bathrooms also I would put a support under that corner Cantilever look great but can be expensive Only my take Sorry if it sounds a bit negative Also scaffolding and crane to factor in
  11. I would go with steel and block Your obviously trying to keep the cost down I’m in the NW of England and find your costings to low London prices are going to be even higher Bathrooms and kitchen Windows Doors Garage doors can be expensive Kitchen and bathrooms also I would put a support under that corner Cantilever look great but can be expensive Only my take Sorry if it sounds a bit negative
  12. If you have looked at commercial Forget grid and tile They won’t benefit you A top hat and plasterboard can fitted loosing you125 minimum A gyp click ceiling can be fitted loosing minimum of 60 mil Just depends how tight for space you are
  13. If you look through my posts I put a breakdown of our costs when we where doing our vat claim about 24 months ago Our main savings where on Labour or lack of it Also keeping professional fees to a minimum Under 2.5k
  14. Yep Ive quoted for large jobs which I will struggle to do I’m not taking anymore work in till after September now
  15. Porcelain looks great and is maintenance free Timber requires to much maintenance for me Unless you just let it weather I’m working on some apartments that have used an engineerd timber cladding on a simple Top hat and clip system 25 year guarantee but expensive £50 for a 2.4 length
  16. Most new site use them If you contact your widow supplier They should be able to supply formers to you
  17. Building and related work has been very busy over the last few years Made worse by the COVID and the government paying companies and individuals not to work The extension to The Furlough will only make matters worse Keeping materials and labour in short supply This is Something we will all have to put up with
  18. EPS external insulation is normal with a render covering Yes there are grants
  19. It’s the first one I’ve tried Design map coming tomorrow
  20. Yep all sizes The ones I’ve used go as low as 35 Plus your flag
  21. It’s the first one I’ve tried Design map coming tomorrow
  22. If you want it to BM be bombproof You could use fiberglass and raise the flags up on podiums allowing the water to drain through and off to a drain and hopper at either bottom corner
  23. Just had a call from the electricity supplier Quote for two plots coming from overhead cables Crossing a moderately busy road £7000 A lot more than last time as all services where on the pavement in front of the plot Though £3500 per plot doesn’t sound to bad
  24. As long as it’s not freezing or frosting overnight Your render can go on any time of the year Any Aldi build ups can be sorted in minutes We use Algicide 6-1 dilution sprayed on Tge rain does the rest
