twice round the block
Everything posted by twice round the block
Beware: Smokey and the Log Burning Bandits
twice round the block replied to NSS's topic in Housing Politics
There were more than 200.000 new log burners installed last year and with the rising fuel prices the number is expected to be far higher this year. Khan is trying to get them outlawed in London.... along with everything else that creates an odour. -
It works to a degree for trades pricing some stuff, but not for home owners.
I've stayed in one of their builds on Skye, as it's run as a B&B. The build quality and finish was spot on. I don't think you will be disappointed with the end result even though communication doesn't seem to be their strong point.
Which kind of professional to engage?
twice round the block replied to WWilts's topic in Party Wall & Property Legal Issues
Depends on how thick your nib is on your red marker pen. Make sure land registry and your solicitor have got the boundary in the correct place. You will also need to take tax advice on the other plot. -
Dangerous wall - shuttering required?
twice round the block replied to woodman23's topic in Foundations
HSE Have the power to shut down a job instantly, if they are not happy with any part of it. Even the vibration caused by a diggers engine ticking over is enough to collapse any excavation. -
Slate roof tile suppliers
twice round the block replied to Internet Know How's topic in Roofing, Tiling & Slating
International slate sales. http://internationalslate.co.uk/ Based in Buckinghamshire, large importer of Spanish slate. -
Turfcutter or similar tool - handy for laying slab?
twice round the block replied to Pabbles's topic in Garages & Workshops
I would hire in a skilled owner operator. If your doing it yourself and you take out too much earth, back filling with mot type 1, or crushed concrete will soon swallow a few extra meters at £70 a cubic meter.... so zero cost saving. -
DIY ers become craftsmen (and woman)
twice round the block replied to saveasteading's topic in General Joinery
Where your yellow steps are in the door way. I'm afraid to say that frame is 100mm to far into the corner, and to try and do a finish as it is, will not be very pretty with BOTH frames. Hold two bits of plaster board into the corner, then imagine two bits of architrave stuck in there as well. I know you have the linings to go in yet but you don't have enough free play. Just my view point, please don't take it as a criticism 😍 -
Yeh. in basket weave 🤣🤣🤣
It's down to building control the depth you excavate too, and the concrete and blockwork that goes in. They're the ones that have to sign it off before you can go any further with the build
Have you had a detailed soil survey done on this plot ?
@Lucasgrantmaw I'll answer the soil survey question as I'm sort of collaborating on this build with Lucas. An in depth soil survey was done in 1996 due to the current property subsiding. As a result 32 piles were put in to a depth of 7m below the property and a raft built on top of them below the existing footings. Nothing has changed on site regarding the sub soil make up. Due to the positioning of the original property, this will be demolished and a new property will be built to make better use of the plot orientation and will not use any of the original piled foundations. The rest of the information Lucas and his wife will need to make everything happen will be down to them too research along with other forum members on here to help them unravel some of the complex issues with a passive house build. That's my two pennies worth, I'm off now to build some garden walls when the weather sorts itself out.
- 11 replies
- isotex
- eps foundations
A honing tool, which is lots of cutting balls attached to spring steel. Available in different sizes, but only good for removing small amounts of material. https://www.amazon.co.uk/BGS-1265-Honing-Tool-flexible/dp/B07XZRGNGJ/ref=asc_df_B07XZRGNGJ/?tag=googshopuk-21&linkCode=df0&hvadid=443259906233&hvpos=&hvnetw=g&hvrand=1315534557284720573&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1006490&hvtargid=pla-891460498067&psc=1&tag=&ref=&adgrpid=103776439380&hvpone=&hvptwo=&hvadid=443259906233&hvpos=&hvnetw=g&hvrand=1315534557284720573&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1006490&hvtargid=pla-891460498067
Leaking glazed roof - outhouse
twice round the block replied to Richini's topic in Roofing, Tiling & Slating
This is just a conservatory surly. You need to make more changes than just a roof to retain heat if you've only got a single skin wall. Have you thought about demolishing it and put in planning for a proper extension? Does this link to the house through a patio door? -
What size digger do you wish you'd bought?
twice round the block replied to janelondon's topic in Tools & Equipment
You can't let other contractors loose on a machine, if they find an unmapped cable or collapse a trench when someone is in it... your going for the high jump. Larger machines are cheaper secondhand as you can only tow upto 2.7t, so anything bigger has to be transported on low loaders etc. and the cost can be high, even more so if it ever breaks down on site.. -
Timber Frame & Insulated Raft - One company?
twice round the block replied to SonnyB's topic in Timber Frame
Are you picky 🤣🤣🤣🤣🤔 -
If the wall collapses onto your land at least you'll have a supply of s/h bricks or hard-core. This was my wall that when I cut the ivy off the otherside the wall fell into my neighbours garden !!! Is your neighbours wall as high or bulging out as much as mine was ??? if not I don't think you have a problem.... apart from a personality clash. Kiss and make up.
Hardest part is trying to get the stuff out of the mixer drum. The more loads you do the worse it gets. Good alloy straight edge and wooden float works wonders After putting down a row of screed around the edge of the room and one down the middle, fill in the voids to the level... easy for old school... non of this pump slurry.
