Mike
Everything posted by Mike
Thanks for returning and providing the feedback - which is very disappointing. I'll cross my fingers extra hard as I've someone lined someone up (for a lot less than €6,000 labour) to install one later this year in my French apartment...
Are we targeting ASHP's at the wrong market?
Mike replied to ProDave's topic in Air Source Heat Pumps (ASHP)
Yes, and it's only low-grade heat that's pumped to the flats so the heat loss of the common pipework is very low. There would be no central heat pump for the building as a whole. They do, and they recommend they over sizing the tank by 30% to account for the lower temperature (the maximum temperature produced is around 65°C). -
Sure - it's one small-scale example project; It's the technology that I was highlighting. Heat the Streets is a programme and interesting because it was open to any and all homes irrespective of ownership in the streets they were working on. But they've done over 300 projects across the country for single owners (Housing Associations, Councils, etc.), many using the same networked heat pump technology. Can't comment on the smell in Portreath though! -
I hope you have adequate air vents through the external walls to allow a cross-flow of air to and from the outside behind your studs? If not, you'll make the wall wetter and risk condensation on the back of the studwork, causing bigger problems in the future. Don't use bubble wrap - you risk trapping moisture behind it. If you need anything then it would be a moisture-permiable VCL, but may be better with nothing - you'd need a WUFI analysis to help make that decision. BTW If this is the same wall mentioned in your previous thread, this is unlikely to be the best solution.
MVHR into a cold roof ?
Mike replied to Post and beam's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Yes, option A. However will it fit through the loft hatch for installation & future replacement? -
I'm considering installing a beam and block floor in Nassau but...
Mike replied to Boyblue's topic in Floor Structures
Wouldn't it be cheaper to import fill (hardcore or insulation sheets) rather than beams? I'm not clear which dimension are which, but you'll need a design from the beam manufacturer, so ask them. But placing beams closer isn't an issue by itself. -
Unbelievable brickwork , will this pass building control!
Mike replied to Jamo73's topic in Bricklaying, Blockwork & Mortar
+1. It is sloppy, even for overhand work. I'd approach the BCO and suggest that it contravenes Part 7 (b): Materials and workmanship 7.—Building work shall be carried out— (a)with adequate and proper materials which— (i)are appropriate for the circumstances in which they are used, (ii)are adequately mixed or prepared, and (iii)are applied, used or fixed so as adequately to perform the functions for which they are designed; and (b)in a workmanlike manner. -
And, in the news last week: UK has highest electricity prices in Europe - and lowest heat pump uptake At the moment, electricity costs 3.9 times as much as gas to produce the same amount of energy in the UK – with electricity costing 24.50 pence per kilowatt hour (kWh) compared to 6.24 pence for gas, according to Ofgem. The gap between electricity and gas prices is largely because most of the levies – such as to fund new solar and wind farms and to improve energy efficiency – sit on electricity rather than gas bills. Furthermore, the carbon tax to discourage fossil fuel use – charged on the carbon dioxide produced when generating electricity – is not applied to the gas burned in central heating boilers. As a result, in 2023 the UK had the most expensive electricity in Europe, compared to its gas price – and one of the highest electricity prices in absolute terms. -
Likewise, if you can heat Bowhill House and Wentworth Woodhouse with heat pumps, you can heat anything. Wentworth Woodhouse, Andrewrabbott, CC-BY-SA-4.0, more -
Or connect them to networked heat pumps in the street, like those installed by Kensa: https://kensa.co.uk/networked-heat-pumps -
+1; a very good product.
What next for heat pumps after BUS and MCS?
Mike replied to joth's topic in Environmental Building Politics
About 28% air-to-water last time I looked (175,000 air-to-water in 2019, up from 90,000 the year before) - https://mcsfoundation.org.uk/news/new-report-france-cuts-heating-emissions-ten-times-faster-than-uk-with-heat-pump-roll-out/ That may well have changed since gas boiler were banned for new build 3 years ago. -
Given any experiences you have had, what would you choose tomorrow
Mike replied to Makeitstop's topic in Windows & Glazing
It would hurt my pocket too, but that's the ideal. FWIW my current project uses double-glazed oak, linseed oil painted (triple glazing wasn't possible due to being in a conservation area) As for why not PVC: toxins and pollution inherent to PVC production & disposal- see https://www.greenspec.co.uk/building-design/polyvinyl-chloride-pvc-environment-health/ impossible to access quality of the PVC used (and in particular the stabilisers required to give it durability) without independent chemical analysis plastic visual appearance often clunky visual appearance surface degradation and discolouration through UV light & surface deposits susceptibility to impact damage (depending on location) & difficult / impossible to repair susceptibility to hairline cracks through thermal cycling questions over the long-term availability of suitable spares - replacement glazing beads, hinges, etc. limited life expectancy - typically 20 to 30 years - unless high-spec. But low-spec is often chosen due to lower cost uValues often not great (unless high-spec) very limited recycling facilities (see also toxins & pollution above) -
1st: Anodized aluminium-clad oak with triple glazed, budget permitting. Best all-round performance, durability & ease of maintenance & repair. 2nd: Oak, with double glazing to the south and triple to the north. 3rd: Other hardwood timber with double glazing to the south and triple to the north. 4th: PassivHaus-certified aluminium Never PVC - too many potential problems. I've posted about that somewhere on here. -
I've used 20mm thick cork for selected areas on my current refurb where there wasn't space for hemp, and it is expensive. However it does have properties that are unmatched by any other insulation I can think of. In addition to excellent eco-credentials it is / has: lightweight good weight resistance good thermal resistance good acoustic resistance good fire resistance slow burning & self extinguishing produces only low levels of non-toxic smoke water repellent rot proof even in high-humidity environments vapour permeable releases no volatile organic compounds (unless processed) dimensionally stable doesn't deteriorate even over very long periods of time has some elasticity insect resistant anti-static good visual appearance if exposed good repairability if exposed pleasant to use easily cut easily fixed reusable (subject to fixing method) recyclable and probably a few more I've forgotten... So there are many reasons why you might choose it, cost permitting.
MVHR Unit + Ducting Suppliers
Mike replied to Duncan62's topic in Mechanical Ventilation with Heat Recovery (MVHR)
A Zehnder unit + other components from 2 or 3 other EU suppliers, depending on cost & availability. -
The lowest cost option is to ditch the screed and put the UFCH in the concrete slab, which can be polished.
Extension (slightly large...) and renovation in Cambridgeshire
Mike replied to Tuppers's topic in Introduce Yourself
Welcome to the forum! Someone else is bound to say this if I don't so... from the extent of your works, you may be better off rebuilding. But either way you've come to the right place :) -
Indemnity policy/adverse possession issue
Mike replied to Garyf123's topic in Party Wall & Property Legal Issues
Because railways are a special case. Under the Railway Regulation Act 1840 refusing to leave railway land a criminal offence. Adverse possession of their land is therefore never valid. See also https://www.justanswer.com/uk-law/bexl6-understand-can-t-claim-adverse-possession-railway.html -
That is worth doing. Last year I calibrated a batch of 16 SHT31-Fs temperature-humidty sensors (though they're not currently recording) and while the temperature recorded by of all was consistent (within 0.1°C of each other), the humidity reading was out (too low) by between 0.6% and 2.55% compared to the expected result.
Horns aren't a traditional feature of windows. They were added when timber window manufacture became mechanised in the 2nd half of the 20th century to add strength during transport, with the intention that they should be cut off when installed. In mass-market housing they were often left on to cut costs.
If you can connect a hose to a vacuum cleaner exhaust port (as well as the regular hose), that would probably work. Suck in the beads from one end and blow them into the cavity through the other.
No idea about Norway, but in France there is a similar scheme with means-tested subsidies + interest free loans + 5,5% VAT. BTW, France now installs the most heat pumps in Europe, banned gas central heating in new-build from January 2022, and gas standing charges are going up due to the number of users quitting gas (despite having to pay for disconnections). Since 2000 the French scheme requires installers to have a sample of their installations audited each year (for appropriate design & installation, correct paperwork, legal & financial aspects, etc.) with the risk of suspension or removal in case of unresolved problems. If the MCS scheme doesn't already include that (I've not seen it mentioned), that may well help resolve many problems. -
This certainly seems to be key problem - the window / door should ideally be positioned mid-way across the (filled) cavity, or as close to that as can be sensibly be achieved, so that no broken metal touches both the inner and the outer leaf. If that's not the case, I'd seriously think about getting it refitted.
- 18 replies
- condensation
- windows
(and 2 more)
