Everything posted by Crofter
How do your BMs compare to Wickes? They can often be quite competitive on things like this.
Insulating to Min Building Regs
Crofter replied to Ian's topic in Energy Efficient & Sustainable Design Concepts
Sounds great, and a similar concept to my own place but a bit bigger. As IanR says your u values look to be better than the BRegs minimum. I thought that an air test figure of under 5 meant you needed MVHR? Or have I mis-remembered that?- 26 replies
Thanks, I seriously could not have managed it without your help!! I should put together a separate blog post about just the bathroom as it was a big project.
It's just cheap stuff from Soak.com- I think the whole lot came to about £250. Pottery side of things seems fine but I don't know how long the unit itself will last. The shower tray and screen was about £200 off eBay. Total spend on the bathroom was about £800 inc lino, tiles, etc. Just got to do the skirtings and fit a towel rail now.
MVHR: More extracts than supplies?
Crofter replied to Crofter's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I'm not sure what will work best. I had actually been thinking about putting the extract at the apex of the internal gable, as that would prevent a pocket of warm moist air gathering up there. The problem with placing vents on the internal gable is that you are reducing the space between them the higher up you go. -
It's starting to feel like the finish line is in sight now. Since my last entry, I've largely finished the interior including all the flooring, the doors, most of the kitchen, the windowsills, and the huge and daunting task of the bathroom (big thanks to @Nickfromwales for answering my hundreds of questions on that one!). I got a plumber in to install my UVC (sorry Nick, forgot to get a photo of that). I've also done a bit more of the cladding, but the exterior work has been on the back burner. I've also gone back to work full time since my last blog post, which is why everything has slowed down so much. Still managing to get a bit done in the evenings and at weekends. You'll notice some furniture has appeared, some of this was given to me by a neighour and was very handy for storing all my tools etc; the bed and sofa were in storage with family and eventually I exhausted their goodwill and had to take delivery of them! The shower has had a couple of test runs, and SWMBO reports that it is very nice indeed. The plan is to be open for business in April, which should be tight but doable. I expect that at that stage I'll still have some outside jobs left to finish but the inside is only a few days away from completion now. Sorry for the crappy image quality- will have to do a bit better when the time comes to do the proper marketing shots
It's really a bit too late for that sort of change. I admit I should maybe have thought this through in a bit more detail at the time, before everything got boarded, plastered, and painted. -
Thanks for the feedback Jeremy. One thing that I haven't been able to convey in the sketches is that it would be possible to put vents into the 'internal gable', which is at the left hand edge of the shaded area in the main room. This would allow vents higher up in the room, right up to the apex- but of course that brings them close to the centreline. -
OK as promised, some rough sketches showing the space I have to work with. First one shows the floorplan. The main room is open to the bedroom via a double doorway- this was originally going to have french doors in it, but I have shelved that plan at least for the time being. There is a cupboard off the main room, and an en-suite off the bedroom. Second pic shows, in grey, the areas in which it is possible to fit ducts/vents for MVHR. Vaulted ceilings prevent any ducts being taken outside of these zones without recourse to ugly box outs, which would be aesthetically unacceptable. The third pic shows my proposed vent locations, with one additional extract in the warm loft space, not shown. -
Thanks for those thoughts. The only bedroom (this is a very small house) is open plan to the living room/kitchen. The only places in the bedroom that I can duct air to are pretty close to the en suite doorway, so I think that any supply placed there will just end up being sucked out through the gap under the door. The loft extraction point would be a trickle really, just to prevent buildup of warm moist air. -
I'm aware of the basics of an MVHR install, that you want to keep everything balanced, you want to maximise the distance between supply and extract points, and that you want to extract from areas of higher humidity i.e. bathrooms and kitchens. My problem is that with a very small open plan house, I am struggling to find places to put the supply vents. I obviously want an extract in the bathroom, one in the kitchen, and I think it would be good to put one at high level in the loft space as that is where all the humid warm air will tend to go. These three points would end up as far from one another as it is possible to get. If I then had a single supply vent centrally located, that would maximise the distance between supply and extract points. But it's obviously not great from the point of view of keeping everything balanced. I'll try to attach some pictures of the house and a floorplan later.
How much to insall a sewage treatment plant?
Crofter replied to vivienz's topic in General Construction Issues
Well if you're being quoted £5k for the whole job inc a new soakaway, that's a fair bit less than I ended up paying.- 10 replies
- remove septic tank
- dig hole
(and 2 more)
Are you retaining the existing soakaway? That can be a bigger project than the tank/plant itself.- 10 replies
- dig hole
(and 2 more)
Will try to reply properly when I have more time, but yes basically a bothy is a small, simple house located somewhere remote. Could also be a shieling, nowadays gently used by walkers and climbers. You wouldn't traditionally expect plumbing, lighting, etc- a super posh one might have a woodburner, more likely an open fire. Toilet facilities would consist of a shovel and, if you're really lucky, half a roll of toilet paper!
My Telford Tempest UVC is now all plumbed in and has had a night to heat up on E7. SWMBO says she's going to rest drive the shower this morning Anyway, I've noticed how hot the pipework gets where it meets the tank. I've already added lagging to the pipe and fitting that comes out of the top of the tank, next step would be where the PRV emerges- would this be allowable? I know you're not supposed to cover up the immersions. Thanks
In her infinite wisdom, SMBO selected bevel-edged metro tiles throughout. Little did I realise what this would mean when it came to lay them! I've finished the toilet/shower, thank goodness, and am shortly moving on to the kitchen splashback. Basic question: what should I do to start off the first row of tiles? I don't have an upstand, by the way. I think that starting with a whole tile looks a bit odd, because of the bevel. But maybe that's just me. Is it normal to cut off the bevel and start with a slightly smaller tile? Finally... anybody got any tips for siliconing the edges of these bloody things?
Gap to leave for integrated appliances?
Crofter replied to Crofter's topic in Kitchen & Household Appliances
It's a few mm under 600- will have to measure it tomorrow. I thought that if I put the carcasses either side exactly 600mm apart, then the door wouldn't actually cover the gap...? -
New diesel and petrol vehicles to be banned from 2040
Crofter replied to Triassic's topic in Environmental Building Politics
Holey moley it's another world out there. I consider £1000/yr an acceptable cost for a car, to cover say 6k miles. I can see why Tesla had to go for the top end of the market first, though, to become established. Here's hoping that the Model 3 production bugs will be ironed out and they will start becoming an option for more people (like me!) -
Hopefully this is a straightforward one. My kitchen is a straight run of units that comes to 4m total, with an integrated fridge and dishwasher, both full size (600mm nominal). I have two doors to be fitted to the appliances, which are yet to be bought. These measure just under 600mm. I'm at the stage of getting the unit levelled up and fixed to the wall, so I need to know exactly what gap to leave. Do I want to make this exactly the same as the door, or a little bit under, so that the door closes against the carcasses on either side? Cheers
boulder mvhr any good?
Crofter replied to Alexphd1's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Can't remember exactly now, but I have a vague feeling it might have been the one that Damian was talking about on another forum? -
I've had mine run up to test it, but not finished the installation yet. I have to say I'm not blown away by it. It's noisier than I expected (hoping final install will sort this) and the humidity sensor is, stupidly, mounted in the control unit. I'm actually going to remove it from the pcb and mount it remotely, in the extract duct. Shouldn't really have to resort to that sort of bodge. And finally, the power consumption is relatively high, at 50w, which I knew before I bought it- a different make might cost only £30/yr to run vs the £50 for the Boulder, so I couldn't justify the extra cost of a better unit on that basis alone as the payback time would be measured in decades... -
Thanks chaps... and have a good Christmas
With a tall pillar tap it doesn't really matter whether it's fitted to te basin or not- it's still way up inside a narrow space, inside the tap pillar itself.
Fitting the tap for the basin. Three parts to this question: - how the heck do you tighten up the tails on a tall pillar monobloc, when the connection is buried several inches up inside the thing? Or is hand tight sufficient? - should I junk the flexi tails that came with the tap, and get solid copper ones instead? And if I do, are the connections at the top end all the same? - I need to hook this up to Hep2O, so is it worth junking the supplied flexis which end in a 1/2" thread, and fitting Hepworth's own flexis that have push fit connectors already on them? The other option is to use the existing flexis and buy Hep tap conns, which only saves a few quid and means extra connections. I'd also trust a Hep flexi over an unbranded eBay one. Thanks for any help
MvHr in cottage refurbishment
Crofter replied to Cpd's topic in Mechanical Ventilation with Heat Recovery (MVHR)
That unit looks decent, nice find
